15NCLPT-3E
15NCLPT-3E
    EATON(伊顿)
    15NCLPT-3E
15NCLPT-3E 数据手册
Technical Data 6002 Effective September 2020 Supersedes September 2018 BUSSMANN SERIES PT Medium voltage fuses for potential and small power transformers Features and benefits Description: BussmannTM series indicating and nonindicating E-Rated, current-limiting, medium voltage fuses for potential, small power and control transformers. Contents • Low amp, current-limiting E-Rated PT medium voltage fuses are general purpose fuses defined by their melting time-current characteristic that permit their electrical interchangeability with other fuses of the same E Rating. • E-Rated general purpose fuses must have a current responsive element that will melt in 300 seconds at an RMS current within the range of 200% to 240% of the fuse’s nameplate current rating, fuse refill, or link per ANSI C37.46 for fuses rated 100E or less. • PT fuses are physically dimensioned for easy installation in existing hardware. • Space saving size eases design considerations for new installations. • Current-limiting fuses provide positive interruption even on low fault currents. The fuse limits the magnitude of electromechanical stresses in the protected apparatus. • These fuses are in a self-contained, nonventing package for installation indoors or outdoors in an enclosure. • Available in indicating and non-indicating versions. • Open fuse indicator speeds troubleshooting by providing a positive visual indication of fuse operation. Description Page Introduction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 2.475 kV fuses . . . . . . . . . . . . . . . . . . . . . . . . . . 3-6 3.6 kV fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-9 5.5 kV fuses . . . . . . . . . . . . . . . . . . . . . . . . . . 10-26 7.2 kV fuses. . . . . . . . . . . . . . . . . . . . . . . . . . . 27-29 8.3 kV fuses . . . . . . . . . . . . . . . . . . . . . . . . . . 30-39 12 kV fuses. . . . . . . . . . . . . . . . . . . . . . . . . . . 40-42 15.5 kV fuses . . . . . . . . . . . . . . . . . . . . . . . . . 43-52 17.5 kV fuses. . . . . . . . . . . . . . . . . . . . . . . . . . 53-54 24 kV fuses. . . . . . . . . . . . . . . . . . . . . . . . . . . 55-56 25.5 kV fuses . . . . . . . . . . . . . . . . . . . . . . . . . 57-60 36 kV fuses. . . . . . . . . . . . . . . . . . . . . . . . . . . 61-62 38 kV fuses. . . . . . . . . . . . . . . . . . . . . . . . . . . 63-69 Fuse mountings. . . . . . . . . . . . . . . . . . . . . . . 70-71 Typical applications • Primary protection of: • Medium voltage potential transformers • Small medium voltage service transformers • Small medium voltage control transformers. PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 E-Rated PT medium voltage fuses Catalog symbols (by maximum voltage rating): • • • • • • 2.475 kV • 2NCLPT-_ 3.6 kV • 3.6ABCNA_ • 3.6ABWNA_ • 3.6CAV_ • • 25.5 kV • 25CLPT-_E • 36 kV • 36ABGNA_ • 36CAV_ • 38 kV • 38CAV_E 5.5 kV • JCW-_ • 5CLPT-_E • 5NCLPT-_E • 5NCLPT-_E-A • 5.5ABWNA_E • 5.5AMWNA_E • 5.5CAV_E • 5.5CAVH_E 7.2 kV • 7.2ABWNA_ • 38CAVH_E • 38CLPT-_E Ratings*: • Volts • 2.4 kV to 38 kV • Amps • 0.25 to 15 A • Interrupting ratings • 25 to 80 kA RMS Sym • 7.2ABCNA_ * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. • 7.2AMWNA_E Agency information: • 7.2CAV_ • Those PT fuses conforming to the requirements for E-Rating meet the performance characteristics of IEEE/ANSI C37.46 8.3 kV • 8CLPT-_E-A • 8CLPT-_E-B • 8NCLPT-_E • 8NCLPT-_E-A • 8NCLPT-_E-B 12kV • 12ABCNA_ • • • 12CAV_ 15.5 kV • 15CLPT-_E • 15NCLPT-_E-A • 15.5CAV_E • 15.5CAVH_E 17.5 kV • 17.5ABGNA_ • 17.5CAV_ 24 kV • 24ABGNA_ • 24CAV_ Eaton.com/bussmannseries 2 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2.475 kV maximum system voltage Amp rating 0.25 0.5 1 2 5 Length A 4.5 (114) Dimensions - in (mm) Diameter B Clip centers C 0.8 (20) 3.9 (99) Catalog No. (Interrupting rating - kA) Indicating Non-indicating — 2NCLPT-.25E (63) — 2NCLPT-.5E (63) — 2NCLPT-1E (40) — 2NCLPT-2E (40) — 2NCLPT-5E (25) Recommended fuseclip 1A1837 Dimensions (see catalog number tables for values) C B A Recommended fuseclip and fuse block: Description Cat. No. Open fuseclip for 0.8 (20mm) dia. fuses 1A1837 Single-pole open fuse block with #10-32 phil-slot screw terminals rated 2500V, 5A maximum and 63kA withstand rating PTFB-2500-JCD Eaton.com/bussmannseries 3 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2.47 kV time-current curves — minimum melting for 2NCLPT-_E 0.25E 0.5E 1E 2E 5E 2NCLPT-_E Curve TC56357202 December 2008 Eaton.com/bussmannseries 4 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2.47 kV time-current curves — total clearing for 2NCLPT-_E 0.25E 0.5E 1E 2E 5E 2NCLPT-_E Curve TC59883702 October 2010 Eaton.com/bussmannseries 5 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2.47 kV peak let-through curves for 2NCLPT-_E 5E 1E & 2E 0.5E 0.25E 2NCLPT-_E Curve TC63933702 December 2008 Eaton.com/bussmannseries 6 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 3.6 kV maximum system voltage Amp rating 2 3.15 3.15 6.3 6.3 10 Length A 8.7 (221) 5.6 (142) 7.7 (195) 5.6 (142) Dimensions - in (mm) Diameter B Clip centers C 1.6 (41) 7.6 (193) 1 (25) 4.4 (112) 1 (25) 6.5 (165) 1 (25) 4.4 (112) 7.7 (195) 1 (25) 6.5 (165) Catalog No. (Interrupting Indicating — — — — — — rating - kA) Non-indicating Recommended fuseclip 3.6CAV2 (50) 1A1837 3.6ABWNA3.15 (50) 3.6ABCNA3.15 (50) 3.6ABWNA6.3 (50) A3354705 3.6ABCNA6.3 (50) 3.6ABCNA10 (50) Dimensions (see catalog number tables for values) C B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.0 (25.4mm) dia. fuses A3354705 Open fuseclip for 1.56 (39.7mm) / 1.6 (40.6mm) dia. fuses 1A0835 Eaton.com/bussmannseries 7 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 3.6 kV Time-current curves — minimum melting for 3.6CAV_, 3.6ABC_ and 3.6ABW_ 2A (CAV) 3.15A (ABC/ABW) 6.3A (ABC/ABW) 10A (ABC/ABW) 3.6ABC_, 3.6ABW_, 3.6CAV_ Eaton.com/bussmannseries 8 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 3.6 kV Peak let-through curves for 3.6ABC_ and 3.6ABW_ Eaton.com/bussmannseries 9 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV maximum system voltage Dimensions - in (mm) Diameter B Clip centers C 0.8 (20) 4.8 (122) 1 (25) 4.4 (112) 1.6 (41) 6.2 (157) 1.6 (41) 8.1 (206) 1 (25) 4.4 (112) 0.8 (20) 4.8 (122) 1.6 (41) 6.2 (157) 1.6 (41) 8.1 (206) 1.6 (41) 8.1 (206) 1 (25) 4.4 (112) 0.8 (20) 4.8 (122) 1.6 (41) 6.2 (157) 1.6 (41) 8.1 (206) 1 (25) 4.4 (112) 0.8 (20) 4.8 (122) Amp rating 0.5 0.5 0.5 0.5 1 1 1 1 1.5 2 2 2 2 3 3 Length A 5.6 (142) 5.6 (142) 7.4 (188) 9.5 (241) 5.6 (142) 5.6 (142) 7.4 (188) 9.5 (241) 9.5 (241) 5.6 (142) 5.6 (142) 7.4 (188) 9.5 (241) 5.6 (142) 5.6 (142) 3 9.5 (241) 1.6 (41) 8.1 (206) 3 4 5 5 5 5 10 15 7.4 (188) 5.6 (142) 9.5 (241) 5.6 (142) 5.6 (142) 7.3 (185) 9.5 (241) 7.4 (188) 1.6 (41) 0.8 (20) 1.6 (41) 1 (25) 0.8 (20) 1.6 (41) 1.6 (41) 1.6 (41) 6.2 (157) 4.8 (122) 8.1 (206) 4.4 (112) 4.8 (122) 5.9 (150) 8.1 (206) 6.2 (157) Catalog No. (Interrupting rating - kA) Indicating Non-indicating — 5.5AMWNA.5E (63) — 5.5ABWNA0.5E (50) 5.5CAVH0.5E (50) JCW-1/2E (40) 5CLPT-.5 (80)† 5NCLPT-.5E-A (63) — 5.5ABWNA1E (50) — 5.5AMWNA1E (63) 5.5CAVH1E (50) JCW-1E (40) 5CLPT-1 (80)† 5NCLPT-1E-A (63) 5CLPT-1.5 (80)† — — 5.5ABWNA2E (50) — 5.5AMWNA2E (63) 5.5CAVH2E (50) JCW-2E (40) — 5NCLPT-2E (63) — 5.5ABWNA3E (50) — 5.5AMWNA3E (63) Recommended fuseclip 1A1837 A3354705 1A0835 A3354705 1A1837 1A0835 1A0835 A3354705 1A1837 1A0835 1A1837 A3354705 1A1837 5CLPT-3E (80) 5NCLPT-3E (63) 1A0835 — 5CLPT-5E (80) — — — 5CLPT-10E (80) — JCW-3E (40) 5.5AMWNA4E (63) 5NCLPT-5E-A (63) 5.5ABWNA5E (50) 5.5AMWNA5E (63) JCW-5E (40) 5NCLPT-10E-A (63) 5.5CAV15E (50) 1A0835 1A1837 1A0835 A3354705 1A1837 1A0835 1A0835 † Due to manufacturing variances, this fuse does not comply with ANSI C37.46 for “E” rating. See time-current curves for performance characteristics. CLPT Type mountings and hardware 5.5 kV maximum (4.8kV nominal)* Fuse mounting Amp rating type** CLPT and NCLPT-A Mounting Non-disconnect 0.5–10 Disconnect† BIL (kV) 60 60 Catalog number Mounting (including live parts, end fittings)*** Live parts (including Porcelain insulator Glass-polyester insulator end fittings)*** End fittings (disconnect only) 5CLPT-PNM-A 5CLPT-PDM-A — CLPT-DF 5CLPT-GNM-A 5CLPT-GDM-A CLPT-NL CLPT-DL * Refers to 5CLPT and 5NCLPT fuses only. ** See page 70 for dimensions and diagrams of typical mounting. *** End fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Eaton.com/bussmannseries 10 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 Dimensions (see catalog number tables for values) C B Recommended fuseclips: Indicator Description Cat. No. Open fuseclip for 0.8 (20 mm) dia. fuses 1A1837 Open fuseclip for 1.0 (25.4 mm) dia. fuses A3354705 Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 A Eaton.com/bussmannseries 11 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV time-current curves — minimum melting for 5NCLPT-_-A 0.5E-A 1E-A 2E 3E 5E-A 10E 5NCLPT-_E Eaton.com/bussmannseries 12 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV time-current curves — total clearing for 5NCLPT-_-A 0.5E-A 1E-A 2E 3E 5E-A 10E 5NCLPT-_E Eaton.com/bussmannseries 13 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV peak let-through curves for 5NCLPT-_-A 10E 5E-A 3E 1E-A & 2E 0.5E-A 5NCLPT-_E Eaton.com/bussmannseries 14 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV Time-current curves — total clearing for 5CLPT_ 0.5A 1A 1.5A 3E 5E 10E Fuse melt times in dotted line region may not be assured due to manufacturing variations. Dotted line shows nominal operation. Some individual fuses may not trip until current at 10-second mark is applied. Curves are based on tests starting with fuse unit at ambient temperature of 25ºC and without initial load. Curves are plotted to maximum test points so all variations should be negative. 5CLPT-_ Curve TC56353306 August 2011 Eaton.com/bussmannseries 15 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV peak let-through curves for 5CLPT_ 10E 5E 1A & 1.5A 3E 0.5A 5CLPT-_ Curve TC63934001 March 2013 Eaton.com/bussmannseries 16 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2E (CAVH) 1E (CAVH) 0.5E (CAVH) 5.5 kV time-current curves — minimum melting for 5.5CAV_ and 5.5CAVH_ 15E (CAV) 5.5CAV_, 5.5CAVH_ Eaton.com/bussmannseries 17 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV time-current curves — total clearing for 5.5CAV_ 15E (CAV) 5.5CAV_ Eaton.com/bussmannseries 18 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV peak let-through curves for 5.5CAVH_ 10 Peak cut-off current in amps 1 2E (CAVH) 1E (CAVH) 0.5E (CAVH) 0.1 0.01 100 5.5CAVH_ 1000 10,000 RMS Symmetrical prospective current in amps Eaton.com/bussmannseries 100,000 19 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5E (ABW) 2E (ABW) 3E (ABW) 1E (ABW) 0.5E (ABW) 5.5 kV time-current curves — minimum melting for 5.5ABW_ and 5.5AMW_ 0.5E (AMW) 1E (AMW) 2E (AMW) 3E (AMW) 4E (AMW) 5E (AMW) 5.5ABW_, 5.5AMW_ Eaton.com/bussmannseries 20 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5E (ABW) 2E (ABW) 3E (ABW) 1E (ABW) 0.5E (ABW) 5.5 kV time-current curves — total clearing for 5.5ABW_ and 5.5AMW_ 0.5E (AMW) 1E (AMW) 2E (AMW) 3E (AMW) 4E (AMW) 5E (AMW) 5.5ABW_, 5.5AMW_ Eaton.com/bussmannseries 21 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 5.5 kV peak let-through curves for 5.5ABW_ and 5.5AMW_ 5E (ABW) 3E (ABW) 2E (ABW) 1E (ABW) 5E (AMW) 4E (AMW) 0.5E (ABW) 3E (AMW) 2E (AMW) 1E (AMW) 0.5E (AMW) 5.5ABW_, 5.5AMW_ Eaton.com/bussmannseries 22 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 7.2 kV maximum system voltage Amp rating 0.5 1 2 2 3 3.15 3.15 4 4 5 6 6.3 6.3 10 Length A 5.6 (142) 5.6 (142) 5.6 (142) 8.7 (221) 5.6 (142) 5.6 (142) 7.7 (195) 5.6 (142) 8.7 (221) 5.6 (142) 8.7 (221) 5.6 (142) 7.7 (195) 8.7 (221) Dimensions - in (mm) Diameter B Clip centers C 0.8 (20) 4.8 (122) 0.8 (20) 4.8 (122) 0.8 (20) 4.8 (122) 1.6 (41) 7.5 (190) 0.8 (20) 4.8 (122) 1 (25.4) 4.4 (112) 1 (25.4) 6.5 (165) 0.8 (20) 4.8 (122) 1.6 (41) 7.5 (190) 0.8 (20) 4.8 (122) 1.6 (41) 7.5 (190) 1 (25.4) 4.4 (112) 1 (25.4) 6.5 (165) 1.6 (41) 7.5 (190) Catalog No. (Interrupting rating - kA) Indicating Non-indicating — 7.2AMWNA0.5E (50) — 7.2AMWNA1.0E (50) — 7.2AMWNA2.0E (50) — 7.2CAV2 (40) — 7.2AMWNA3.0E (50) — 7.2ABWNA3.15 (45) — 7.2ABCNA3.15 (45) — 7.2AMWNA4.0E (50) — 7.2CAV4 (40) — 7.2AMWNA5E (50) — 7.2CAV6 (40) — 7.2ABWNA6.3 (45) — 7.2ABCNA6.3 (45) — 7.2CAV10 (40) Recommended fuseclip 1A1837 1A0835 1A1837 A3354705 1A1837 1A0835 1A1837 1A0835 A3354705 1A0835 Dimensions (see catalog number tables for values) C B A Recommended fuseclips Description Cat. No. Open fuseclip for 0.8 (20 mm) dia. fuses 1A1837 Open fuseclip for 1.0 (25.4 mm) dia. fuses A3354705 Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 23 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 7.2 kV time-current curves — minimum melting for 7.2ABW_ and 7.2CAV_ 2E (CAV) 4E (CAV) 6E (CAV) 10E (CAV) 6.3A (ABW) 3.15A (ABW) 7.2ABW_, 7.2CAV_ Eaton.com/bussmannseries 24 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 7.2 kV peak let-through curves for 7.2ABW_ Eaton.com/bussmannseries 25 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV maximum system voltage Amp rating 0.5 1 1 2 2 3 4 5 5 8 10 Length A 9.5 (241) 5 (127) 9.5 (241) 8 (203) 9.5 (241) 12.9 (328) 8 (203) 5 (127) 12.9 (328) 5 (127) 12.9 (328) Dimensions - in (mm) Diameter B Clip centers C 1.6 (41) 8.1 (206) 1.1 (28) 4 (102) 1.6 (41) 8.1 (206) 0.8 (20) 7.2 (183) 1.6 (41) 8.1 (206) 1.6 (41) 11.5 (292) 0.8 (20) 7.2 (183) 1.1 (28) 4 (102) 1.6 (41) 11.5 (292) 1.1 (28) 4 (102) 1.6 (41) 11.5 (292) Catalog No. (interrupting rating - kA) Indicating Non-indicating 8CLPT-.5 (50)† 8NCLPT-.5E-A (50) — 8NCLPT-1E (50) — 8NCLPT-1E-A (50) — 8NCLPT-2E (25) — 8NCLPT-2E-A (50) 8CLPT-3E (50) 8NCLPT-3E-B (50) — 8NCLPT-4E (25) — 8NCLPT-5E (50) 8CLPT-5E (50) 8NCLPT-5E-B (50) — 8NCLPT-8E (50) 8CLPT-10E (50) 8NCLPT-10E-B (50) Recommended fuseclip 1A0835 A3354705 1A0835 1A1837 1A0835 1A1837 A3354705 1A0835 † Does not comply with ANSI C37.46 for “E” rating. CLPT type mountings and hardware 8.3 kV maximum (7.2 kV nominal)* Catalog number Amp rating 0.5–2 3–10 * ** *** † Fuse mounting type** BIL (kV) Non-disconnect Disconnect† Non-disconnect Disconnect† 75 75 75 75 Mounting (including live parts, end fittings)*** Porcelain insulator Glass-polyester insulator Live parts (including End fittings end fittings)*** (disconnect only) 8CLPT-PNM-A 8CLPT-PDM-A 8CLPT-PNM-B 8CLPT-PDM-B CLPT-NL CLPT-DL CLPT-NL CLPT-DL 8CLPT-GNM-A 8CLPT-GDM-A 8CLPT-GNM-B 8CLPT-GDM-B — CLPT-DF — CLPT-DF Refers to 8CLPT and 8NCLPT-A or -B fuses only. See page 70 for dimensions and diagrams of typical mounting. End fittings supplied only when required. Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Dimensions (see catalog number tables for values) C Indicator B A Recommended fuseclips: Description Cat. No. Open fuseclip for 0.8 (20 mm) dia. fuses 1A1837 Open fuseclip for 1.0 (25.4 mm) dia. fuses A3354705 Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 26 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV time-current curves — minimum melting for 8NCLPT_ 1E 5E 8E 2E 4E 8NCLPT-_ Curve 59887102 July 2002 Reference # 628852, 598871 Curve TC56357206 December 2008 Eaton.com/bussmannseries 27 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV time-current curves — total clearing for 8NCLPT_ 1E 5E 2E 8NCLPT-_ 8E 4E Curve 59887104 July 2002 Reference # 598871 Curve TC59883706 December 2008 Eaton.com/bussmannseries 28 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV peak let-through curves for 8NCLPT_ 8E 5E 4E 8NCLPT-_ Curve 63933703 July 2001 Reference # 639337 2E 1E Curve TC63933704 December 2008 Eaton.com/bussmannseries 29 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV time-current curves — minimum melting for 8CLPT_ 0.5A 3E 5E 10E 8CLPT-_ 0.5 A fuse melt time in the dotted line region may not be assured due to manufacturing variations. The dotted lines show nominal operation. Some individual fuses may not open until current at 10-second mark is applied. Curve TC56353206 December 2013 Eaton.com/bussmannseries 30 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV time-current curves — total clearing for 8CLPT_ 0.5A 3E 5E 10E 8CLPT-_ Curve TC56353306 March 2013 Eaton.com/bussmannseries 31 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV peak let-through curves for 8CLPT_ 10E 5E 3E 0.5A 8CLPT-_ Curve TC63934001 March 2013 Eaton.com/bussmannseries 32 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV time-current curves — minimum melting for 8NCLPT-_E-A/B 0.5E-A 1E-A 2E-A 3E-B 5E-B 10E-B 8NCLPT-_E-A/B Curve TC70548303 December 2008 Eaton.com/bussmannseries 33 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV time-current curves — total clearing for 8NCLPT-_E--A/B 0.5E-A 1E-A 2E-A 3E-B 5E-B 10E-B 8NCLPT-_E-A/B Curve TC70548403 December 2008 Eaton.com/bussmannseries 34 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 8.3 kV peak let-through curves for 8NCLPT-_E-A/B 10E-B 5E-B 3E-B 1E-A & 2E-A 0.5E-A 8NCLPT-_E-A/B Curve TC63934002 December 2008 Eaton.com/bussmannseries 35 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 12 kV maximum system voltage Amp rating 2 3.15 Length A 8.7 (221) 7.7 (195) Dimensions - in (mm) Catalog No. (Interrupting Diameter B Clip centers C Indicating 1.6 (41) 7.5 (190) — 1 (25) 6.5 (165) — rating - kA) Non-indicating 12CAV2 (40) 12ABCNA3.15 (45) Recommended fuseclip 1A0835 A3354705 Dimensions (see catalog number tables for values) C B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.0 (25.4 mm) dia. fuses A3354705 Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 36 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 12 kV time-current curves — minimum melting for 12ABC_ and 12CAV_ 2A (CAV) 3.15A (ABC) 12ABC_, 12CAV_ Eaton.com/bussmannseries 37 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 12 kV peak let-through curves for 12ABC_ Eaton.com/bussmannseries 38 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV maximum system voltage Amp rating 0.5 1 2 3 3 3 5 5 7 10 Dimensions - in (mm) Catalog No. (Interrupting rating - kA) Length A Diameter B Clip centers C Indicating Non-indicating Recommended fuseclip 12.9 (328) 1.6 (41) 11.5 (292) 15.5CAVH0.5E (80) 15NCLPT-.5E-A (50) 12.9 (328) 1.6 (41) 11.5 (292) 15.5CAVH1E (80) 15NCLPT-1E-A (50) 12.9 (328) 1.6 (41) 11.5 (292) 15.5CAVH2E (80) 15NCLPT-2E (50) 12.9 (328) 1.6 (41) 11.5 (292) — 15.5CAV3E (80) 17.6 (447) 1.6 (41) 16.1 (409) — 15NCLPT-3E (50) 1A0835 17.6 (447) 1.6 (41) 16.1 (409) 15CLPT-3E (50) — 12.9 (328) 1.6 (41) 11.5 (292) — 15.5CAV5E (80) 17.6 (447) 1.6 (41) 16.1 (409) 15CLPT-5E (50) 15NCLPT-5E (50) 12.9 (328) 1.6 (41) 11.5 (292) — 15.5CAV7E (80) 17.6 (447) 1.6 (41) 16.1 (409) 15CLPT-10E (50) 15NCLPT-10E (50) CLPT Type mountings and hardware 15.5 kV maximum (14.4 kV nominal) Amp rating 0.5–2 3–10 * ** † Fuse mounting type* Nondisconnect Disconnect† Nondisconnect Disconnect† Catalog number Mounting (Including live parts, end fittings)** Porcelain insulator Glass-polyester insulator Live parts (including End fittings end fittings)** (disconnect only) 95 15CLPT-PNM-A 15CLPT-GNM-A CLPT-NL — 95 15CLPT-PDM-A 15CLPT-GDM-A CLPT-DL CLPT-DF 95 15CLPT-PNM-B 15CLPT-GNM-B CLPT-NL CLPT-DF 95 15CLPT-PDM-B 15CLPT-GDM-B CLPT-DL — BIL (kV) See page 70 for dimensions and diagrams of typical mounting. End fittings supplied only when required. Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Dimensions (see catalog number tables for values) C Indicator B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 39 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV time-current curves — minimum melting for 15CLPT_ 1A 3E 0.5A 1.5A 10E 15CLPT-_ 5E Curve TC56353206 August 2011 Eaton.com/bussmannseries 40 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV time-current curves — total clearing for 15CLPT_ 0.5A 1A 1.5A 3E 5E 10E 15CLPT-_E Eaton.com/bussmannseries 41 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV peak let-through curves for 15CLPT_ 10E 5E 1A & 1.5A 3E 0.5A 15CLPT-_ Curve TC63934001 March 2013 Eaton.com/bussmannseries 42 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV time-current curves — minimum melting for 15NCLPT_ 0.5E-A 1E-A 2E 3E 5E 10E 15NCLPT-_ Curve TC70548303 December 2008 Eaton.com/bussmannseries 43 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV Time-current curves — total clearing for 15NCLPT_ 0.5E-A 1E-A 2E-A 3E 5E 10E 15NCLPT-_ Curve TC70548403 December 2008 Eaton.com/bussmannseries 44 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 15.5 kV Peak let-through curves for 15NCLPT_ 10E 5E 3E 1E-A & 2E-A 0.5A 15NCLPT-_ Curve TC63934002 December 2008 Eaton.com/bussmannseries 45 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2E (CAVH) 1E (CAVH) 0.5E (CAVH) 15.5 kV time-current curves — minimum melting for 15.5CAV_ and 15.5CAVH_ 7E (CAV) 3E (CAV) 15.5CAV_, 15.5CAVH_ Eaton.com/bussmannseries 46 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2E (CAVH) 1E (CAVH) 0.5E (CAVH) 15.5 kV time-current curves — total clearing for 15.5CAVH_ 7E (CAV) 3E (CAV) 15.5CAV_, 15.5CAVH_ Eaton.com/bussmannseries 47 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 PEAK CUT-OFF CURRENT IN KILOAMPS 15.5 kV peak let-through curves for 15.5CAVH_ 2E (CAVH) 1E (CAVH) 0.5E (CAVH) 15.5CAVH_ RMS SYMMETRICAL PROSPECTIVE CURRENT IN KILOAMPS Eaton.com/bussmannseries 48 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 17.5 kV maximum system voltage Amp rating 2 4 6 Length A 8.7 (221) Dimensions - in (mm) Diameter B Clip centers C 1.6 (41) 7.5 (190) 10 Catalog No. (Interrupting rating - kA) Indicating Non-indicating — 17.5CAV2 (40) — 17.5CAV4 (40) — 17.5CAV6 (40) — 17.5CAV10 (40) Recommended fuseclip 1A0835 Dimensions (see catalog number tables for values) C B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 49 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 17.5 kV time-current curves — minimum melting for 17.5CAV_ 2A (CAV) 4A (CAV) 6A (CAV) 10A (CAV) 7.5CAV_ Eaton.com/bussmannseries 50 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 24 kV maximum system voltage Amp rating 2 3 4 Dimensions - in (mm) Catalog No. (Interrupting rating - kA) Diameter B Clip centers C Indicating Non-indicating — 24CAV2 (40) 13.49 (340) 1.6 (41) 12.2 (310) — 24CAV3 (40) — 24CAV4 (40) Length A Recommended fuseclip 1A0835 Dimensions (see catalog number tables for values) C B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 51 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 24 kV time-current curves — minimum melting for 24CAV_ 2A (CAV) 3A (CAV) 4A (CAV) 24CAV_ Eaton.com/bussmannseries 52 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 25.5 kV maximum system voltage Amp rating 0.5 1 Length A 17.6 (447) 17.6 (447) Dimensions - in (mm) Catalog No. (interrupting rating - kA) Diameter B Clip centers C Indicating Non-indicating 1.6 (41) 16.1 (410) 25CLPT-.5 (43.5)† — 1.6 (41) 16.1 (410) 25CLPT-1 (43.5)† — Recommended fuseclip 1A0835 † Does not comply with ANSI C37.46 for “E” rating. CLPT Type Mountings and Hardware 25.5 kV Maximum (23 kV Nominal) Amp rating 0.5–1 * ** † Fuse mounting type* Non-disconnect Disconnect BIL (kV) 150 150 Catalog number Mounting (including live parts, end fittings)** Porcelain insulator Glass-polyester insulator 25CLPT-PNM-A — 25CLPT-PDM-A — Live parts (including end fittings)** 25CLPT-NL 25CLPT-DL End fittings (disconnect only) — CLPT-DF See page 70 for dimensions and diagrams of typical mounting. End fittings supplied only when required. Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Dimensions (see catalog number tables for values) C Indicator B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 53 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 25.5 kV time-current curves — minimum melting for 25CLPT_ 0.5A 1A 25CLPT-_ 0.5, and 1 A fuse melt times in the dotted line region may not be assured due to manufacturing variations. The dotted lines show nominal operation. Some individual fuses may not open until current at 10-second mark is applied. Curve TC56353208 December 2008 Eaton.com/bussmannseries 54 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 25.5 kV time-current curves — total clearing for 25CLPT_ 0.5A 1A 25CLPT-_ Curve TC56353308 December 2008 Eaton.com/bussmannseries 55 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 25.5 kV Peak let-through curves for 25CLPT_ 1A 0.5A 25CLPT-_ Curve TC63933901 December 2008 Eaton.com/bussmannseries 56 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 36 kV maximum system voltage Amp rating 2 4 Length A 17.3 (439) Dimensions - in (mm) Diameter B Clip centers C 1.6 (41) 16.1 (410) — — Catalog No. (Interrupting rating - kA) Indicating Non-indicating 36CAV2 (40) 36CAV4 (40) Recommended fuseclip 1A0835 Dimensions (see catalog number tables for values) C B A Recommended fuseclips: Description Cat. No. Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 57 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 36 kV Time-current curves — minimum melting for 36CAV_ 2A (CAV) 4A (CAV) 36CAV_ Eaton.com/bussmannseries 58 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 38 kV maximum system voltage Amp rating 0.5 0.5 1 2 4 Length A 17.3 (439) 18.6 (472) 17.3 (439) 17.3 (439) 17.3 (439) Dimensions - in (mm) Catalog No. (interrupting Diameter B Clip centers C Indicating 1.6 (41) 16.1 (409) 38CAVH0.5E (40) 1.6 (41) 17.1 (434) 38CLPT-0.5 (43.5)† 1.6 (41) 16.1 (409) 38CAVH1E (40) 1.6 (41) 16.1 (409) 38CAVH2E (40) 1.6 (41) 16.1 (409) — rating - kA) Non-indicating — — — — 38CAV4E (40) Recommended fuseclip 1A0835 † Does not comply with ANSI C37.46 for “E” rating. CLPT Type Mountings and Hardware 38 kV Maximum (34.5 kV Nominal) Amp rating 0.5 Catalog number Fuse mounting Mounting (including Live Parts, End Fittings)* type Porcelain insulator Glass-polyester insulator Disconnect† Not applicable Not applicable Non-disconnect 38CLPT-PNM-A Not applicable Live Parts (including end fittings)* CLPT-NL CLPT-DL End fittings (disconnect only) CLPT-DF — * End fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Dimensions (see catalog number tables for values) C Indicator B A Recommended fuseclip: Description Cat. No. Open fuseclip for 1.56 (39.7 mm) / 1.6 (40.6 mm) dia. fuses 1A0835 Eaton.com/bussmannseries 59 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2A (CAVH) 1A (CAVH) 0.5A (CAVH) 38 kV time-current curves — minimum melting for 38CAV_ and 38CAVH 4A (CAV) 38CAV_, 38CAVH_ Eaton.com/bussmannseries 60 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 2A (CAVH) 1A (CAVH) 0.5A (CAVH) 38 kV time-current curves — total clearing for 38CAV_ and 38CAVH 4A (CAV) 38CAV_, 38CAVH_ Eaton.com/bussmannseries 61 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 38 kV peak let-through curves for 38CAVH 2A (CAVH) 1A (CAVH) 0.5A (CAVH) 38CAVH_ Eaton.com/bussmannseries 62 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 38 kV time-current curves — minimum melting for 38CLPT_ 0.5A 38CLPT_ 0.5 A fuse melt times in the dotted line region may not be assured due to manufacturing variations. The dotted lines show nominal operation. Some individual fuses may not open until current at 10-second mark is applied. Curve TC56353208 December 2008 Eaton.com/bussmannseries 63 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 38 kV time-current curves — total clearing for 38CLPT_ 0.5A 38CLPT_ Curve TC56353308 December 2008 Eaton.com/bussmannseries 64 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 38 kV peak let-through curves for 38CLPT_ 0.5A 38CLPT_ Curve TC63933901 Eaton.com/bussmannseries December 2008 65 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 PT fuse mountings - in (mm) Catalog number Hole centers A Hole centers B Overall length C 5.5kV Disconnect† 5CLPT-GDM-A 9.37 (238) 6 (152.4) 18.63 (473.2) 5CLPT-PDM-A 9.37 (238) 6 (152.4) 18.63 (473.2) 5.5kV Non-disconnect 5CLPT-GNM-A 9.37 (238) 5CLPT-PNM-A 9.37 (238) 8.3kV Disconnect† 8CLPT-GDM-A 9.37 (238) 8CLPT-GDM-B 9.37 (238) 8CLPT-PDM-A 9.37 (238) 8CLPT-PDM-B 12.74 (323.6) 8.3kV Non-disconnect 8CLPT-GNM-A 9.37 (238) 8CLPT-PNM-A 9.37 (238) 8CLPT-GNM-B 12.75 (323.8) 8CLPT-PNM-B 12.75 (323.8) 15.5kV Disconnect† 15CLPT-GDM-A 12.74 (323.6) 15CLPT-PDM-A 12.74 (323.6) 15CLPT-GDM-B 17.46 (443.5) 15CLPT-PDM-B 17.46 (443.5) 15.5kV Non-disconnect 15CLPT-GNM-A 12.74 (323.6) 15CLPT-PNM-A 12.74 (323.6) 15CLPT-GNM-B 17.46 (443.5) 15CLPT-PNM-B 17.46 (443.5) 25.5kV Disconnect† 25CLPT-PDM-A 19.12 (485.6) 25.5kV Non-disconnect 25CLPT-PNM-A 26.63 (676.4) 38kV Non-disconnect 38CLPT-PNM-A 19.12 (485.6) Hole Inset D Hole centers E Contact height F Overall height G BIL kV 0.75 (19) 0.75 (19) 1.75 (44.4) 1.75 (44.4) 4.5 (114.3) 4.5 (114.3) 9.56 (242.8) 9.56 (242.8) 60 60 4.5 (114.3) 4.5 (114.3) 6.94 (176.2) 6.94 (176.2) 60 60 6 (152.4) 6 (152.4) 18.63 (473.2) 18.63 (473.2) 0.75 (19) 0.75 (19) 1.75 (44.4) 1.75 (44.4) 6 6 6 6 (152.4) (152.4) (152.4) (152.4) 18.63 (473.2) 18.63 (473.2) 18.63 (473.2) 22 (558.8) 0.75 0.75 0.75 0.75 (19) (19) (19) (19) 1.75 1.75 1.75 1.75 (44.4) (44.4) (44.4) (44.4) 7 7 7 7 (177.8) (177.8) (177.8) (177.8) 12.06 12.06 12.06 12.06 (306.3) (306.3) (306.3) (306.3) 75 75 75 75 6 6 6 6 (152.4) (152.4) (152.4) (152.4) 18.63 (473.2) 18.63 (473.2) 22 (558.8) 22 (558.8) 0.75 0.75 0.75 0.75 (19) (19) (19) (19) 1.75 1.75 1.75 1.75 (44.4) (44.4) (44.4) (44.4) 7 7 7 7 (177.8) (177.8) (177.8) (177.8) 9.44 9.44 9.44 9.44 (239.8) (239.8) (239.8) (239.8) 75 75 75 75 6 6 6 6 (152.4) (152.4) (152.4) (152.4) 22 (558.8) 22 (558.8) 26.63 (676.4) 26.63 (676.4) 0.75 0.75 0.75 0.75 (19) (19) (19) (19) 1.75 1.75 1.75 1.75 (44.4) (44.4) (44.4) (44.4) 7 7 7 7 (177.8) (177.8) (177.8) (177.8) 12.06 12.06 12.06 12.06 (306.3) (306.3) (306.3) (306.3) 95 95 95 95 6 6 6 6 (152.4) (152.4) (152.4) (152.4) 22 (558.8) 22 (558.8) 26.63 (676.4) 26.63 (676.4) 0.75 0.75 0.75 0.75 (19) (19) (19) (19) 1.75 1.75 1.75 1.75 (44.4) (44.4) (44.4) (44.4) 7 7 7 7 (177.8) (177.8) (177.8) (177.8) 9.44 9.44 9.44 9.44 (239.8) (239.8) (239.8) (239.8) 95 95 95 95 7 (177.8) 26.63 (676.4) 0.75 (19) 1.75 (44.4) 12 (304.8) 17.06 (433.3) 150 7 (177.8) 26.63 (676.4) 0.75 (19) 1.75 (44.4) 12 (304.8) 14.75 (374.6) 150 7 (177.8) 26.63 (676.4) 0.75 (19) 1.75 (44.4) 12 (304.8) 14.75 (374.6) 150 † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Eaton.com/bussmannseries 66 PT medium voltage fuses for potential and small power transformers Technical Data 6002 Effective September 2020 Disconnect mountings† Non-disconnect mountings G G F D F D E E C A A C E E D B D B † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Eaton.com/bussmannseries 67 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2020 Eaton All Rights Reserved Publication No. 6002 – BU-SB15149 September 2020 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Follow us on social media to get the latest product and support information.
15NCLPT-3E 价格&库存
很抱歉,暂时无法提供与“15NCLPT-3E”相匹配的价格&库存,您可以联系我们找货
