OPM-1038R
OPM-1038R
    EATON(伊顿)
    OPM-1038R
OPM-1038R 数据手册
Bussmann® OPTIMA™ OPM-1038 Overcurrent Protection Module - Fuseholder for ⁄‹Ω£™∑ ≈ 1⁄Ω™∑ (10mm ≈ 38mm) Fuses Non-Switch Series Physical Characteristics: • Small size matches 45mm IEC starter width. • Fits #8-18 AWG stranded wire, #10-18 AWG solid wire. • 3-pole version. Product Features: • “Open” fuse indication lights. (Min. 100V required) • Cam action handle for easy removal. • Finger safe terminals. (Qualified as IP2O per IEC529) • Removable module for convenient fuse loading. • 35mm DIN-rail or screw panel mounting (#8 screw, 1⁄Ω¢∑ long). • Dead front construction. Catalog Symbol: Series O P M - 1 0 3 Fuse Type Communication Blank - 10 x 38mm C - Communication Feature 8 or 13/32” x 1-1/2” R - Class CC Additional Features: • Option for remote “open fuse” status indication feature available (less down-time). • Offered with Class CC rejection clips or European 10mm ≈ 38mm clips to meet global needs. • Wire ready: Saves time as terminals are ready to accept wires. Materials: Grey Thermoplastic UL Flammability: UL 94VO Agency Information: UL - see table below CSA Certified: C22.2 No. 39, Class 6225-01, File 47235 IEC - see table below Shipping Weight: Approx. 213g (.47 lb.) Carton Quantity: 1 Catalog Number OPM-1038 OPM-1038R Electrical Rating SC Rating Clips 30A, 600V UL/CSA** * Non-rejection, (Max. 3 Watts per fuse) 10 x 38mm or 32A, 660V IEC 13/32” x 1-1/2” 30A, 600V UL/CSA** OPM-1038C 200kA 30A, 600V UL/CSA** OPM-1038RC * Non-rejection, Yes 32A, 660V IEC 13/32” x 1-1/2” *Rating varies depending on fuse used in module. **DC Voltage Rating: 600V UL/CSA Recommended Fuse Types: Class CC Midget (non-rejection) LP-CC KTK KTK-R FNM FNQ-R FNQ 1-23-04 No 10 x 38mm or 200kA SB04028 No Rejection, Class CC (Max. 3 Watts per fuse) 30A, 600V UL/CSA** Remote Open Fuse Indication Rejection, Class CC Yes UL Information Std. File Guide IEC Recognized UL 512 E14853 IZLT2 Listed UL 512 E14853 IZLT UL 512 E14853 IZLT2 Listed UL 512 E14853 IZLT IEC 269-2-1 Recognized IEC 269-2-1 CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Applies to OPM-1038 and OPM-1038R. Form No. OPM-1038 Non-Switch Series Page 1 of 3 Data Sheet: 1102 Bussmann® OPTIMA™ OPM-1038 Overcurrent Protection Module - Fuseholder for ⁄‹Ω£™∑ ≈ 1⁄Ω™∑ (10mm ≈ 38mm) Fuses Non-Switch Series 3.22∑ (± .03) (81.8mm) (± .76) Dimensional Data 2T1 BUSS 4T2 1.76∑ (± .03) (44.7mm) (± .7 ) 6T3 IL1 Communication Port 3L2 .27∑ (6.9mm) 5L3 .74∑ (18.8mm) .31∑ (7.9mm) 3.60∑ (± .03) (91.4mm) (± .76) .57∑ (14.5mm) 3.74∑ (± .03) (95.0mm) (± .76) 1.65∑ (± .03) (41.9mm) (±. 76) 3.17∑ (80.5mm) Communication Port 0.23∑ (5.8mm) .50∑ (12.7mm) .44∑ (11.2mm) .224" (5.6mm) 1.312∑ (± .01) (33.3mm) (± .25) Panel Mount Hole Pattern 3.60∑ (± .03) (91.4mm) (± .76) 1.86∑ (± .03) (47.2mm) (± .76) Panel Mount Hole Pattern Spare Fuseholder: Part No. 5TPH 2.98∑ (75.6mm) 1.03∑ (26.2mm) SPARE FUSE HOLDER BODY DOUBLE SIDED ADHESIVE TAPE .63∑ (15.9mm) 1-23-04 SB04028 Form No. OPM-1038 Non-Switch Series Page 2 of 3 Data Sheet: 1102 Bussmann® OPTIMA™ OPM-1038 Overcurrent Protection Module - Fuseholder for ⁄‹Ω£™∑ ≈ 1⁄Ω™∑ (10mm ≈ 38mm) Fuses Non-Switch Series OPEN FUSE INDICATION Status Output Specifications: *Minimum operating voltage: 460Vac, 3-phase *Maximum operating voltage: 620Vac, 3-phase Status output maximum conducting current: 40mA Status output maximum on resistance: 35 ohms @ 40mA Status output typical off resistance: >10 Mohm Status output maximum turn-on and turn-off delay: 850 milli-second Status Output Interface Specifications: Rated Voltage: Recommended 5-35Vdc, 300Vac max. Rated Current: 40mA max. Wire Size: #28-14 AWG Torque: 2.25 lb. in. Open Fuse Indicator Status Output Description: The open fuse indicator status output acts very much like an on/off switch. With all three fuses in place and operating properly, this status output has a high resistance value of greater than ten mega-ohms. When one or more of the fuses are open, the status output becomes turned-on with a resistance value less than 35 ohms. This status output withstands voltage (AC or DC) up to 35 volts at off-state and conducts current up to 40 milli-amps at on-state. Applying voltage and current exceeding these limits will result in damage to the components inside this status output device permanently. There is some time-delay when the status output changes on/off state. The open fuse communications or status output device includes optical isolators within the unit. Communications output states: Fuse Good NO - High Resistance, >10 mega-ohms Opened Fuse NC - Low Resistance, < 35 ohms Note: Operating this device beyond the above limits will cause permanent damage to the components on the board. For applications requiring status output below a system voltage of 460V, contact Bussmann. The examples shown below illustrate typical interface to Programmable Logic Controllers. EXAMPLE 1: DIRECT INTERFACE TO PC/PLC PC / PLC STATUS OUTPUT Vcc (5V to 35V) TTL Digital Input Pull up Resistor (> 1K) EXAMPLE 2: INTERFACE TO PC / PLC WITH OPTICAL ISOLATION PC / PLC STATUS OUTPUT Vcc (5V to 35V) Optical Isolator TTL Digital Input Pull up Resistor (> 1K) CurrentLimiting Resistor ISOLATED AC OR DC POWER SOURCE Note: When energized, a low load terminal voltage will be present when fuses are open or when pullout module is removed. The leakage current is limited to .5mA maximum. Example of Output Voltage with three open fuses or pullout module removed. Catalog Number OPM-1038, OPM-1038R OPM-1038C, OPM-1038RC Type of Indication Standard Communication System Voltage Load Terminal Voltage (1L1-3L2-5L3) (2T1-4T2-6T3) 125Vdc * 12Vdc * 31Vdc * 480Vac, 3-phase 26Vac 56Vac 600Vac, 3-phase 33Vac 88Vac *The communication device requires a minimum circuit voltage (1L1-3L2-5L3) of 460 volts for the status indicating device to operate. Below 460 volts, but above 120 volts the indicator lights will luminate, but there will not be any communication status output. The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 1-23-04 SB04028 Form No. OPM-1038 Non-Switch Series Page 3 of 3 Data Sheet: 1102
OPM-1038R 价格&库存
很抱歉,暂时无法提供与“OPM-1038R”相匹配的价格&库存,您可以联系我们找货
