35884
35884
    GREENLEECOMMUNICATIONS(格林利)
35884 数据手册
BIT KIT,STEP-#1,#3 & #8. Kwik Stepper® Step Bit Kit Cat No: 35884 UPC No: 783310358848 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : From 1/8 IN (3.200 MM) through 1-3/8 IN (3.200 - 34.900 MM) Sub Brand : Kwik Stepper
35884 价格&库存
很抱歉,暂时无法提供与“35884”相匹配的价格&库存,您可以联系我们找货
