36414
36414
    GREENLEECOMMUNICATIONS(格林利)
36414 数据手册
BIT,STEP #14 (PKGD) Kwik Stepper® Step Bits Cat No: 36414 UPC No: 783310364146 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • • • • • Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : 7/8 IN (22.200 MM), 1-1/8 IN (28.600 MM), 1.201 IN (32.500 MM), 1-7/32 IN (31.000 MM), 1-1/4 IN (31.800 MM), 1-3/8 IN (34.900 MM) Maximum Material Thickness : 10 GA (3.500 MM) Minimum Chuck Size : 3/8 IN (9.500 MM) Overall Length : 3-7/8/ IN (85.700 MM) Sub Brand : Kwik Stepper Type : Multi Hole
36414 价格&库存
很抱歉,暂时无法提供与“36414”相匹配的价格&库存,您可以联系我们找货
