Flexibility and Convenience Make
Point-of-Use Configuration Easy
Full range of open disconnect
switches with versatile options
and accessories that ship within
24 hours
• Most disconnect switches can be operated with a front,
side, flange or direct mount handle mechanism for
increased flexibility and reduced inventory
• Easy-to-install accessories make it simple to configure
each disconnect switch for the desired application
• Most common parts in stock and ship within 24 hours with
QuikShip Everyday Service to meet project requirements
• Double break feature on all fused disconnect switches
helps ensure complete fuse isolation and reduces hazards
to personnel
• UL 98 Listed for main disconnect, branch circuit
protection or service entrance and UL 508 Listed for motor
disconnect applications
For more information visit www.cooperbussmann.com/Disconnects
Description:
Fused and non-fused open Rotary Disconnect Switches from
16 to 1200A
Ratings:
Volts: 600Vac
250-600Vdc*
Amps: 16-1200A
Short-Circuit Current Ratings: UL 98: 25kA-200kA
UL 489: 100kA
UL 508: 10kA-65kA
Specifications:
Operating temperature: -20ºC to 70ºC
Flammability rating: UL 94-V0
Mounting:
• Panel mount: All
• DIN-Rail mount: All UL 508, UL 98 compact fused
30A-60A, UL 98 non-fused compact 30A-100A
• Door mount: All UL 508 with accessory mounting kit
Agency Information: (Disconnect Switches)
UL 98 Listed: File E155130, Guide WHTY, WHTY7
UL 489 Listed: File E359801, Guide WJAZ, WJAZ7
UL 508 Listed: File E155129, Guide NLRV, NLRV7
CSA Certified 257020
Complies with IEC 60947-3
CE Compliant
RoHS Compliant
Product Features and Benefits:
• UL 508 Listed for motor disconnect applications up to 600Vac
• UL 98 Listed for general purpose, main disconnect, branch
circuit protection or service entrance up to 600Vac/dc
side, flange or direct mount handle mechanisms for
• Easy-to-install modular accessories make it simple to
configure each disconnect switch for the desired application
• SCCR options allow users to select a disconnect switch
with SCCR that best suits the application
• Lockout/tagout: Up to three 1⁄4 ˝ padlocks on external
handles. Most disconnect switches also provide an
on-switch lockout point for additional flexibility
• Finger-safe with terminal shroud accessories
• Endurance tested at or beyond the stringent levels of the
UL standards to ensure durability
Accessories†:
• Pistol, selector, direct and
flange handles
• Shafts for external handles
• Auxiliary contacts
Rotary Disconnect Switch Catalog for more information about available
accessories.
†See
*Some non-fused disconnect switches are not rated for DC applications. See
Rotary Disconnect Switch Catalog for more information.
UL 98 Non-Fused Disconnect Switches
Rating (A)
UL 98 & UL 489 Fused Disconnect Switches
Rating (A)
Fuse Class
Compact
30A
CC
Compact
30A
J
No. of
Poles
Part
Number
3
RDF30CC-3
4**
RDF30CC-3N
3
RDF30J-3-COMP
4**
RDF30J-3N-COMP
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
RDF30J-2
RDF30J-3
RDF30J-4
RDF60J-2-COMP
RDF60J-3-COMP
RDF60J-4-COMP
RDF60J-2
RDF60J-3
RDF60J-4
RDF100J-2
RDF100J-3
RDF100J-4
RDF200J-2
RDF200J-3
RDF200J-4
RDF400J-2
RDF400J-3
RDF400J-4
RDF600J-2
RDF600J-3
RDF600J-4
RDF800L-2
RDF800L-3
RDF800L-4
30A
J
Compact
60A
J
60A
J
100A
J
200A
J
400A
J
600A
J
800A
L
**3-Poles and switched neutral pole.
© 2013 Cooper Bussmann
Reorder # 10048
0313
2.5M
• Terminal shrouds
• 4th Switched poles
• Terminal lugs
• Door mounting kits
SCCR
Compact 30A
Compact 60A
Compact 100A
100A
200A
100kA
400A
600A
200kA
800A
1000A
100kA
1200A
No. of
Poles
3
3
3
3
3
4
3
4
3
4
3
4
3
4
3
4
Part
Number
RD30-3
RD60-3
RD100-3
RD100-3-SCCR
RD200-3
RD200-4
RD400-3
RD400-4
RD600-3
RD600-4
RD800-3
RD800-4
RD1000-3
RD1000-4
RD1200-3
RD1200-4
SCCR
100kA
25kA
200kA
100kA
UL 508 Non-Fused Disconnect Switches
200kA
Rating (A)
No. of
Poles
Part
Number
16A
25A
3
3
RD16-3-508
RD25-3-508
40A
3
RD40-3-508
63A
3
RD63-3-508
80A
3
RD80-3-508
SCCR with Max
Upstream
Class J Fuse
65kA / 30A
65kA / 30A
65kA / 30A
10kA / 60A
65kA / 30A
50kA / 100A
65kA / 60A
50kA / 100A
很抱歉,暂时无法提供与“RD30-3”相匹配的价格&库存,您可以联系我们找货
