36022
36022
    GREENLEECOMMUNICATIONS(格林利)
    BIT STEP 32 5MM
36022 数据手册
BIT,STEP 32,5MM (PKGD) Kwik Stepper® Step Bits Cat No: 36022 UPC No: 783310360223 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • • • • • Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : 0.638 IN (16.200 MM), 0.803 IN (20.400 MM), 1 IN (25.400 MM), 1.280 IN (32.500 MM) ISO : 16, 20, 25, 32 Maximum Material Thickness : 1/4 IN (6.400 MM) Minimum Chuck Size : 3/8 IN (9.500 MM) Overall Length : 3-7/8/ IN (85.700 MM) Sub Brand : Kwik Stepper
36022 价格&库存
很抱歉,暂时无法提供与“36022”相匹配的价格&库存,您可以联系我们找货
