BBU27-140K
BBU27-140K
    EATON(伊顿)
    FUSE PWR 140K 27KV BBU-20
BBU27-140K 数据手册
Bussmann® Boric Acid Fuses BBU Medium Voltage General • The BBU power fuse is a Boric Acid, expulsion style fuse unit. • Provides a low initial cost alternative to refillable fuses in indoor applications. • Utilizes calibrated silver elements, boric acid for its interrupting media, and a spring & rod mechanism. • The housing is a fiberglass reinforced resin tube with plated copper contacts. • Available in 3 maximum voltage classes: 17kV, 27kV & 38kV • Available in 3 speed variations: E (Standard) SE (Slow E) & K (Fast) • Visual Indicating with use of end fittings. • End Fittings: • End fittings are required to complete the electrical connection between the fuse unit and the live parts and mounting. • The indoor fittings accept a Muffler attachment to limit noise and contamination to indoor equipment. The open fuse indicator located on the top end fitting provides visual indication on a faulted fuse unit. Catalog Symbol: BBU Medium Voltage Expulsion Fuse Fuse Class: E (Standard), SE (Slow E) & K (Fast) Voltage Rating: 17kV, 27kV & 38kV Interrupting Ratings: 17kV - 14kA 27kV - 12.5kA 38kV - 10kA Boric Acid, expulsion style fuses meet: • ANSI C37.40 – Service Conditions and Definitions • ANSI C37.41 – Power Fuse Design and Testing • ANSI C37.42 – Distribution Fuse Ratings and Specifications • ANSI C37.46 – Power Fuse Ratings and Specifications • ANSI C37.48 – Power Fuse Application, Operations and Maintenance 5-30-02 SB02199 Applications The BBU Boric Acid fuse provides effective protection for circuits and equipment which operate on voltage systems up to 34,500V. Typical usage is on industrial distribution systems for: • Power Transformers • Feeder Circuits • Distribution Transformers • Metal Enclosed Switchgear • Pad Mounted Switches Form No. BBU Page 1 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Illustration & Diimensional Data 1.244 DIA. kV Max. 17 27 38 5-30-02 SB02199 Fuse Unit Fittings A B C 19.08 22.58 28.76 27.19 30.69 36.87 28.82 32.32 38.50 Form No. BBU Page 2 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage BBU Boric Acid Fuses for Use Indoors 5-30-02 SB02199 Catalog Number Ampere Rating 5E to 200E BBU-EFID BBU-EFID 15SE to 200SE BBU-EFID 3K to 200K BBU-EFID 5E to 200E BBU-EFID BBU27-50E 12.5 BBU27-65E BBU27-80E BBU27-100E BBU27-125E BBU27-150E BBU27-175E BBU27-200E BBU27-15SE BBU27-20SE BBU27-25SE BBU27-30SE BBU27-40SE BBU27-50SE BBU27-65SE BBU27-80SE 12.5 BBU27-100SE BBU27-125SE BBU27-150SE BBU27-175SE BBU27-200SE BBU38-3K BBU38-6K BBU38-8K BBU38-10K BBU38-12K BBU38-15K BBU38-20K 10 BBU38-30K BBU38-40K BBU38-50K BBU38-65K BBU38-80K BBU38-100K BBU38-140K BBU38-200K BBU38-5E BBU38-7E BBU38-10E BBU38-13E BBU38-15E BBU38-20E BBU38-25E BBU38-30E BBU38-40E BBU38-50E 10 BBU38-65E BBU38-80E BBU38-100E BBU38-125E BBU38-150E BBU38-175E BBU38-200E BBU38-15SE BBU38-20SE BBU38-25SE BBU38-30SE BBU38-40SE BBU38-50SE BBU38-65SE BBU38-80SE 10 BBU38-100SE BBU38-125SE BBU38-150SE BBU38-175SE BBU38-200SE 15SE to 200SE 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 End Fittings Voltage (kV) E E E E E E E E SE SE SE SE SE SE SE SE SE SE SE SE SE K K K K K K K K K K K K K K K E E E E E E E E E E E E E E E E E SE SE SE SE SE SE SE SE SE SE SE SE SE Max. Int. kA Sym Fuse Type 50 65 80 100 125 150 175 200 15 20 25 30 40 50 65 80 100 125 150 175 200 3 6 8 10 12 15 20 30 40 50 65 80 100 140 200 5 7 10 13 15 20 25 30 40 50 65 80 100 125 150 175 200 15 20 25 30 40 50 65 80 100 125 150 175 200 Catalog Number Amps Catalog Number Ampere Rating 3K to 200K BBU-EFID BBU-EFID 5E to 200E BBU-EFID 15SE to 200SE BBU-EFID 3K to 200K BBU-EFID BBU17-3K BBU17-6K BBU17-8K BBU17-10K BBU17-12K BBU17-15K BBU17-20K 14 BBU17-25K BBU17-30K BBU17-40K BBU17-50K BBU17-65K BBU17-80K BBU17-100K BBU17-140K BBU17-200K BBU17-5E BBU17-7E BBU17-10E BBU17-13E BBU17-15E BBU17-20E BBU17-25E BBU17-30E 14 BBU17-40E BBU17-50E BBU17-65E BBU17-80E BBU17-100E BBU17-125E BBU17-150E BBU17-175E BBU17-200E BBU17-15SE BBU17-20SE BBU17-25SE BBU17-30SE BBU17-40SE BBU17-50SE BBU17-65SE 14 BBU17-80SE BBU17-100SE BBU17-125SE BBU17-150SE BBU17-175SE BBU17-200SE BBU27-3K BBU27-6K BBU27-8K BBU27-10K BBU27-12K BBU27-15K BBU27-20K BBU27-25K BBU27-30K 12.5 BBU27-40K BBU27-50K BBU27-65K BBU27-80K BBU27-100K BBU27-140K BBU27-200K BBU27-5E BBU27-7E BBU27-10E BBU27-13E BBU27-15E BBU27-20E BBU27-25E BBU27-30E BBU27-40E Indoor 5E to 200E 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 End Fittings Voltage (kV) K K K K K K K K K K K K K K K K E E E E E E E E E E E E E E E E E SE SE SE SE SE SE SE SE SE SE SE SE SE K K K K K K K K K K K K K K K K E E E E E E E E E Max. Int. kA Sym Fuse Type 3 6 8 10 12 15 20 25 30 40 50 65 80 100 140 200 5 7 10 13 15 20 25 30 40 50 65 80 100 125 150 175 200 15 20 25 30 40 50 65 80 100 125 150 175 200 3 6 8 10 12 15 20 25 30 40 50 65 80 100 140 200 5 7 10 13 15 20 25 30 40 Catalog Number Amps Indoor *Note: Muffler can be ordered separately. Order Catalog number BBU-MFLR. Form No. BBU ˆPage 3 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 4 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 5 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 6 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 7 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 8 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 9 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 10 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 11 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage Time Current Characteristics 5-30-02 SB02199 Form No. BBU Page 12 of 13 Data Sheet: 1123 Bussmann® Boric Acid Fuses BBU Medium Voltage BBU Cross Reference Charts Bussmann® S&C Bussmann® S&C Bussmann® S&C BBU17-3K BBU17-6K BBU17-8K BBU17-10K BBU17-12K BBU17-15K BBU17-20K BBU17-25K BBU17-30K BBU17-40K BBU17-50K BBU17-65K BBU17-80K BBU17-100K BBU17-140K BBU17-200K BBU17-5E BBU17-7E BBU17-10E BBU17-13E BBU17-15E BBU17-20E BBU17-25E BBU17-30E BBU17-40E BBU17-50E BBU17-65E BBU17-80E BBU17-100E BBU17-125E BBU17-150E BBU17-175E BBU17-200E BBU17-15SE BBU17-20SE BBU17-25SE BBU17-30SE BBU17-40SE BBU17-50SE BBU17-65SE BBU17-80SE BBU17-100SE BBU17-125SE BBU17-150SE BBU17-175SE BBU17-200SE 702003 702006 702008 702010 702012 702015 702020 702025 702030 702040 702050 702065 702080 702100 702140 702200 612005 612007 612010t 612013 612015 612020 612025 612030 612040 612050 612065 612080 612100 612125 612150 612175 612200 712015 712020 712025 712030 712040 712050 712065 712080 712100 712125 712150 712175 712200 BBU27-3K BBU27-6K BBU27-8K BBU27-10K BBU27-12K BBU27-15K BBU27-20K BBU27-25K BBU27-30K BBU27-40K BBU27-50K BBU27-65K BBU27-80K BBU27-100K BBU27-140K BBU27-200K BBU27-5E BBU27-7E BBU27-10E BBU27-13E BBU27-15E BBU27-20E BBU27-25E BBU27-30E BBU27-40E BBU27-50E BBU27-65E BBU27-80E BBU27-100E BBU27-125E BBU27-150E BBU27-175E BBU27-200E BBU27-15SE BBU27-20SE BBU27-25SE BBU27-30SE BBU27-40SE BBU27-50SE BBU27-65SE BBU27-180SE BBU27-100SE BBU27-125SE BBU27-150SE BBU27-175SE BBU27-200SE 703003 703006 703008 703010 703012 703015 703020 703025 703030 703040 703050 703065 703080 703100 703140 703200 613005 613007 613010 613013 613015 613020 613025 613030 613040 613050 613065 613080 613100 613125 613150 613175 613200 713015 713020 713025 713030 713040 713050 713065 713080 713100 713125 713150 713175 713200 BBU38-3K BBU38-6K BBU38-8K BBU38-10K BBU38-12K BBU38-15K BBU38-20K BBU38-25K BBU38-30K BBU38-40K BBU38-50K BBU38-65K BBU38-80K BBU38-100K BBU38-140K BBU38-200K BBU38-5E BBU38-7E BBU38-10E BBU38-13E BBU38-15E BBU38-20E BBU38-25E BBU38-30E BBU38-40E BBU38-50E BBU38-65E BBU38-80E BBU38-100E BBU38-125E BBU38-150E BBU38-175E BBU38-200E BBU38-15SE BBU38-20SE BBU38-25SE BBU38-30SE BBU38-40SE BBU38-50SE BBU38-65SE BBU38-80SE BBU38-100SE BBU38-125SE BBU38-150SE BBU38-175SE BBU38-200SE BBU-EFID 704003 704006 704008 704010 704012 704015 704020 704025 704030 704040 704050 704065 704080 704100 704140 704200 614005 614007 614010 614013 614015 614020 614025 614030 614040 614050 614065 614080 614100 614125 614150 614175 614200 714015 714020 714025 714030 714040 714050 714065 714080 714100 714125 714150 714175 714200 3097 5-30-02 SB02199 Form No. BBU Page 13 of 13 Data Sheet: 1123
BBU27-140K
物料型号:Bussmann® BBU
器件简介:BBU是Boric Acid, expulsion style fuse unit,即硼酸喷射型熔断器单元。它是一种低压成本的室内应用替代品,使用校准的银元素、硼酸作为截断介质,以及弹簧和杆机制。
引脚分配:文档中提供了BBU熔断器单元的端接件定位销和定位槽的说明,但未提供具体的引脚分配图。
参数特性: - 电压等级:17kV、27kV和38kV - 截断等级:17kV - 14kA、27kV - 12.5kA、38kV - 10kA - 符合多项ANSI标准,包括服务条件和定义、电力熔断器设计和测试、配电熔断器额定值和规格等 - 可用在3种最大电压等级和3种速度变化:E(标准)、SE(慢E)和K(快)
功能详解:BBU熔断器单元具有视觉指示功能,使用端接件进行指示。室内端接件可接受消音器附件以限制噪音和室内设备的污染。顶部端接件上的开放熔断器指示器提供故障熔断器单元的视觉指示。
应用信息:BBU硼酸熔断器为高达34,500V的电压系统上的电路和设备提供有效保护。典型应用包括工业配电系统、电力变压器、馈线电路、配电变压器、金属封闭开关设备和垫装开关。
封装信息:文档提供了BBU熔断器单元的尺寸和端接件信息,包括最大直径和长度。
BBU27-140K 价格&库存
很抱歉,暂时无法提供与“BBU27-140K”相匹配的价格&库存,您可以联系我们找货
BBU27-140K
  • 1+11581.686031+1498.92985
