NON-250
NON-250
    EATON(伊顿)
NON-250 数据手册
Bussmann® One-Time General Purpose Fuses NON and NOS 250 and 600 Volts, ⁄Ω• to 600 Amps Dimensions All diameters (± 0.008) 5" (600V) (± 0.031) 2" (250V) (± 0.031) 0.81" (± 0.008) .56" (± 0.008) ⁄Ω¡º to 30A ⁄Ω¡º to 30A 5.5" (600V) (± 0.031) 3" (250V) (± 0.031) 1.06" (± 0.008) .81" (± 0.008) 35A to 60A 35A to 60A Catalog Symbol: NON (250V); NOS (600V) For general purpose application Ampere Rating: ⁄Ω• to 600A Voltage Rating: NON: 250Vac, 125Vdc (0-100A); NOS: 600Vac Non-Current-Limiting Interrupting Rating: 50,000A RMS Sym. (0-60A), 10,000A RMS Sym. (65-600A), 50,000A @ 125Vdc (NON 0-60), 10,000A @ 125Vdc (NON 65-100A) Agency Information: UL Listed - 250V: Class K5 (0-60A), Std. 248-9 Class H (65-600A), Std. 248-6 (125Vdc: NON 0-100) 600V: Class K5 (0-60A), Std. 248-9 Class H (70-600A), Std. 248-6 UL Guide JDDZ, File E4274 CSA Certified, Class 1421-01, File 53787 (0-12 & 65-600A)† 250V (0-600A) 600V Catalog Numbers—NON ONE-TIME (250Vac) NON-⁄Ω• NON-5 NON-40 NON-175 NON-⁄Ω™ NON-6 NON-45 NON-200 NON-‹Ω¢ NON-6⁄Ω¢ NON-50 NON-225 NON-°Ω¡º NON-7 NON-60 NON-250 NON-1 NON-8 NON-65 NON-300 NON-1⁄Ω¢ NON-9 NON-70 NON-350 NON-1⁄Ω™ NON-10 NON-75 NON-400 NON-1flΩ¡º NON-12 NON-80 NON-450 NON-2 NON-15 NON-2⁄Ω™ NON-20 NON-90 NON-500 NON-100 NON-600 NON-3 NON-25 NON-110 — NON-3¤Ω¡º NON-30 NON-125 — NON-4 NON-35 NON-150 — 7.13" (250V) (± 0.062) 9.63" (600V) (± 0.062) 5.88" (250V) (± 0.062) 7.9" (600V) (± 0.062) 1.56" (250V) 1.84" (600V) 1.06" (250V) 1.34" (600V) 110A to 200A 70A to 100A 8.63" (250V) (± 0.094) 11.63" (600V) (± 0.094) 10.38" (250V) (± 0.094) 13.38" (600V) (± 0.094) 2.59" (250V) 3.13" (600V) 2.06" (250V) 2.59" (600V) 450A to 600A 225A to 400A General Information: • Protect lighting, heating and other circuits not subject to temporary surges and where available short-circuit currents are relatively low. • ONE-TIME fuses do not have any appreciable degree of timedelay and thus should not be specified in circuits where large transients or motor overloads occur. Use Buss FUSETRON® or LOW-PEAK® dual-element, time-delay fuses. • For general purpose circuits, size at ampere rating of circuit. • For motor circuits, size at 300% to 400%. Catalog Numbers—NOS ONE-TIME (600Vac) NOS-1 NOS-12 NOS-70 NOS-225 NOS-2 NOS-15 NOS-75 NOS-250 NOS-3 NOS-20 NOS-80 NON-300 NOS-4 NOS-25 NOS-90 NOS-350 NOS-5 NOS-30 NOS-100 NOS-400 NOS-6 NOS-35 NOS-110 NOS-450 NOS-7 NOS-40 NOS-125 NOS-500 NOS-8 NOS-45 NOS-150 NOS-600 NOS-9 NOS-50 NOS-175 NOS-10 NOS-60 — Carton Quantity and Weight—NON ONE-TIME (250Vac) Catalog Number Weight** Carton Qty. Lbs. Kg. NON ⁄Ω•–30 10 0.38 0.172 NON 35–60 10 1.00 0.453 NON 65–100 5 0.79 0.358 NON 110–200 1 0.79 0.358 NON 225–400 1 1.65 0.748 NON 450–600 1 2.76 1.251 NON -(1/8-60) is rated at 125Vdc with 50,000 AIC Rating. NON -(65-100) is rated at 125Vdc with 10,000 AIC Rating. **Weight per carton. † For CSA Certified 15-60A Ratings, see PON Data Sheet: 4126 Recommended fuseblocks for Class H & K5, 250V & 600V fuses See Data Sheets: 1112 (250V) and 1113 (600V) 10-2-02 SB02295 Carton Quantity and Weight—NOS ONE-TIME (600Vac) Catalog Number Carton Qty. Weight** Lbs. Kg. 1.45 0.657 NOS 1–30 10 NOS 35–60 10 2.6 1.179 NOS 70–100 5 2.80 1.270 NOS 110–200 1 1.24 0.562 NOS 225–400 1 3.03 1.374 NOS 450–600 **Weight per carton. 1 4.63 2.100 CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Applies to OPM-1038 and OPM-1038R. Form No. NON/ NOS Page 1 of 2 Data Sheet: 1030 Bussmann® One-Time General Purpose Fuses NON and NOS 250 and 600 Volts, ⁄Ω• to 600 Amps 10 10 TIME IN SECONDS 100 TIME IN SECONDS 100 1 .1 600A 400A 200A 100A 60A 300 30A 35A AMPERE RATING 15A 20A 600A Time-Current Characteristic Curves–Average Melt NOS ONE-TIME (600Vac) 400A 200A 60A 100A 30A 35A 300 15A 20A NON ONE-TIME (250Vac) AMPERE RATING 1 .1 .08 .06 .04 .03 1,000 100 20 .01 10,000 CURRENT IN AMPERES 10,000 1,000 20 .01 100 .02 CURRENT IN AMPERES The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 10-2-02 SB02295 Form No. NON/NOS Page 2 of 2 Data Sheet: 1030 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cooper Bussmann: NON-35 NOS-50 NON-20 NON-250 NON-5 NON-6
NON-250 价格&库存
很抱歉,暂时无法提供与“NON-250”相匹配的价格&库存,您可以联系我们找货
