03607
03607
    GREENLEECOMMUNICATIONS(格林利)
03607 数据手册
KIT-STEP BIT #1 & #3 (03607) Kwik Stepper® Step Bit Kit Cat No: 03607 UPC No: 783310036074 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : From 1/8 IN (3.200 MM) through 1-3/8 IN (3.200 - 34.900 MM) Sub Brand : Kwik Stepper
03607 价格&库存
很抱歉,暂时无法提供与“03607”相匹配的价格&库存,您可以联系我们找货
