35728
35728
    GREENLEECOMMUNICATIONS(格林利)
    BLADESTEEL5-3/8
35728 数据手册
BLADE,STEEL 5-3/8 (POP) Steel Toothed Cat No: 35728 UPC No: 783310357285 Description • • • • • • Industry's only interchangeable replacement bladeS Strong durable back plate Available in two styles - steel tooth and carbide grit Made and designed in USA by Greenlee Use with a power drill to cut large diameter holes for recessed lighting fixtures Saws use Greenlee arbor 37156, purchased separately Specifications • • • • • • Application : "Use For Capri, Juno, Lightolier, Progress, And Precolite, Use With A Power Drill To Cut Large Diameter Holes For Recessed Lighting Fixtures " Capacity : Up To 7/8 IN (22.200 MM) Plywood, Wood, Acoustical Tile AndCeiling Tile Material : Steel Blade Replacement Part : 35730 Blade for 35728 Size : 5-3/8 IN (137.000 MM) Diameter Weight : 0.980 LB (0.440 KG)
35728 价格&库存
很抱歉,暂时无法提供与“35728”相匹配的价格&库存,您可以联系我们找货
