RD60-3
RD60-3
    EATON(伊顿)
    RD60-3
RD60-3 数据手册
Flexibility and Convenience Make Point-of-Use Configuration Easy Full range of open disconnect switches with versatile options and accessories that ship within 24 hours • Most disconnect switches can be operated with a front, side, flange or direct mount handle mechanism for increased flexibility and reduced inventory • Easy-to-install accessories make it simple to configure each disconnect switch for the desired application • Most common parts in stock and ship within 24 hours with QuikShip Everyday Service to meet project requirements • Double break feature on all fused disconnect switches helps ensure complete fuse isolation and reduces hazards to personnel • UL 98 Listed for main disconnect, branch circuit protection or service entrance and UL 508 Listed for motor disconnect applications For more information visit www.cooperbussmann.com/Disconnects Description: Fused and non-fused open Rotary Disconnect Switches from 16 to 1200A Ratings: Volts: 600Vac 250-600Vdc* Amps: 16-1200A Short-Circuit Current Ratings: UL 98: 25kA-200kA UL 489: 100kA UL 508: 10kA-65kA Specifications: Operating temperature: -20ºC to 70ºC Flammability rating: UL 94-V0 Mounting: • Panel mount: All • DIN-Rail mount: All UL 508, UL 98 compact fused 30A-60A, UL 98 non-fused compact 30A-100A • Door mount: All UL 508 with accessory mounting kit Agency Information: (Disconnect Switches) UL 98 Listed: File E155130, Guide WHTY, WHTY7 UL 489 Listed: File E359801, Guide WJAZ, WJAZ7 UL 508 Listed: File E155129, Guide NLRV, NLRV7 CSA Certified 257020 Complies with IEC 60947-3 CE Compliant RoHS Compliant Product Features and Benefits: • UL 508 Listed for motor disconnect applications up to 600Vac • UL 98 Listed for general purpose, main disconnect, branch circuit protection or service entrance up to 600Vac/dc • Most disconnect switches can be operated with a front, side, flange or direct mount handle mechanisms for increased flexibility and reduced inventory • Easy-to-install modular accessories make it simple to configure each disconnect switch for the desired application • SCCR options allow users to select a disconnect switch with SCCR that best suits the application • Lockout/tagout: Up to three 1⁄4 ˝ padlocks on external handles. Most disconnect switches also provide an on-switch lockout point for additional flexibility • Finger-safe with terminal shroud accessories • Endurance tested at or beyond the stringent levels of the UL standards to ensure durability • Most common parts in stock and ship within 24 hours with QuikShip Everyday Service to meet project requirements Accessories†: • Pistol, selector, direct and flange handles • Shafts for external handles • Auxiliary contacts Rotary Disconnect Switch Catalog for more information about available accessories. †See *Some non-fused disconnect switches are not rated for DC applications. See Rotary Disconnect Switch Catalog for more information. UL 98 Non-Fused Disconnect Switches Rating (A) UL 98 & UL 489 Fused Disconnect Switches Rating (A) Fuse Class Compact 30A CC Compact 30A J No. of Poles Part Number 3 RDF30CC-3 4** RDF30CC-3N 3 RDF30J-3-COMP 4** RDF30J-3N-COMP 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 RDF30J-2 RDF30J-3 RDF30J-4 RDF60J-2-COMP RDF60J-3-COMP RDF60J-4-COMP RDF60J-2 RDF60J-3 RDF60J-4 RDF100J-2 RDF100J-3 RDF100J-4 RDF200J-2 RDF200J-3 RDF200J-4 RDF400J-2 RDF400J-3 RDF400J-4 RDF600J-2 RDF600J-3 RDF600J-4 RDF800L-2 RDF800L-3 RDF800L-4 30A J Compact 60A J 60A J 100A J 200A J 400A J 600A J 800A L **3-Poles and switched neutral pole. © 2013 Cooper Bussmann www.cooperbussmann.com Reorder # 10048 0313 2.5M • Terminal shrouds • 4th Switched poles • Terminal lugs • Door mounting kits SCCR Compact 30A Compact 60A Compact 100A 100A 200A 100kA 400A 600A 200kA 800A 1000A 100kA 1200A No. of Poles 3 3 3 3 3 4 3 4 3 4 3 4 3 4 3 4 Part Number RD30-3 RD60-3 RD100-3 RD100-3-SCCR RD200-3 RD200-4 RD400-3 RD400-4 RD600-3 RD600-4 RD800-3 RD800-4 RD1000-3 RD1000-4 RD1200-3 RD1200-4 SCCR 100kA 25kA 200kA 100kA UL 508 Non-Fused Disconnect Switches 200kA Rating (A) No. of Poles Part Number 16A 25A 3 3 RD16-3-508 RD25-3-508 40A 3 RD40-3-508 63A 3 RD63-3-508 80A 3 RD80-3-508 SCCR with Max Upstream Class J Fuse 65kA / 30A 65kA / 30A 65kA / 30A 10kA / 60A 65kA / 30A 50kA / 100A 65kA / 60A 50kA / 100A
RD60-3 价格&库存
很抱歉,暂时无法提供与“RD60-3”相匹配的价格&库存,您可以联系我们找货
