SR249120D36RNF
SR249120D36RNF
    LAIRD(莱尔德)
    ANT2400-2500/4900-590036"NFE
SR249120D36RNF 数据手册
SR249120D Series 2.4-2.5 / 4.9-5.9 GHz 5 dBi Dual-Band 120° Sector Antenna Innovative Technology for a Connected World DUAL BAND TRI-MODE SECTOR ANTENNA Laird Technologies’ SR249120D dual-band tri-mode antenna offers the system integrator a perfect solution to indoor and outdoor wide area coverage wall-mount applications. While omni-directional antennas are well suited for installations where the antenna has a 360 degree unobstructed view of the coverage area, wall mounting omni-directional antennas can create a number of system performance issues. Because the antenna radiates equally in all directions, much of the power is radiated directly to the wall surface behind the antenna. This causes elements of the wall to become actual components of the antenna, often causing multi-path nulls within the intended coverage area. The SR249120D antenna provides a solution for the most common coverage requirements. Its integrated backplane shields the radiating element from the wall, eliminating any problems from wall construction components. The antenna’s gain makes it a perfect replacement for typical high-performance omni-directional antennas. The result is solid, consistent, and uniform coverage within the intended coverage area. FEATURES • Covers 802.11b/a/g modes of operation • Pattern optimized for wide area directional coverage • Suitable for both indoor and outdoor applications direct to radio mounting • Wide range of connector type and cable length options available global solutions: local support Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +1.32.80.7866.12 IAS-EUSales@lairdtech.com Asia: +1.65.6.243.8022 IAS-AsiaSales@lairdtech.com www.lairdtech.com TM MARKETS • • • • • • Healthcare centers Campus Warehouses Business parks Transport concourses Retail malls SR249120D Series 2.4-2.5 / 4.9-5.9 GHz 5 dBi Dual-Band 120° Sector Antenna Innovative Technology for a Connected World SPECIFICATIONS PARAMETER 350 0 10 20 30 320 Part Number SR249120D Frequency (GHz) 2.4-2.5 GHz; 4.9-5.9 Gain (dBi) 340 330 40 310 50 300 60 290 5 70 280 3 dB Beamwidth-Azimuth 120° 3 dB Beamwidth-Elevation 65° Polarization Vertical Linear VSWR 2.0:1 Cable Length (mm) 304 Ultralink RG-58 RF Connector N (m) Power Rating 5W Dimensions (mm) 1.38”x 2.16”x 5.16” (35 x 55 x 131) 80 270 -30 -20 90 -10 dB 260 100 250 110 240 120 230 130 220 140 210 150 200 340 190 350 180 170 0 10 160 20 330 30 320 40 310 Weight .09 kg Enclosure High Strength PC Mount Style Wall / Mast RoHS Compliant 50 300 60 290 70 280 80 270 -30 -20 -10 90 dB 260 100 250 110 240 120 230 130 220 140 210 150 200 340 350 0 10 340 20 330 310 300 290 280 80 -20 -10 90 100 250 110 240 120 230 130 140 150 global solutions: local support 190 180 170 20 30 40 50 60 70 280 80 270 -30 -20 -10 dB 260 200 10 290 70 210 0 300 60 220 350 160 310 50 -30 170 320 40 270 180 330 30 320 190 160 90 dB 260 100 250 110 240 120 230 130 220 140 210 150 200 190 180 170 160 TM Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +1.32.80.7866.12 IAS-EUSales@lairdtech.com Asia: +1.65.6.243.8022 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-SR249120D 0509 Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. All Laird Technologies’ products are sold pursuant to the Laird Technologies’ terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. © 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc
SR249120D36RNF 价格&库存
很抱歉,暂时无法提供与“SR249120D36RNF”相匹配的价格&库存,您可以联系我们找货
