36171
36171
    GREENLEECOMMUNICATIONS(格林利)
36171 数据手册
PUNCH UNIT-54MM SLUGBUSTER Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 36171 UPC No: 783310361718 Description • • • • • • "The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52"" (64.0 mm) U.S.Patent #4,543,722 for Slug-Buste " Specifications • • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 10 GA (3.500 MM) Includes : Punch, Die And Draw Stud Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers PG : 42 Replacement Part : 36172 UPC 36172 Punch, 36173 UPC 36173 Die And 304AVBB UPC 04042 Draw Stud Size : 2-1/8 IN (54.000 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 2.500 LB (1134.000 GM)
36171 价格&库存
很抱歉,暂时无法提供与“36171”相匹配的价格&库存,您可以联系我们找货
