BIT,NAILEATER 1-1/8(1.125) X 18.00(66PT)
Nail Eater Extreme
Cat No:
66PT-1-1/8
UPC No:
783310309352
Description
"Improved cutting edge provides 30% longer life span
Patented new design for improved cutting and cleaner holes
Self-feeding screw point draws bit through wood
Unique patented design cutting angle - smoother starts, reduced cutting loads
Made of super tough, heat-treated steel
cuts through nails and provides longer life
?Shorty"" bits - for working in tight places, yet still can go through three abutting 2 x 4s
See ?Bit Extensions"" if more length is required
P.O.P packaged "
Specifications
Bit Diameter : 1-1/8 IN (28.600 MM)
Material : Heat Treated Steel
Overall Length : 18.000 IN (457.200 MM)
Shank Diameter : 7/16 IN (11.100 MM)
Shank Type : Hexagonal
Sub Brand : Nail Eater
Twist Length : 15.000 IN (381.000 MM)
Type : Extreme
Weight : 2.300 LB (1044.000 GM)
很抱歉,暂时无法提供与“66PT-1-1/8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+833.050921+107.77738
