WCC1138
WCC1138
    CROUZET(高诺斯)
WCC1138 数据手册
 5 Igniters Auburn Sales Symbol Center Electrode Material SKU Thread I-2 I-2-1 12944 12946 1/2-14 NPT 1/2-14 NPT Nickel Nickel 7/8 7/8 I-2-2 12948 1/2-14 NPT Nickel I-2-EI-2 13137 1/2-14 NPT Nickel I-2 with 48-13/16" c/w I-3 13881 12987 1/2-14 NPT 14mm x 1.25mm Nickel Nickel Auburn Sales Symbol SKU Thread I-64-1 I-64-3 12958 12959 1/2-14 NPT 1/2-14 NPT 7/8 I-64-4 12963 7/8 I-67 12962 7/8 13/16 I-75-4 I-75-5 13332 12949 HEX Center Electrode Material HEX Nickel Nickel 7/8 7/8 1/2-14 NPT Nickel 7/8 18MM X 1.5MM 304 SS 7/8 1/4-20 NEF 1/4-20 NEF Nickel Nickel 15/16 15/16 I-5-99 13008 1/2-14 NPT Nickel 15/16 I-75-6 13211 3/4-20 NEF-2 Nickel 15/16 I-5-99 with 48" c/w I-6 13309 12954 1/2-14 NPT 1/2-14 NPT Nickel Nickel 15/16 7/8 I-78 I-78-2 12998 12995 7/8-18 NPT 7/8-14 NPT Nickel Nickel 15/16 15/16 I-6 SP with 24" c/w 13779 1/2-14 NPT Nickel 7/8 I-82 12960 No Thread Kanthal no HEX I-6 with 45" c/w 13827 1/2-14 NPT Nickel 7/8 I-90-3 13011 3/4-14 NPT Nickel 1 1/8 IA-9 IA-9-C 12967 13345 13/16-24 13/16-24 Nickel Nickel 13/16 13/16 I-90-6 I-90-7 13015 13016 3/4-14 NPT 3/4-14 NPT Nickel Nickel 1 1/8 1 1/8 IC-9-2 12965 7/8-18 NPT Nickel 1.125 I-90-8 13018 3/4-14 NPT Nickel 1 1/8 IC-9-4 I-10-25 13344 12986 7/8-18 NPT 1/2" Inconel Nickel 1.125 13/16 I-96-1 I-96-3 13536 13529 No Thread No Thread Nickel Nickel no HEX no HEX IC-10 12973 7/18-18 Nickel 1 1/8 I-101 12982 10mm x 1mm Nickel 11/16 IA-15-1 12978 13/16-24 Nickel 13/16 I-102 12983 10mm x 1mm - SAE Nickel 11/16 IC-15 IC-15-3B 12976 12979 7/8-18 NPT 7/8-18 NPT Nickel Nickel 1.125 1.125 I-143 I-144 12999 13000 14mm x 1.25mm - SAE 14mm x 1.25mm - SAE Kanthal Kanthal 13/16 13/16 IP-16 13004 1/2-14 NPT Nickel 15/16 I-147-2 14305 14mm x 1.25mm - SAE Kanthal 13/18 IP-16-EI IP-17 13124 13005 1/2-14 NPT 1/2-14 NPT Nickel Nickel 15/16 15/16 I-181 I-182 12996 13270 18mm x 1.5mm 18mm x 1.5mm Nickel Nickel 7/8 7/8 I-182-1 12997 18mm x 1.5mm Nickel 7/8 I-18 12969 1/2 - 14NPT Nickel 15/16 I-18-14 12970 13/16-24 NEF Nickel 15/16 I-18-16 I-18K 13218 12972 N/A 1/2-14 NPT Inconel Kanthal N/A 15/16 IP-19 13006 1/2-14 NPT Nickel 15/16 OJ-21-1 OJ-21-4 13001 13002 14MM X 1.25MM 14MM X 1.25MM Nickel Nickel 13/16 13/16 OJ-21-5 13003 14MM X 1.25MM Nickel 13/16 I-25 12951 1/2-14 NPT Nickel 7/8 I-25-3 I-25 LNG (4.550) 13206 13148 1/2-14 NPT 1/2-14 NPT Nickel Nickel 7/8 7/8 I-28 12952 18mm x 1.5mm Nickel 7/8 I-31 I-31-1 12989 12990 14mm x 1.25mm 14mm x 1.25mm Nickel Nickel 13/16 13/16 I-31-2 13238 14mm x 1.25mm Nickel 13/16 I-31-3 12991 14mm x 1.25mm Inconel 13/16 I-31-5-3.3 I-31-6 13122 13169 14mm x 1.25mm 14mm x 1.25mm Nickel Nickel 13/16 13/16 I-32 12992 14mm x 1.25mm Nickel 13/16 I-33 I-33 SP with 18" c/w 12988 13781 14mm x 1.25mm 14mm x 1.25mm Nickel Nickel 13/16 13/16 I-33 SP with 6" c/w 13795 14mm x 1.25mm Nickel 13/16 I-33 SP with 4.5" c/w 13776 14mm x 1.25mm Nickel 13/16 I-63 12956 18MM X 1.5MM Nickel 7/8 Shielded Igniters 6 SI-140 13019 14MM X 1.25MM Nickel 13/16 SI-140-1NM 13380 14MM X 1.25MM Nickel 13/16 SI-141 13020 14MM X 1.25MM Nickel 3/16 SI-180 SI-180RH 13023 13414 18MM X 1.5MM 18MM X 1.5MM Nickel Nickel 7/8 7/8 SI-183-1 13397 18MM X 1.5MM Nickel 7/8 SI-185 SI-186 13025 13026 18MM X 1.5MM 18MM X 1.5MM Nickel Nickel 7/8 7/8 SI-187 13027 18MM X 1.5MM Nickel 7/8 SI-188 13028 18MM X 1.5MM Nickel 7/8 SI-230 SI-322 13029 13032 Special 18MM X 1.5MM Nickel Nickel 15/16 7/8 SI-323 13399 18MM X 1.5MM Inconel 7/8 SI-324 SI-328-2 13401 13407 18MM X 1.5MM-SAE 18MM X 1.5MM-SAE Inconel Chromel 7/8 1" SI-346 13022 14MM X 1.25MM Nickel 13/16 Igniters I-2 I-3 I-2-EI-2 I-5-99 7 Igniters I-6 I-10-25 IA-9 IA-15-1 8 Igniters IP-17 IP-19 I-18 OJ-21-4 9 Igniters I-25 I-31 I-28 I-31-1 10 Igniters I-33 I-67 I-64-1 I-75-4 11 Igniters I-75-5 I-82 I-78-2 I-90 12 Igniters I-101/I-102 I-144 SI-140 I-147-2 13 Igniters 149T-1 I-181 SI-180 SI-185 14 Igniters SI-186 IG-4765 SI-323 15  16 Flame Rods Auburn Sales Symbol FRS-2-12 FRS-2-18 FRS-2-24 FRS-2-6 FRS-3 FRS-4-12 FRS-4-24 FRS-4-4 FRS-4-6 FRS-4-7.5 FRS-4 with 48"c/w FRS-5 FRS-5 with 64" c/w FRS-9 Probe Length "A" (inches) SKU Thread 12 18 24 6 3 12 24 4 6 8 48 28 64 9 13035 13037 13038 13034 13044 13041 13043 13039 13040 13117 13848 13045 13313 13316 1/2 NPT 1/2 NPT 1/2 NPT 1/2 NPT 1/2-14 NPT 1/4-18 NPT 1/4-18 NPT 1/4-18 NPT 1/4-18 NPT 1/4-18 NPT 1/4-18 NPT 1/2 NPT 1/2 NPT 10mm x 1mm SAE 18 Center Electrode Material Kanthal Kanthal Kanthal Kanthal Nichrome Kanthal Kanthal Kanthal Kanthal Kanthal Kanthal Kanthal Stainless Steel Stainless Steel Operating Temperature 2350ʹF 2350ʹF 2350ʹF 2350ʹF 2100ʹF 2350ʹF 2350ʹF 2350ʹF 2350ʹF 2350ʹF 2350ʹF 2350ʹF 1500ʹF 1500ʹF Flame Rods FRS-2 FRS-4 FRS-3 FRS-5 19 Flame Rods FRS-9 20 21 Liquid Level Sensors Alumina Insulation WCC Series Metal parts are 300 series non-magnetic stainless steel. Teflon insulation and seals are for applications up to 1,000 psi at 70Degrees F. and 400 deg F at 1 atmosphere, and will maintain their insulating properties when subjected to many corressive chemicals. Auburn Sales Symbol SKU HEX WCC-12 WCC-12-1 WCC-1112 WCC-1112-3 WCC-1138 WCC-1138-3 WCC-1138L 13095 13099 13097 13583 13096 13100 14450 13/16 13/16 7/8 7/8 13/16 7/8 13/16 Thread 5/8-24 NEF 5/8-24 NEF -3 1/2-14 NPT 1/2-14 NPT 3/8-18 PTF Short 3/8-18 PTF Short 3/8-18 PTF Short Alumina Insulation WCC (KH) Series Metal parts are 300 series non-magnetic stainless steel. These control electrodes, with special insulator tip seals nad glass-sealed solid kovar center wire, are for applications up to 2500 PSI at 70ʹF and 450ʹF at 1 atmosphere. Auburn Sales Symbol SKU HEX WCC-12-1KH WCC-12KH WCC-12K UC WCC-1112KH 13104 13101 13369 13103 13/16 13/16 13/16 7/8 Thread 5/8-24 NEF -3 5/8-24 NEF 5/8-24 NEF 1/2-14 NPT Teflon Insulation and seals WCT Series WCT Series liquid level control electrodes are rated at 20 amperes at 250 volts, and can be used in steam applications up to 100 PSI at 337 deg F. Auburn Sales Symbol SKU HEX WCT-2 13092 13/16 WCT-90 WCT-90-2 WCT-912 WCT-938 13085 13089 13087 13086 13/16 13/16 7/8 13/16 WCTL-3814 13091 13/16 WCTL-38141S 13364 13/16 22 Thread 1-11 1/2 PTF-SAE DHORT 5/8-24 NEF-2 5/8-24 NEF-2 1/2-14 NPT 3/8-18 PTF-SAE SHORT 3/8-18 PTF-SAE SHORT 3/8-18 PTF Short Liquid Level Sensors WCT-2 WCC-12-1KH WCC-12 WCC-12K-UC 23 Liquid Level Sensors WCT-90 WCC-1112 WCT-938 WCC-1112KH 24 Liquid Level Sensors WCC-1138 WCC-3814-1 WCC-1138-3 25  26 Electric Feedthroughs Auburn Sales Symbol SKU Conductor Material Current Rating Amps F-68 F-140 F-150 F200-1 F210-1H F220-1 F220-1B F240LLH F250LLH F-310H F-351 F-610 F-630 F-650-1 F-670-1 F-820 12974 13056 13057 13059 13060 13062 13064 13066 13068 13071 14776 13076 13077 13080 13083 14301 Nickel Kovar Kovar Brass Copper Brass Brass Brass Copper Copper Copper Copper Copper Copper Copper Copper 30 30 30 110 175 105 105 105 175 275 275 750 750 750 750 750 FlashOver voltage (kV) 8 8 8 10 8 8 8 14 14 12 12 8 10 8 10 8 Max. Operating Temperature Deg (F) Thread Mounting Centerwire HEX Overall Length 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 1/2 NPT 3/8-18 Dryseal 5/8-24 NEF-2 3/8-18 Dryseal 3/8-18 Dryseal 5/8-18 NF-2 5/8-18 NF-2 1/2-14 NPT 1/2-14 NPT 3/4-14 NPT 7/8-14 UNF 1-11-1/2 NPT 1-11-1/2 NPT 1 5/8 1-11-1/2 NPT 1 7/8-12 UN-2A 6-32 NC-2 10-24 NC-2 10-24 NC-2 1/4-20 NC-2 1/4-20 NC-2 1/4-20 NC-2 1/4-20 NC-2 1/4-20 NC-2 1/4-20 NC-2 3/8-16 NC-2 3/8-16 NC-2 5/8-11 NC-2 5/8-11 NC-2 5/8-11 NC-2 5/8-11 NC-2 7/8-14 UNF-2A 7/8 13/16 13/16 13/16 13/16 13/16 13/16 7/8 7/8 1 1/8 1 1/8 1 3/8 1 3/8 1 5/16 1 3/8 2 4.28 3.57 3.57 4.45 4.45 4.45 4.20 5.17 5.17 5.23 5.23 5.91 7.68 6.56 8.17 8.37 28 Electric Feedthroughs F-68 F150 F140 F-200-1 29 Electric Feedthroughs F-210-1H F-250LLH F240LLH F-351 30 Electric Feedthroughs F610 F650-1 F-630 F-820 31  32 Observation Ports/Additional Parts Catalogue Number SKU "A" Thread Size 13580 13578 13113 13581 1/2-14 NPT 1/2-14 NPT 3/4-14 NPT 1-11 1/2 NPT "C" Diameter "B" HEX Size Maximum Operating Pressure (PSI) Maximum Operating Temperature Sight Glass P-380 P-500 P-750 P-1000 0.437 0.56 0.75 0.9 Item SKU 1099C Boot Protector Rajah Clip Rajah Clip 90ʹ 13299 13374 13805 13817 0.75 0.875 1.12 1.375 Part Number spring cap 022046 021958 021967 34 350 275 200 150 400ʹ F 400ʹ F 400ʹ F 400ʹ F Observation Ports/Additional Parts P-380 P-750 P-500 P-1000 35 Observation Ports/Additional Parts 1099C 022046 021958 Auburn High Volt 36 Observation Ports/Additional Parts Auburn High Volt Accessories Rajah Clip 2 Liquid Level Sensor Nut Rajah Clip 90 degree 37   © 2011 Federal-Mogul Corporation Southfield, MI 48033 All Rights Reserved. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: WCC1138
WCC1138 价格&库存
很抱歉,暂时无法提供与“WCC1138”相匹配的价格&库存,您可以联系我们找货
WCC1138
