DIRTSP8224D
DIRTSP8224D
    CROUZET(高诺斯)
DIRTSP8224D 数据手册
CONTROLS CONTROLS IR.T SERIES CURRENT CONTROL RELAY UL listed • • • • • CSA recognized Automatic or Manual Control Start-up Inhibit Adjustable Hysteresis Multiple Voltages LED Relay Status Indicator 1. AC Current Control Without Latching: The output relay is energized when the current (peak current on AC) overshoots the level selected on the potentiometer. It de-energizes when the current falls below the normal current by 5 to 50% or when input power breaks. The hysteresis is controlled by a top mounted potentiometer and its selection does not change the chosen current level. 2. AC Current Control With Latching: The output relay is energized when the current reaches the selected value and stays latched. The contact between terminal B1 and B2 (or 11 and 9) should be opened or input power to the device interrupted to reset. In this case, it is preferable to reduce the hysteresis 5%. S1 hysteresis 5 R S1 S2 Manual Unlatching Threshold SPECIFICATIONS: hysteresis Input . . . . . . . . . . . . . . . . . . . . . . . . 24 VDC, 24, 48, 110, 220 VAC ±15%, 50/60 Hz Power consumption . . . . . . . . . . . 3 VA maximum CONTROL RANGE PERMITTED OVERLOAD DC AC INPUT LESS THAN CURRENT CURRENT RESISTANCE PERMANENTLY 1 sec Peak 5 to 100 mA 3.5 to 70.7 mA 1 ohm 1.5 V 5A 0.05 to 1 A 0.035 to 0.707 A 0.1 ohm 5A 17 A 0.5 to 10 A 0.35 to 7.07 A 0.01 ohm 15 A 55 A Hysteresis selection . . . . . . . . . . . 5 to 50% of input current Repeat accuracy . . . . . . . . . . . . . . ±2% at a constant ambient Response time . . . . . . . . . . . . . . . . 100 ms On Make 200 ms On Break Output Relay . . . . . . . . . . . . . . . . . SPDT Relay Contact material . . . . . . . . . . . . . . AgCdO Maximum loading . . . . . . . . . . . . . 10 A AC resistive 1 A DC inductive Maximum switching voltage . . . . . 250 VAC or DC Relay maximum power rating . . . . 2500 VA 30W Mechanical life of relay . . . . . . . . . 30 x 104 operations Electrical life of relay . . . . . . . . . . . 2 x 105 at 2500 VA resistive load Operating temperature . . . . . . . . . +14°F to + 140°F -10°C to +60°C Weight . . . . . . . . . . . . . . . . . . . . . . 7 oz. (200g) R WIRING DIAGRAM: ˜+ MOUNTING LIR-T (+)5 to 100mA (+)0.05 to 1A (+)0.5 to 10A S1 (+)5 (+)5 to 100mA 100mA ~ – (+)0.05 1A ~ (+)0.05 to 1A – (+)0.5 to 10A (+)0.5 10A ~ – 0V (–)0V (-)8v S1 6 5 E1 E2 E3 7 4 3 8 9 R 2 12 14 B2 B1 1 M A2 Memory S2 11 10 Memory S2 (-)8v0V ˜Note: Upon energization of the current control IR.T Series Relay, the time delay, which is adjustable from .1 to 10 seconds, inhibits the output relay during start-up periods. The delay time is adjustable via a potentiometer located on the side of the case. Applies to both versions, with and without latching. Note: It is recommended that the unit be adequately fused. D = DIN-rail mounting L = 11 pin plug-in DIR-T A1 11 Option: 24 VDC power - the voltage and the measured current must be from separate sources. ORDERING INFORMATION: Automatic Unlatching Threshold L IR.T 110A MOUNTING SERIES INPUT POWER SERIES IR.T INPUT POWER 24D 24A 48A 110A 220A = 24VDC = 24VAC = 48VAC = 110VAC = 220VAC Products and specifications subject to change without notice. Consult factory for application assistance. 204 Airline Drive, Suite 300, Coppell, Texas 75019 / Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 5-21 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: DIRT110A LIRT110A LIRT220A DIRT220A DIRT24A DIRT24D LIRT24D LIRT24A DIRTSP82110A DIRTSP8224D
DIRTSP8224D 价格&库存
很抱歉,暂时无法提供与“DIRTSP8224D”相匹配的价格&库存,您可以联系我们找货
DIRTSP8224D
    • 10+654.3358010+83.99180
