35714
35714
    GREENLEECOMMUNICATIONS(格林利)
    PUMP ONLY TAKE-ALONG LOCK SS 8OZ
35714 数据手册
HOLESAW,LIGHT 6-5/8 STEEL TOOTH Steel Toothed Cat No: 35714 UPC No: 783310357148 Description • • • • • • Industry's only interchangeable replacement bladeS Strong durable back plate Available in two styles - steel tooth and carbide grit Made and designed in USA by Greenlee Use with a power drill to cut large diameter holes for recessed lighting fixtures Saws use Greenlee arbor 37156, purchased separately Specifications • • • • • • • Application : For Use With A Power Drill ToCut Large Diameter Holes For Recessed Lighting Fixtures, Use For Juno And Progress Hole Diameter : 6-5/8 IN Material : Steel Maximum Capacity : Steel Toothed Blade - Up To 7/8 IN Plywood, Wood, Acoustical Tile And Ceiling Tile Replacement Part : 35722 Blade for 35714 Type : Recessed Light Use With Standard Arbor No. : 37156
35714 价格&库存
很抱歉,暂时无法提供与“35714”相匹配的价格&库存,您可以联系我们找货
