BIT,STEP #11 (PKGD)
Kwik Stepper® Step Bits
Cat No:
34411
UPC No:
783310344117
Description
Unique split-tip design penetrates through steel faster
Resists walking or skidding, even on round surfaces
Balanced, double-flute construction requires less pressure, does the work for you
Designed and manufactured in USA.
Specifications
Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic
and Laminates
Hole Size : 7/8 IN (22.200 MM)
Maximum Material Thickness : 10 GA (3.500 MM)
Minimum Chuck Size : 3/8 IN (9.500 MM)
Overall Length : 2-1/8 IN (53.8 MM)
Sub Brand : Kwik Stepper
Type : Single Hole
很抱歉,暂时无法提供与“34411”相匹配的价格&库存,您可以联系我们找货
