CC-ACC-LCDW-70
CC-ACC-LCDW-70
    DIGIINTERNATIONAL
CC-ACC-LCDW-70 数据手册
COMPACT CORE MODULE WITH WIRELESS AND WIRED CONNECTIVITY DIGI CONNECTCARD FOR i.MX28 Cost-effective small-footprint System-on-Module solution delivers performance, lowpower operation and integrated 802.11a/b/g/n, Bluetooth 4.0 and Ethernet connectivity Based on the NXP i.MX28 processor family, the ConnectCard for i.MX28 is an ideal embedded platform solution for connected applications in medical and healthcare, energy, transportation and industrial/building automation. It offers easy design integration and unique peripheral/ interface flexibility in an extremely compact and cost-effective form factor. This module is suitable for a wide range of different devices, including battery powered product designs. The module is equipped with a highly integrated 32-bit ARM core running at up to 454 MHz, on-chip power management, dual Ethernet and 802.11a/b/g/n networking options, Bluetooth 4.0 connectivity, dual FlexCAN options, GPIO, ADC, UART, USB high-speed, SPI, I2C, I2S, 1-Wire, PWM and JTAG/ETM. The Digi JumpStart Kit® for Digi Embedded Linux provides a complete turnkey embedded development solution allowing immediate and successful product development with accelerated time-to-market and reduced design risk. BLOCK DIAGRAM PHY CONNECTIVITY i2C x 2 SPI x 4 UART x 6 U.FL EXT MEMORY I/F ADVANCED CONNECTIVITY 10/100 Ethernet IEEE 1588 x 2 L2 Switch 10/100 Ethernet IEEE 1588 x 2 HS USB Phy x 2 GPIO 802.11 a/b/g/n + BT4.0 PHY NAND CONNECTIVITY 16K I Cache PC x 2 LV-DDR2 EXT MEMORY I/F 32K D Cache 128KB SRAM SPI x 4 128KB ROM SECURITY UART x 6 POWER MANAGEMENT HAB4 L2 Switch USER I/F 128-bit AES SHA-2 Hashing LCD Controller DC/DC - 4.2V Timer x 4 AUDIO PS x 2 S/PDIFT x BENEFITS Touchscreen STANDARD SYSTEM LDO x 4 Battery Charger Up to 256 MB DDR2 DDR2 mDDR i.MX28 ARM926EJ-S 454 MHz MMC+/SD x 4 BCH 20-bit Watch Dog RTC PWM x 8 DMA SYSTEM DEBUG ETM Up to 2 GB NAND (SLC) JTAG LCD/ Touch Connector Scaling Alpha Blending Rotation Color Space Conversion 52-Position Edge Connectore – Cost-effective design in compact form factor – 32-bit ARM processor at up to 454 MHz – Single/dual 10/100 Ethernet connectivity options – Pre-approved 802.11a/b/g/n Wi-Fi + Bluetooth 4.0 - Includes Wi-Fi® Access Point mode + Wi-Fi Direct™ - Support for Bluetooth 3.0 + HS and Bluetooth LE - Ready for Cisco CCX and Wi-Fi Logo certification – Digi Embedded Linux platform - Digi Remote Manager ® enabled - Includes complete Digi BSP source code RELATED PRODUCTS – Long-term product availability – Additional ZigBee®, 802.15.4, cellular and satellite connectivity options (off-module) ConnectCore® 6 ConnectCore® for i.MX53 ConnectCore® 6 SBC Digi XBee® Development Kits OVERVIEW ConnectCard™ i.MX28 | ConnectCard™ Wi-i.MX28 PROCESSOR PROCESSOR MODELS NXP® i.MX280, i.MX287 SPEED GRADE Up to 454 MHz CORE TYPE ARM926EJ-S CACHE MEMORY 16k I-Cache, 32k D-Cache INTERNAL RAM 128 KB SRAM INTERNAL ROM (OCOTP) 1,280 Bits MEMORY FLASH Up to 2 GB NAND flash RAM Up to 256 MB DDR2 DEBUG JTAG Yes ETM/ETB Yes POWER MANAGEMENT POWER MODES Run, Standby, Deep Sleep WAKE-UP EVENTS RTC, GPIO, CAN, USB, Ethernet AUTO SLOW Yes LI-ION BATTERY CHARGER / MONITOR Yes CLOCK AND WATCHDOG REAL-TIME CLOCK Yes ALARM Yes WATCHDOG Yes SECURITY DATA CO-PROCESSOR (DCP) 128-bit AES encryption; SHA-1 / SHA256 hashing FUSEBOX (OCOTP) 1280 bits HIGH-ASSURANCE BOOT (HAB4) Yes SECURE BOOT 128-bit AES decryption PERIPHERALS UART Up to 4 channels with bit rates up to 3.25 Mbps (AUART) Up to 1 channel with bit rate up to 115 kbps (DUART) CAN BUS Up to 2 channels, CAN Bus 2.0B, bit rates up to 1 Mbps, 64 message buffers (0-8 bytes), low-power modes with wake-up SPI Up to 2, master/slave modes I2S Up to 1 I2C Up to 2 channels, master/slave (7-/10-bit addressing), standard (100 kbps) and fast (400 kbps) mode SD/SDIO/MMC Up to 4 ports, 1-/4-/8-bit modes, up to 48 MHz USB 2.0 HIGH-SPEED Up to 1 USB 2.0 High-Speed Host (with PHY) ; Up to 1 USB 2.0 OTG port (with PHY) 1-WIRE Maxim DS2482-100+ PWM Up to 4 ADC HSADC: Up to 1 channel, up to 2 Mbps sample rate, 8-/10-/12-bit resolution LRADC: Up to 6 channels, 12-bit resolution GPIO Up to 128 GPIOs, selectable voltage (1.8/3.3V), interrupt capable WWW.DIGI.COM SPECIFICATIONS SPECIFICATIONS ConnectCard™ i.MX28 | ConnectCard™ Wi-i.MX28 DISPLAY RESOLUTION 800x480 (WVGA) REFRESH RATE Up to 60 Hz COLOR DEPTH 8/16/24 bpp MODES RGB/DOTCK/SYSTEM COLOR SPACE CONVERSION Yes SCALING Yes ROTATION Yes TOUCH SCREEN TOUCH SCREEN CONTROLLER 4-/5-wire (LRADC) ETHERNET PHYSICAL LAYER 10/100Base-T DATA RATES 10/100 Mbps, auto-sensing DUPLEX MODE Full or half duplex, auto-sensing IEEE 1588 Yes (i.MX287 only) POWER OVER ETHERNET (802.3AF) POWER OVER ETHERNET Development board ready for 802.3af PoE application kit (sold separately) WI-FI2 STANDARD N/A 802.11a/b/g/n ANTENNA CONNECTORS N/A 2 x U.FL DUAL DIVERSITY N/A Yes FREQUENCY BANDS N/A 2.412 - 2.484 GHz; 4.900 - 5.850 GHz DATA RATES N/A 802.11b: 1, 2, 5.5, 11 Mbps 802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11n: 15, 30, 45, 60, 90, 120, 135, 150 Mbps (HT40, MCS 0-7) MODULATION N/A DBPSK, DQPSK, CCK, BPSK, QPSK, 16-QAM, 64-QAM TRANSMIT POWER (±2 DBM) N/A 802.11b: 17 dBm typical 802.11g/n: 15 dBm typical 802.11a/n: 12 dBm typical SECURITY N/A WEP, WPA-PSK/WPA2-Personal, WPA/WPA2 Enterprise, 802.11i WI-FI LOGO CERTIFICATION N/A Ready CCXV4 ASD N/A Ready MODES N/A Bluetooth 4.0 (Bluetooth 2.1 + EDR, Bluetooth 3.0 + HS 802.11 AMP, Bluetooth Low Energy) CLASS N/A 1.5 PROFILES N/A GAP, SPP, HSP, HFP, FTP, PAN, OPP, HID, A2DP, AVRCP, HDP COEXISTENCE N/A Yes BLUETOOTH2 WWW.DIGI.COM SPECIFICATIONS SPECIFICATIONS ConnectCard™ i.MX28 | ConnectCard™ Wi-i.MX28 POWER REQUIREMENTS (USE-CASE ESTIMATES) WI-FI 2.4 GHZ TRANSMIT, CPU 454 MHZ @ 50%, UART ACTIVE 406 mA @ 5V WI-FI 2.4 GHZ RECEIVE, CPU IDLE (AUTO SLOW) 100 mA @ 5V WI-FI STANDBY (SLEEP), CPU STANDBY (IRQ) 8 mA @ 5V WI-FI STANDBY (HOST OFF), CPU DEEP SLEEP (RTC) 112 µA @ 5V MODULE VARIANTS1 POPULATION OPTIONS Processor models (i.MX280, i.MX281, i.MX283, i.MX285, i.MX286, i.MX287), flash, RAM, Single 10/100 Ethernet, dual 10/100 Ethernet w/1588, 802.11a/b/g/n Wi-Fi with Bluetooth 4.0, 1-Wire, LCD connector, CAN bus MECHANICAL DIMENSIONS (L X W X H) W/O JTAG/LCD CONNECTOR 51 mm x 35 mm x 2.6 mm MATING CONNECTOR FOR MODULE Molex, P/N 67910-5700; Tyco, P/N 2041119-x RETAINING CLIP FOR MODULE (OPTIONAL) Molex, P/N 480995701; Tyco, P/N 1717832 JTAG/LCD CONNECTOR ON MODULE (OPTIONAL) FCI, P/N SFV31R-1STE1LF; Tyco, P/N 3-1734839-1 51 mm x 35 mm x 3 mm ENVIRONMENTAL OPERATING TEMPERATURE -40° C up to +85° C (-40° F to +185° F) Upper temperature ceilings may require active and/or passive thermal management such as lower clock speed, thermal pads, airflow, etc. STORAGE TEMPERATURE -40° C up to +85° C (-40° F to +185° F) RELATIVE HUMIDITY 5% to 90% (non-condensing) APPROVALS AND CERTIFICATIONS EMISSIONS FCC Part 15 Class B, EN 55022 Class B, EN 61000-3-2, EN 61000-3-3, ICES-003 Class B, VCCI Class II, AS 3548, FCC Part 15 Subpart C Section 15.247, IC (Industry Canada), RSS-210 Issue 5 Section 6.2.2(o), EN 300 328, EN 301 489-17 IMMUNITY EN 55024, EN 301 489-3 SAFETY UL/UR, or equivalent RADIO US, Canada, EU, Japan, Australia/New Zealand TEMPERATURE IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-78 VIBRATION/SHOCK IEC 60068-2-6, IEC 60068-2-64, IEC 60068-2-27 DESIGN TEST HALT WARRANTY PRODUCT WARRANTY 1 2 3 years All options available on development module. Production modules may require custom variants. Contact your local distributor or Digi sales office for details. Transmit power and channel availability depending on regulatory requirements and corresponding module variants. WWW.DIGI.COM PRODUCT DIMENSIONS PART NUMBERS DESCRIPTION KITS CC-ACC-LCDW-70 7” WVGA LCD application kit w/resistive touch screen for ConnectCore for i.MX51/i.MX53 and ConnectCard for i.MX28 family MODULES CC-WMX-PF47-VM ConnectCard for i.MX28 module, i.MX287, 454 MHz, up to 85°C, 128 MB flash, 128 MB DDR2, 802.11abgn, Ethernet, LCD CC-WMX-PF58-JT ConnectCard for i.MX28 module, i.MX287, 454 MHz, up to 85°C, 256 MB flash, 256 MB DDR2, 802.11a/b/g/n, Bluetooth 4.0, dual Ethernet, LCD CC-WMX-PF58-QK ConnectCard for i.MX28 module, i.MX287, 454 MHz, up to 85°C, 256 MB flash, 256 MB DDR2, 802.11a/b/g/n, Bluetooth 4.0, dual Ethernet, LCD (International) CC-MX-PF47-ZK ConnectCore for i.MX28 module, i.MX287, 454 MHz, up to 85°C, 128 MB flash, 128 MB DDR2, dual Ethernet, LCD CC-MX-PF58-ZK ConnectCore for i.MX28 module, i.MX287, 454 MHz, up to 85°C, 256 MB flash, 256 MB DDR2, dual Ethernet, LCD CC-WMX-PE47-JT ConnectCard for i.MX28 module, i.MX280, 454 MHz, up to 85°C, 128 MB flash, 128 MB DDR2, 802.11abgn, Ethernet DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91001903 B8/120 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: DIGI: CC-WMX28-LX CC-WMX-PF58-VM CC-MX-PE47-ZM CC-MX-PF47-ZM
CC-ACC-LCDW-70 价格&库存
很抱歉,暂时无法提供与“CC-ACC-LCDW-70”相匹配的价格&库存,您可以联系我们找货
