PUNCH UNIT 12.5MM
Slug-Buster Knockout Punches 0.492 to 2.520
Cat No:
06727
UPC No:
783310067276
Description
"The contractor's choice - worldwide
Unique punch profile also splits slugs for easier slug removal
Use with battery-powered, hydraulic, ratchet or manual drivers
Uses standard Greenlee dies and draw studs
Slug Buster punches available in sizes up thru 2.52"" (64.0 mm)
U.S.Patent #4,543,722 for Slug-Buste "
Specifications
Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic
Capacity Mild Steel : 16 GA (1.500 MM)
Includes : Punch, Die And Draw Stud
ISO : 12
Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers
PG : 7
Replacement Part : 06728 UPC 06728 Punch, 06729 UPC 06729 Die And 1675AV UPC 04218
Draw Stud
Size : 0.492 IN (12.500 MM)
Sub Brand : Slug-Buster
Type : Knockout
Weight : 0.300 LB (137.000 GM)
很抱歉,暂时无法提供与“06727”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+776.199671+100.71127
