SP/NOS-90
SP/NOS-90
    EATON(伊顿)
SP/NOS-90 数据手册
Technical Data 1030 Effective June 2017 Supersedes July 2013 250 V NON/600 V NOS Class K5 and H fuses Catalog numbers (amps) NON-1/8 NON-1/2 NON-3/4 NON-8/10 NON-1 NON-1-1/4 NON-1-1/2 NON-1-6/10 NON-2 NON-2-1/2 NON-3 NON-3-2/10 NON-4 NON-5 NON-6 NON-6-1/4 NON-7 NON-8 NON-9 NON-10 NON-12 NON-15 NON-20 NON-25 NON-30 NON-35 NON-40 NON-45 NON-50 NON-60 NON-65 NON-70 NON-75 NON-80 NON-90 NON-100 NON-110 NON-125 NON-150 NON-175 NON-200 NON-225 NON-250 NON-300 NON-350 NON-400 NON-450 NON-500 NON-600 Carton quantity Description Basic protection 250V NON Class K5 and H general purpose, non-current-limiting, one-time fuses. Amps 1/8-60 65–100 110–600 Dimensions – in All Diameters ± 0.008 NON-(amp) 250 Vac • 125 Vdc (1/8-100 A) • Amps 1/8-600 A • IR 450 to 600A 3" (0.031) 8.63" (± 0.094) 2.06" 0.81" (± 0.008) Volts • 2.59" 0.56" (± 0.008) 1/8 to 30A Ratings • 10.38" ( 0.094) 2" (0.031) Catalog symbol • Qty. 10 5 1 35 to 60A 225 to 400A 5.88" (± 0.062) 7.13" (± 0.062) 1.06" 65 to 100A 1.56" 110 to 200A • 50 kA Vac RMS Sym. (1/8-60 A) Features • 10 kA Vac RMS Sym. (65-600 A) • • 50 kA Vdc (1/8-60 A) • 10 kA Vdc (65-100 A) Protect lighting, heating and other circuits not subject to temporary surges and where available short-circuit currents are relatively low • NON one-time fuses do not have any appreciable degree of timedelay and thus should not be specified in circuits where large transients or motor overloads occur. Use Bussmann series advanced protection FUSETRON™ FRN-R or ultimate protection Low-Peak™ LPN-RK dual-element, time-delay fuses. • For general purpose circuits, size at amp rating of circuit • For motor circuits, size at 300% to 400% according to the NEC® motor ampacity tables 430.247 to 430.250, per 430.6(A)(1) Agency information • UL Listed, Class K5 (1/8-60 A), Std. 248-9, Class H (65-600 A), Std. 248-6 (125 Vdc 1/8-100 A), UL Guide JDDZ, File E4273 • CSA Certified, Class 1421-01, File 53787 (1/8-12 A, 65-600 A)† • CE † For CSA Certified 15-60 A, see PON data sheet no. 4126. Technical Data 1030 250 V NON/600 V NOS Class K5 and H fuses Effective June 2017 300 600A 1-, 2- and 3-pole modular power distribution fuse blocks up to 60 amps — see data sheet no. 10490 400A • 200A 1-, 2- and 3-pole modular fuse blocks up to 600 amps — see data sheet no. 10487 60A 100A • 30A 35A NON time-current curves — average melt 15A 20A Recommended fuse blocks AMP RATING Fuse reducers for Class R fuses † Not CSA certified. Catalog no. (pairs) 250V NO.263 NO.213 NO.216 NO.226 NO.2621 NO.2641† NO.2642 NO.2661† NO.2662† NO.2664† For additional information on Class K5 & H fuse reducers, see data sheet no. 1118. 100 10 TIME IN SECONDS Desired fuse (case) Equipment fuse clips size 60 A 30 A 30 A 100 A 60 A 60 A 200 A 100 A 100 A 400 A 200 A 100 A 600 A 200 A 400 A 1 CURRENT IN AMPS 2 Eaton.com/bussmannseries 10,000 1000 20 0.01 100 0.1 Technical Data 1030 250 V NON/600 V NOS Class K5 and H fuses Effective June 2017 Dimensions – in All Diameters ± 0.008 13.38" ( 0.094) 5" (± 0.031) 0.81" (± 0.008) 3.13" 1 to 30A 450 to 600A 11.63" (± 0.094) 5.5" (± 0.031) 2.59" 1.06" (± 0.008) 35 to 60A 225 to 400A 9.63" (± 0.062) 7.9" (± 0.062) 1.84" 1.34" 110 to 200A 70 to 100A Features • Protect lighting, heating and other circuits not subject to temporary surges and where available short-circuit currents are relatively low • NOS one-time fuses do not have any appreciable degree of timedelay and thus should not be specified in circuits where large transients or motor overloads occur. Use Bussmann series advanced protection FUSETRON FRS-R or ultimate protection Low-Peak LPS-RK dual-element, time-delay fuses. • For general purpose circuits, size at amp rating of circuit • For motor circuits, size at 300% to 400% according to the NEC® motor ampacity tables 430.247 to 430.250, per 430.6(A)(1) Description Basic protection 600 V NOS Class K5 and H general purpose, noncurrent-limiting, one-time fuses. Catalog symbol • NOS-(amp) Ratings • Volts 600 Vac • Amps 1-600 A • IR Recommended fuse blocks • 50 kA Vac RMS Sym. (1-60 A) • 10 kA Vac RMS Sym. (70-600 A) 1-, 2- and 3-pole modular fuse blocks up to 600 amps — see data sheet no. 10487 • 1-, 2- and 3-pole modular power distribution fuse blocks up to 60 amps — see data sheet no. 10490 Fuse reducers for Class R fuses Agency information • UL Listed, Class K5 (1-60 A), Std. 248-9, Class H (70-600 A), Std. 248-6, UL Guide JDDZ, File E4273 • CSA Certified, Class 1421-01, File 53787 • CE Catalog Numbers (amps) NOS-1 NOS-9 NOS-2 NOS-10 NOS-3 NOS-12 NOS-4 NOS-15 NOS-5 NOS-20 NOS-6 NOS-25 NOS-7 NOS-30 NOS-8 NOS-35 • Equipment fuse clips 60 A 100 A 200 A NOS-40 NOS-45 NOS-50 NOS-60 NOS-70 NOS-75 NOS-80 NOS-90 NOS-100 NOS-110 NOS-125 NOS-150 NOS-175 NOS-200 NOS-225 NOS-250 NOS-300 NOS-350 NOS-400 NOS-450 NOS-500 NOS-600 400 A 600 A Desired fuse (case) size 30 A 30 A 60 A 60 A 100 A 100 A 200 A 100 A 200 A 400 A Catalog no. (pairs) 600V NO.663 NO.216 NO.616 NO.626 NO.2621 NO.2641† NO.2642 NO.2661† NO.2662† NO.2664† † Not CSA certified. For additional information on Class R fuse reducers, see data sheet no 1118. Carton Quantity Amps 1–60 70–100 110–600 Qty. 10 5 1 Eaton.com/bussmannseries 3 Technical Data 1030 250 V NON/600 V NOS Class K5 and H fuses Effective June 2017 600A 400A 200A 100A 60A 30A 35A 300 15A 20A NOS time-current curves — average melt AMP RATING 100 TIME IN SECONDS 10 1 0.1 0.08 0.06 0.04 0.03 CURRENT IN AMPS 10,000 1000 20 0.01 100 0.02 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 1030 — BU-SB13738 June 2017 Eaton.com/bussmannseries Eaton, Bussmann, Low-Peak and Fusetron are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. NEC is a registered trademark of the National Fire Protection Association. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Eaton: NON-7 NON-70 NOS-6 NON-125 NOS-300 NOS-125 NON-600 NON-500 NOS-250 NON-8 NOS-100 NOS-35 NOS-70 NOS-1 NOS-350 NOS-40 NON-35 NON-12 NOS-110 NON-175 NON-1-1/2 NON-15 NOS-450 NOS175 NOS-5 NOS-50 NOS-600 NON-300 NON-20 NOS-9 NON-4 NON-350 NOS-90 NON-450 NOS-4 NOS-80 NON-1 NOS-7 NOS-25 NOS-500 NON-25 NON-250 NOS-10 NOS-150 NON-2-1/2 NON-80 NOS-400 NON-5 NON-110 NON-3/4 NON-6 NOS-2 NON-225 NON-30 NON-90 NOS-30 NOS-12 NOS-3 NON-45 NOS-8 NOS45 NON-400 NON-1/8 NOS-225 NOS-200 BP/NON-15 BP/NON-30 BP/NON-100 BP/NON-50 BK/NON-30 BP/NON-20 BP/NON-35 BK/NON-60 BP/NON-40 BP/NON-60 BP/NON-45 BP/NON-25 NON-9 SP/NOS-90
SP/NOS-90 价格&库存
很抱歉,暂时无法提供与“SP/NOS-90”相匹配的价格&库存,您可以联系我们找货
SP/NOS-90
  • 5+1721.278805+223.33450
