S9028PCR180RTN
S9028PCR180RTN
    LAIRD(莱尔德)
    902-928MHZ9DBIRH180"RPTNCM-M
S9028PCR180RTN 数据手册
Circular Polarity RFID Panel Antenna S9028PCL S9028PCR 902-928 MHz 9 dBic CIRCULAR POLARITY PANEL The Laird S9028PCL antenna is a circularly polarized panel antenna that provides reception and transmission of signals in the 902-928 MHz frequency band. Laird's industry-renowned design methodology achieves maximum efficiency and performance across the entire frequency band. Both VSWR and axial ratios are excellent and allow the user to achieve the maximum performance for an antenna of this type. The antenna is housed in a heavy duty radome enclosure that can be directly wall mounted, An optional articulating mount allows either wall or mast mounting. The antenna is offered with an integrated coax pigtail and a variety of connector types are available. FEATURES APPLICATIONS • Low profile • Extremely low VSWR and axial ratio • Warehouse • Distribution center • Airports and hospitals • Weather and UV resistant radome • Wide range of connector and cable options • Transit terminals • Conveyer belt • Left hand and right hand CP versions SPECIFICATIONS 915 MHz Antenna Part Number S9028PLC / S9028PCR Frequency Range 902 - 928 MHz Gain 9 dBic Maxium VSWR 1.3:1 3 dB Beamwidth - Azimuth 70° Front to Back Ratio 20 dB Polarization Circular Right or Left Maxium Input Power 10 Watts Input Impedence 50 Ohms Axial Ratio 1dB Typical Weight (Kg) 2.3 lbs (1.04) Mechanical Size 10.2” x 10.2” x 1.32” Antenna Connection Coax Pigtail, Rev TNC Male (others available) Radome High Strength PC Mount Style Threaded Stud Temperature Operational -25°C to +70°C Lightning Protection DC Grounded Environmental Rating IP 54 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-S9028PCL S9028PCR 0515 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
S9028PCR180RTN
物料型号:S9028PCL/S9028PCR 器件简介:902-928 MHz频段的圆极化面板天线,具有高效能和高性能。 引脚分配:文档未明确提供引脚分配信息。 参数特性:包括9 dBic的增益、1.3:1的最大VSWR、70°的3 dB波束宽度-方位、20 dB的前后比、圆极化(右旋或左旋)、10瓦特的最大输入功率、50欧姆的输入阻抗、典型的1 dB轴比。 功能详解:天线设计用于在902-928 MHz频段内提供信号的接收和传输,具有低剖面、极低的VSWR和轴比、耐候和抗紫外线的护套。 应用信息:适用于仓库、配送中心、机场、医院、交通枢纽、传送带等。 封装信息:机械尺寸为10.2"x10.2"x1.32",天线连接为同轴猪尾,标准配置为Rev TNC Male(其他类型可用),护套材料为高强度PC,安装方式为螺纹柱,工作温度范围为-25°C至+70°C,具有直流接地的防雷保护,环境等级为IP54。
S9028PCR180RTN 价格&库存
很抱歉,暂时无法提供与“S9028PCR180RTN”相匹配的价格&库存,您可以联系我们找货
