Dual Band 2400-2500 MHZ/5150-5875 MHz
6-port MIMO Pole/Mast Mount Antenna
OP24516DS
6-PORT OMNIDIRECTIONAL DUAL BAND MIMO ANTENNA
The OP24516DS antenna is an indoor/outdoor pole mounted omnidirectional antenna designed for 802.11n
applications. As a 6-element MIMO antenna, each port operates over the 2.4GHz and 5 GHz bands, providing
a broadband solution in a single radome. It features a low profile radome and is designed to withstand the
rigors of outdoor applications with an IP67 Ingression Protection rating. The radiation patterns are uniform
and symmetrical, providing high levels of signal density into defined coverage zones. This antenna greatly
enhances the performance of 802.11n systems.
FEATURES
MARKETS
Low profile esthetically neutral housing
Both indoor/outdoor
6-element MIMO solution
IP67 rating
Conformance to RoHS
PARAMETER
PERFORMANCE
Frequency
2400-2500 MHz/5150-5875 MHz
Gain (dBi)
2.0 Typical (2.8 Max)/ 4.8 Typical (6.5 Max)
VSWR
2.0:1, Max
Nominal Impedance
50Ω
Polarization
Linear, Vertical
Azimuth Typical 3dB Beamwidth
Omnidirectional
Elevation Typical 3dB Beamwidth
66° /30°
Port-to-Port Isolation
20 dB /25 dB
Input Power
5W x 6
RF Connector
Type N, Male 6x
Cable Type
Plenum rated RG-58
Cable Length
910 mm±18 mm 6x (36 in±0.71 in 6x)
Radome Material
Polycarbonate, White
Mounting
Mast Mount (31.8-57.2 OD)
Wind Survival
200 km/hr (125 mph)
Operational Temperature
-30°C to +70°C
Storage Temperature
-40°C to +85°C
IP67
Dimensions (height x OD)
116.5 x 209.6 mm
Weight
1.6 kg (3.53 lbs)
CONNECTORS
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Offices, hotels and college campuses
Airports and hospitals
Bus terminals and train stations
Museums, libraries and retail malls
Wi-Fi Hot Spots
Cellular off-loading
802.11n MIMO
PART NO.
CONNECTOR
OP24516DS-91NM
Type N male
OP24516DS-91RSMM
Reverse Polarity SMA male
OP24516DS
AZIMUTH PATTERNS
Port 1
Port 1
Port 2
Port 3
Port 2
Port 3
Port 2
Port 3
Port 2
Port 3
Frequency = 2400 MHz
Frequency = 5550 MHz
ELEVATION PATTERNS
Port 1
Port 1
www.lairdtech.com
ANT-DS-OP24516DS 0415
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of
Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird
materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and
Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and
other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein
provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“OP24516DS-91NM”相匹配的价格&库存,您可以联系我们找货
