PV-40ANH1
PV-40ANH1
    EATON(伊顿)
    FUSE40A1000VDCPVSIZE1DUAL
PV-40ANH1 数据手册
BUSSMANN Technical Data 720133 Effective January 2016 Supersedes February 2015 SERIES Bussmann series NH photovoltaic fuse links Product description Eaton’s Bussmann series NH size photovoltaic fuse links are specifically designed to protect and isolate photovoltaic array combiners and disconnects. These fuse links are capable of interrupting low overcurrents associated with faulted PV systems (reverse current, multi-array fault). Standard features • Compact design • Low power loss • Global accreditations • Dual indicator feature • Variation of fixing options • Compatible with Bussmann series PV NH base range (see data sheet 720136) Technical Data 720133 Bussmann series NH photovoltaic fuse links Effective January 2016 Catalogue symbol • Blade without bolt holes: PV-ratingNH(size) • Blade with bolt holes PV-ratingNH(size)-B • Blade with bolt holes and lugs: PV-ratingNH(size)-BL Fuse size • NH1, 2 and 3 Technical data • Volts: 1000 V d.c. • Amps: 32 to 400 A • Breaking capacity: 50 kA • Time constant: 1-3mS • Class of operation: gPV and UL PV fuse links Standards/Agency information • IEC 60269-6 • UL 2579 (file number E335324) • CSA listed • RoHS compliant Microswitches (ordered separately, only for use with bladed version) • 170H0236 • 170H0238 Table 1. Technical data - Blade without bolt holes Energy integrals I2t (A2S) Watts loss (W) Catalogue number Fuse size Current rating (amps) Prearcing Total at 1000 V 0.8In In PV-32ANH1 NH1 32 80 720 4 8.5 PV-40ANH1 NH1 40 185 1670 5 9 PV-50ANH1 NH1 50 400 3600 6 11 PV-63ANH1 NH1 63 470 4300 6 12 PV-80ANH1 NH1 80 640 5760 8 15.5 PV-100ANH1 NH1 100 1300 11700 8 16.5 PV-110ANH1 NH1 110 2100 18900 9 18.5 PV-125ANH1 NH1 125 2600 23400 9 17.5 PV-160ANH1 NH1 160 5200 46800 14 27.5 PV-175ANH1 NH1 175 8300 74700 15 29 PV-200ANH1 NH1 200 10200 82000 13 25 PV-160ANH2 NH2 160 4600 37000 14 28 PV-200ANH2 NH2 200 9500 76000 16 32 PV-250ANH2 NH2 250 17000 136000 19 38 PV-300ANH3 NH3 300 32000 260000 24 40 PV-315ANH3 NH3 315 32000 260000 26 44 PV-350ANH3 NH3 350 44500 370000 27 45 PV-355ANH3 NH3 355 44500 370000 28 46 PV-400ANH3 NH3 400 67500 550000 30 50 Dimensions - Blade without bolt holes - mm 0$; • SD1-D-PV • SD2-D-PV • SD3-D-PV  Fuse holders (ordered separately, only for use with bladed version)  ,1',&$725 Packaging • 0$; “ MOQ 3 NH size 1 2 EATON www.eaton.com “ “ 0$; ,1',&$725 Bussmann series NH photovoltaic fuse links Technical Data 720133 Effective January 2016 Dimensions - Blade without bolt holes - mm  0$;    0$;   0$; “  “ ,1',&$7256+2:1,1 23(5$7('326,7,21 0$;   ,1',&$7256+2:1,1 23(5$7('326,7,21 ,1',&$725 NH size 2 “ “ “ “ ,1',&$725 NH Size 3 Time current-curve - Blade without bolt holes 10000 200A 175A 160A 125A 110A 100A 80A 1000 63A 50A Pre-arcing Time (s) 100 40A 32A 10 1 0.1 0.01 10 100 1000 10000 Prospective current (A) NH Size 1 EATON www.eaton.com 3 Technical Data 720133 Bussmann series NH photovoltaic fuse links Effective January 2016 Time current-curve - Blade without bolt holes 10000 250A 200A 160A 1000 Pre-arcing Time (s) 100 10 1 0.1 0.01 10 100 1000 10000 Prospective current (A) NH size 2 10000 1000 400A 350A355A 300A315A Pre-arcing Time (s) 100 10 1 0.1 0.01 10 100 1000 Prospective current (A) NH size 3 4 EATON www.eaton.com 10000 Bussmann series NH photovoltaic fuse links Technical Data 720133 Effective January 2016 Table 2. Technical data - Blade with bolt holes Catalogue numbers Energy integrals I2t (A2S) Watts loss (w) 0.8In With bolt holes With bolt holes and lugs Fuse size Current rating (amps) Prearcing PV-63ANH1-B PV-63ANH1-BL NH1 63 470 4300 6 12 PV-80ANH1-B PV-80ANH1-BL NH1 80 640 5760 8 15 PV-100ANH1-B PV-100ANH1-BL NH1 100 1300 11700 8 16 PV-125ANH1-B PV-125ANH1-BL NH1 125 2600 23400 9 17 PV-160ANH1-B PV-160ANH1-BL NH1 160 5200 46800 14 27 PV-200ANH1-B PV-200ANH1-BL NH1 200 10200 82000 13 25 PV-160ANH2-B PV-160ANH2-BL NH2 160 4600 37000 14 28 PV-200ANH2-B PV-200ANH2-BL NH2 200 9500 76000 16 32 PV-250ANH2-B PV-250ANH2-BL NH2 250 17000 136000 19 38 PV-315ANH3-B PV-315ANH3-BL NH3 315 32000 260000 26 44 PV-355ANH3-B PV-355ANH3-BL NH3 355 38000 310000 29 48 PV-400ANH3-B PV-400ANH3-BL NH3 400 61000 490000 32 50 Total at 1000 V In Dimensions - Blade with bolt holes - mm 0$;   0$;   0$;   0$; ,1',&$725 NH size 1 ,1',&$725     ,1',&$725        ,1',&$725  NH size 2 EATON www.eaton.com 5 Technical Data 720133 Bussmann series NH photovoltaic fuse links Effective January 2016 Dimensions - Blade with bolt holes - mm Dimensions - Blade with bolt holes and lugs - mm 0$;   0$;    0$; 0$;  ,1',&$725   ,1',&$725        ,1',&$725 ,1',&$725   NH size 3  NH size 2 Dimensions - Blade with bolt holes and lugs - mm 0$;   0$;     0$; 0$;   ,1',&$725     NH size 3 NH size 1 6 EATON www.eaton.com   ,1',&$725  ,1',&$725      ,1',&$725 Bussmann series NH photovoltaic fuse links Technical Data 720133 Effective January 2016 Time current-curve - Blade with bolt holes, with or without lugs 10000 200A 160A 125A 1000 100A 80A 63A Pre-arcing Time (s) 100 10 1 0.1 0.01 10 100 1000 10000 Prospective current (A) NH size 1 10000 250A 200A 160A 1000 Pre-arcing Time (s) 100 10 1 0.1 0.01 10 100 1000 10000 Prospective current (A) NH size 2 EATON www.eaton.com 7 Technical Data 720133 Bussmann series NH photovoltaic fuse links Effective January 2016 Time current-curve - Blade with bolt holes, with or without lugs 10000 400A 1000 355A 315A Pre-arcing Time (s) 100 10 1 0.1 0.01 10 100 1000 10000 Prospective current (A) NH size 3 Temperature derating for blades without bolt holes, with bolt holes (with or without lugs) PV Array fuse link derating with temperature 100 90 Percentage of ratted current 80 70 60 50 40 30 20 10 0 20 30 40 50 60 Ambient temperature (C) Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland 70 80 Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Electrical Sector Eaton Melton road, Burton-on-the-wolds LE12 5TH, United Kingdom Eaton.eu © 2016 Eaton All Rights Reserved Publication No. 720133 January 2016 Eaton is a registered trademark. All other trademarks are property of their respective owners.
PV-40ANH1 价格&库存
很抱歉,暂时无法提供与“PV-40ANH1”相匹配的价格&库存,您可以联系我们找货
PV-40ANH1
  • 10+4009.0705910+519.65188
