LPN-RK-125SP-TP
LPN-RK-125SP-TP
    EATON(伊顿)
    LPN-RK-125SP-TP
LPN-RK-125SP-TP 数据手册
Technical Data 1004 Effective August 2018 Supersedes March 2017 LPN-RK — 250 Vac/dc, 70-600 A, dual element, time-delay fuses Catalog no.* LPN-RK-70SP LPN-RK-80SP LPN-RK-90SP LPN-RK-100SP LPN-RK-110SP LPN-RK-125SP LPN-RK-150SP LPN-RK-175SP LPN-RK-200SP LPN-RK-225SP LPN-RK-250SP LPN-RK-300SP LPN-RK-350SP LPN-RK-400SP LPN-RK-450SP LPN-RK-500SP LPN-RK-600SP * Open fuse indication available on all part numbers by inserting the suffix “I,” e.g., LPN-RK-90SPI. Requires 75Vac minimum voltage. Indicating fuses are not Vdc rated. Carton quantity • 70–100 A: 5 • 110–600 A: 1 Typical applications Catalog symbols: • LPN-RK-(amp)SP (non-indicating) • LPN-RK-(amp)SPI (indicating) • Feeder and branch circuits • Transformers • Motors • Solenoids • General purpose circuits Description: Features and benefits Ultimate protection Class RK1 dual element, current-limiting, time-delay fuses available with optional open fuse indication. • Industry’s only UL Listed and CSA Certified fuse with a 300 kA interrupting rating that allows for simple, worry-free installation in virtually any application. • Fast short-circuit protection and dual-element, time-delay performance provide ultimate protection. • Reduces existing fuse inventory by up to 33% when upgrading to Low-Peak fuses. • Consistent 2:1 ampacity ratios for all Low-Peak fuses make selective coordination easy. • Time-delay permits 130% FLA sizing for back-up motor protection. • Current-limitation protects downstream components against damaging thermal and magnetic effects of short-circuit currents. • Protects against single-phase motor damage. • Proper sizing can provide “no damage” Type 2 coordinated protection for NEMA and IEC motor controllers. Specifications: Ratings • Volts 250Vac/dc* • Amps 70-600 A • IR • 300kA Vac RMS Sym. • 100kA Vdc * Indicating versions not Vdc rated. Agency information • UL Listed, Guide JDDZ, File E4273 • CSA Certified, Class 1422-02, File 53787, Class RK1 per CSA C22.2 No. 248.12 • CE Technical Data 1004 LPN-RK — 250 Vac/dc, 70-600 A, dual element, time-delay fuses Effective August 2018 Recommended fuse blocks Amps 100 200 400 600 Catalog no. 1-Pole RM25100-1CR RM25200-1CR RM25400-1CR RM25600-1CR 2-Pole RM25100-2CR RM25200-2CR RM25400-2CR RM25600-2CR 3-Pole RM25100-3CR RM25200-3CR RM25400-3CR RM25600-3CR For additional information on the RM Series of 250 volt fuse blocks, see product brochure # 3192. Fuse Reducers For Class R Fuses Desired fuse (case) Equipment fuse clips size 200 A 100 A 100 A 400 A 200 A 100 A 600 A 200 A 400 A Catalog no. (Pairs) 250V NO.2621-R NO.2641-R NO.642-R NO.2661-R NO.2662-R NO.2664-R† † Single reducer only (pair not required). For additional information on Class R fuse reducers, see data sheet no. 1118. Dimensions — in A B Amp rating 70-100 110-200 225-400 450-600 2 A 5.88 7.13 8.63 10.38 Eaton.com/bussmannseries B 1.10 1.61 2.36 2.88 LPN-RK — 250 Vac/dc, 70-600 A, dual element, time-delay fuses Technical Data 1004 Effective August 2018 Time-current curves - average melt 600 400 200 100 TIME IN SECONDS 60 AMP RATING CURRENT IN AMPS NOTE: 60 Amp fuse curve is ferrule style and included to show only relative performance. For actual 60 amp time-current curve performance, see data sheet no. 1003. Eaton.com/bussmannseries 3 Technical Data 1004 LPN-RK — 250 Vac/dc, 70-600 A, dual element, time-delay fuses Effective August 2018 Current-limitation curves Current-limiting effects B Prosp. S.C.C. Let-through current (apparent RMS Sym. vs. fuse rating) — 100 A 200 A 400 A 600 A 1000 1000 1000 1000 1000 2000 2000 2000 2000 2000 3000 2000 3000 3000 3000 5000 2000 3000 5000 5000 50,000 600A 10,000 3000 4000 7000 9000 40,000 400A 15,000 3000 5000 8000 11,000 200A 20,000 3000 5000 8000 11,000 25,000 3000 5000 9000 12,000 100A 30,000 4000 6000 9000 12,000 35,000 4000 6000 10,000 13,000 40,000 4000 6000 10,000 13,000 50,000 4000 7000 11,000 14,000 60,000 4000 7000 11,000 16,000 70,000 4000 7000 12,000 16,000 80,000 5000 8000 12,000 16,000 90,000 5000 7000 13,000 17,000 100,000 5000 8000 13,000 17,000 150,000 6000 9000 15,000 19,000 200,000 6000 11,000 16,000 20,000 250,000 7000 11,000 17,000 21,000 300,000 7000 12,000 18,000 22,000 AMP RATING 400,000 300,000 INSTANTANEOUS PEAK LET-THROUGH CURRENT IN AMPERES 200,000 100,000 90,000 80,000 70,000 60,000 30,000 20,000 10,000 9000 8000 7000 6000 5000 4000 3000 A 2000 RMS SYMMETRICAL CURRENT IN AMPS A-B = ASYMMETRICAL AVAILABLE PEAK (2.3 X SYM RMS AMPS) 300,000 200,000 80,000 100,000 60,000 40,000 30,000 20,000 8000 10,000 6000 4000 3000 2000 1000 1000 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2018 Eaton All Rights Reserved Printed in USA Publication No. 1004 — BU-SB13687 August 2018 Eaton.com/bussmannseries Eaton, Bussmann and Low-Peak are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
LPN-RK-125SP-TP
物料型号: - 该文档列出了BUSSMANN系列的LPN-RK型号,包括70-600A的双元件、延时保险丝,具体型号包括LPN-RK-70SP至LPN-RK-600SP。
器件简介: - LPN-RK系列是Class RK1双元件、电流限制、延时保险丝,提供终极保护。它们是行业中唯一获得UL认证和CSA认证的保险丝,具有300kA的中断等级,适用于几乎所有应用场景。
引脚分配: - 文档中未明确提供引脚分配信息,通常这是针对集成电路或模块化组件的,而此文档描述的是保险丝。
参数特性: - 电压等级:250Vac/dc - 电流等级:70-600A - 断路容量:300kA Vac RMS对称,100kA Vdc(注意:指示版本未对Vdc进行评级) - 具有快速短路保护和双元件延时性能,提供终极保护。
功能详解: - 这些保险丝具有电流限制功能,可保护下游组件免受短路电流的热和磁效应的损害。 - 它们还具有可选的断开保险丝指示功能,需要至少75Vac的电压。
应用信息: - 典型应用包括馈电和分支电路、变压器和电机。
封装信息: - 文档提供了不同电流等级的尺寸信息,例如70-100A的尺寸为5.88 x 1.10英寸,而450-600A的尺寸为10.38 x 2.88英寸。
LPN-RK-125SP-TP 价格&库存
很抱歉,暂时无法提供与“LPN-RK-125SP-TP”相匹配的价格&库存,您可以联系我们找货
LPN-RK-125SP-TP
  • 1+6056.552841+787.33227
