PUNCH UNT-1-3/4" (POP)
Slug-Buster Knockout Punches 0.492 to 2.520
Cat No:
12316
UPC No:
783310123163
Description
"The contractor's choice - worldwide
Unique punch profile also splits slugs for easier slug removal
Use with battery-powered, hydraulic, ratchet or manual drivers
Uses standard Greenlee dies and draw studs
Slug Buster punches available in sizes up thru 2.52"" (64.0 mm)
U.S.Patent #4,543,722 for Slug-Buster "
Specifications
Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic
Capacity Mild Steel : 10 GA (3.500 MM)
Includes : Punch, Die And Draw Stud
Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers
Replacement Part : 12315 UPC 12315 Punch, 12314 UPC 12314 Die And 04040 UPC 04040
Draw Stud
Size : 1-3/4 IN (44.500 MM)
Sub Brand : Slug-Buster
Type : Knockout
Weight : 1.400 LB (661.500 GM)
很抱歉,暂时无法提供与“12316”相匹配的价格&库存,您可以联系我们找货
