HOLESAW,LIGHT 6-3/8 STEEL TOOTH
Steel Toothed
Cat No:
35713
UPC No:
783310357131
Description
Industry's only interchangeable replacement bladeS
Strong durable back plate
Available in two styles - steel tooth and carbide grit
Made and designed in USA by Greenlee
Use with a power drill to cut large diameter holes for recessed lighting fixtures
Saws use Greenlee arbor 37156, purchased separately
Specifications
Application : For Use With A Power Drill ToCut Large Diameter Holes For Recessed Lighting
Fixtures, Use For Halo And Capri
Hole Diameter : 6-3/8 IN
Material : Steel
Maximum Capacity : Steel Toothed Blade - Up To 7/8 IN Plywood, Wood, Acoustical Tile And
Ceiling Tile
Replacement Part : 35721 Blade for 35713
Type : Recessed Light
Use With Standard Arbor No. : 37156
很抱歉,暂时无法提供与“35713”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+717.530401+93.00560
