BIT, STEP #3 (PKGD).
7/8 Multi-Hole Step Bit
Cat No:
34403
UPC No:
783310344032
Description
Unique split-tip design penetrates through steel faster
Resists walking or skidding, even on round surfaces
Balanced, double-flute construction requires less pressure, does the work for you
Designed and manufactured in USA
Specifications
Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic
and Laminates
Hole Size : 13/16 IN (4.800 MM), 1/4 IN (6.400 MM), 5/16 IN (7.900 MM), 3/8 IN (9.500 MM), 7/16
IN (11.100 MM), 1/2 IN (12.700 MM), 9/16 IN (14.300 MM), 5/8 IN (15.900 MM), 11/16 IN (17.500
MM), 3/4 IN (19.100 MM), 13/16 IN (20.600 MM)
Maximum Material Thickness : 10 GA (3.500 MM)
Minimum Chuck Size : 3/8 IN (9.500 MM)
Overall Length : 3-9/16 IN (90.500 MM)
Sub Brand : Kwik Stepper
Type : Multi Hole
很抱歉,暂时无法提供与“34403”相匹配的价格&库存,您可以联系我们找货
