12338
12338
    GREENLEECOMMUNICATIONS(格林利)
12338 数据手册
PUNCH UNT-15/16" (POP) Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 12338 UPC No: 783310123385 Description • • • • • • "The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52"" (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster " Specifications • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 14 GA (2.000 MM) Includes : Punch, Die And Draw Stud Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers Replacement Part : 12340 UPC 12340 Punch, 12339 UPC 12339 Die And 00042 UPC 00042 Draw Stud Size : 15/16 IN (23.800 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 0.500 LB (253.000 GM)
12338 价格&库存
很抱歉,暂时无法提供与“12338”相匹配的价格&库存,您可以联系我们找货
