BFW-50
BFW-50
    EATON(伊顿)
    BFW-50
BFW-50 数据手册
Bussmann® Plug Fuses Type W Fast-Acting 125 Volts, 1/2–12 Amps • Fast-Acting Plug Fuse. • For lighting, heating or other circuits that do not contain electric motors. • Edison base size. • These fuses thread into fuse receptacles. • The General Purpose (W) fuse has no time-delay feature and should not be used in circuits that contain motors. 10 AMPERE RATING 100 Electrical Ratings (Catalog Symbol and Amperes) 125V W-1/2 W-5 W-1 W-6 W-1-8/10 W-6-1/2 W-2 W-7 W-2-1/2 W-8 W-3 W-10 W-4 W-12 TIME IN SECONDS 10 Package Quantity and Weight Weight Per 5 Cards 1 0.96 1.20 W-15, W-20, W-25, and W-30 Plug Fuses Obsoleted Suggest Replacing with either T-(Amp) or TL-(Amp) Plug Fuses Both the T and TL Series plug fuses offer similar short circuit protection to the W Series plug fuses. In addition, the T and TL Series plug fuses offer time-delay performance for overload currents (typically between one and six times the rated current of the fuse). For most applications, this feature is preferred to allow harmless inrush currents to pass without causing the fuse to open unnecessarily. The TL Series plug fuses (Data Sheet: 1035) utilize a loaded link construction and provide medium-duty performance. The T Series plug fuses (Data Sheet: 1034) utilize the advanced dual-element design for heavy-duty performance. This construction makes the T Series the preferred selection. For additional information, please see the applicable Data Sheets. .1 .01 200 Per Box 4 100 Card 10 Box 1. Quantity Ratings 1 .4 Ampere 15, 20, 25, & 30A 6 1 Catalog ssymbol: W Fast-Acting 1/2 To 30A 125Vac or less UL Listed (Guide #JEFV, File # E12112) 3 Time-Current Characteristics–Total Clear CURRENT IN AMPERES The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this Data Sheet are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 6-11-03 SB03177 Form No.Type W Page 1 of 1 Data Sheet: 1036 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Eaton: BFW-30 BFW-40 BFW-25 BFW-3 BFW-1/2 BFW-15 BFW-1/4 BFW-20 BFW-5 BFW-4 BFW-60 BFW-6 BFW10 BFW-1-1/2 BFW-2 BFW-1 BFW-50 BFW-80 BFW-8 BFW-3/4
BFW-50 价格&库存
很抱歉,暂时无法提供与“BFW-50”相匹配的价格&库存,您可以联系我们找货
