S8658WPR240RTN
S8658WPR240RTN
    LAIRD(莱尔德)
    ANT865-965MHZ9DBIRHRP-TNCM-M
S8658WPR240RTN 数据手册
S8658WPR S8658WPL Circular Polarity Wide Band RFID Panel Antenna l The Laird S8658WPR antenna is a circularly polarized panel antenna that provides reception and transmission of signals in the 865-960 MHz frequency band. Laird's industry renowned design methodology achieves maximum efficiency and performance across the entire frequency band. Both VSWR and axial ratios are both excellent and allow the user to achieve the maximum performance for an antenna of this type. The antenna is housed in a heavy duty radome enclosure that can be directly wall mounted. An optional articulating mount allows either wall or mast mounting. The antenna is offered with an integrated coax pigtail and a variety of connector types are available. 340 0 350 10 s s • Low profile • Extremely low VSWR and axial ratio • Warehouse • Distribution center • Wide band • Weather and UV resistant radome • Airports and hospitals • Transit terminals • Wide range of connector and cable options • Left hand and right hand CP versions • Conveyer belt SPECIFICATIONS 20 330 30 320 40 310 50 300 60 290 70 280 80 270 -20 -10 90 0 d B 260 100 250 110 240 120 230 130 220 140 210 150 200 190 180 170 160 902 MHz Antenna Part Number S8658WPR and S8658WPL Frequency Range 865 - 960 MHz Gain 8.5 dBic Maxium VSWR 1.4:1 3 dB Beamwidth - Azimuth 65° Front to Back Ratio 20 dB Polarization Circular Right-hand or circular Left-hand Maxium Input Power 3 Watts Input Impedence 50 Ohms Axial Ratio 1dB Weight (Kg) 2.5 lbs (1.13) Mechanical Size (mm) 10.2” x 10.2” x 1.32” (259 x 259 x 34) Antenna Connection Coax Pigtail, Rev TNC Male (others available) Radome High Strength PC Mount Style Threaded Stud Temperature Operational -25°C to +70°C Lightning Protection DC Grounded Environmental Rating IP 54 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.co Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-S8658WPR S8658WPL_0915 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
S8658WPR240RTN 价格&库存
很抱歉,暂时无法提供与“S8658WPR240RTN”相匹配的价格&库存,您可以联系我们找货
