35182
35182
    GREENLEECOMMUNICATIONS(格林利)
    PUNCH UNIT-64MM
35182 数据手册
PUNCH UNIT-64MM Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 35182 UPC No: 783310351825 Description • • • • • • "The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52"" (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster " Specifications • • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 10 GA (3.500 MM) Includes : Punch, Die And Draw Stud ISO : 64 Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers Replacement Part : 35167 UPC 35167 Punch, 35166 UPC 35166 Die And 304AVBB UPC 04042 Draw Stud Size : 2.520 IN (64.000 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 3.400 LB (1542.000 GM)
35182 价格&库存
很抱歉,暂时无法提供与“35182”相匹配的价格&库存,您可以联系我们找货
