PUNCH UNT (7211-E-BB) 28.3MM (3/8"D/S)
Slug-Buster Knockout Punches 0.492 to 2.520
Cat No:
7211EBB-28.3
UPC No:
783310319931
Description
The contractor's choice - worldwide
Unique punch profile also splits slugs for easier slug removal
Use with battery-powered, hydraulic, ratchet or manual drivers
Uses standard Greenlee dies and draw studs
Slug Buster punches available in sizes up thru 2.52 IN (64.0 mm)
U.S.Patent #4,543,722 for Slug-Buster
Specifications
Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic
Capacity Mild Steel : 14 GA (2.000 MM)
Includes : Punch, Die And Draw Stud
PG : 21
Replacement Part : 31973 UPC 31973 Punch, 32006 UPC 32006 Die And 00042 UPC 00042
Draw Stud
Size : 1.115 IN (28.300 MM)
Sub Brand : Slug-Buster
Type : Knockout
Weight : 0.500 LB (227.000 GM)
很抱歉,暂时无法提供与“7211EBB-28.3”相匹配的价格&库存,您可以联系我们找货
