Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
General
• The BBU power fuse is a Boric Acid, expulsion style
fuse unit.
• Provides a low initial cost alternative to refillable fuses
in indoor applications.
• Utilizes calibrated silver elements, boric acid for its interrupting media, and a spring & rod mechanism.
• The housing is a fiberglass reinforced resin tube with plated
copper contacts.
• Available in 3 maximum voltage classes:
17kV, 27kV & 38kV
• Available in 3 speed variations:
E (Standard) SE (Slow E) & K (Fast)
• Visual Indicating with use of end fittings.
• End Fittings:
• End fittings are required to complete the electrical
connection between the fuse unit and the live parts
and mounting.
• The indoor fittings accept a Muffler attachment to
limit noise and contamination to indoor equipment.
The open fuse indicator located on the top end fitting provides visual indication on a faulted fuse unit.
Catalog Symbol: BBU
Medium Voltage Expulsion Fuse
Fuse Class: E (Standard), SE (Slow E) & K (Fast)
Voltage Rating: 17kV, 27kV & 38kV
Interrupting Ratings:
17kV - 14kA
27kV - 12.5kA
38kV - 10kA
Boric Acid, expulsion style fuses meet:
• ANSI C37.40 – Service Conditions and Definitions
• ANSI C37.41 – Power Fuse Design and Testing
• ANSI C37.42 – Distribution Fuse Ratings and Specifications
• ANSI C37.46 – Power Fuse Ratings and Specifications
• ANSI C37.48 – Power Fuse Application, Operations and
Maintenance
5-30-02
SB02199
Applications
The BBU Boric Acid fuse provides effective protection for circuits and equipment which operate on voltage systems up to
34,500V. Typical usage is on industrial distribution systems for:
• Power Transformers
• Feeder Circuits
• Distribution Transformers
• Metal Enclosed Switchgear
• Pad Mounted Switches
Form No. BBU
Page 1 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
Illustration & Diimensional Data
1.244
DIA.
kV
Max.
17
27
38
5-30-02
SB02199
Fuse Unit Fittings
A
B
C
19.08
22.58
28.76
27.19
30.69
36.87
28.82
32.32
38.50
Form No. BBU
Page 2 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
BBU Boric Acid Fuses for Use Indoors
5-30-02
SB02199
Catalog Number
Ampere Rating
5E to 200E
BBU-EFID
BBU-EFID
15SE to 200SE
BBU-EFID
3K to 200K
BBU-EFID
5E to 200E
BBU-EFID
BBU27-50E 12.5
BBU27-65E
BBU27-80E
BBU27-100E
BBU27-125E
BBU27-150E
BBU27-175E
BBU27-200E
BBU27-15SE
BBU27-20SE
BBU27-25SE
BBU27-30SE
BBU27-40SE
BBU27-50SE
BBU27-65SE
BBU27-80SE 12.5
BBU27-100SE
BBU27-125SE
BBU27-150SE
BBU27-175SE
BBU27-200SE
BBU38-3K
BBU38-6K
BBU38-8K
BBU38-10K
BBU38-12K
BBU38-15K
BBU38-20K
10
BBU38-30K
BBU38-40K
BBU38-50K
BBU38-65K
BBU38-80K
BBU38-100K
BBU38-140K
BBU38-200K
BBU38-5E
BBU38-7E
BBU38-10E
BBU38-13E
BBU38-15E
BBU38-20E
BBU38-25E
BBU38-30E
BBU38-40E
BBU38-50E
10
BBU38-65E
BBU38-80E
BBU38-100E
BBU38-125E
BBU38-150E
BBU38-175E
BBU38-200E
BBU38-15SE
BBU38-20SE
BBU38-25SE
BBU38-30SE
BBU38-40SE
BBU38-50SE
BBU38-65SE
BBU38-80SE
10
BBU38-100SE
BBU38-125SE
BBU38-150SE
BBU38-175SE
BBU38-200SE
15SE to 200SE
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
38
End Fittings
Voltage (kV)
E
E
E
E
E
E
E
E
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
K
K
K
K
K
K
K
K
K
K
K
K
K
K
K
E
E
E
E
E
E
E
E
E
E
E
E
E
E
E
E
E
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
Max. Int. kA Sym
Fuse Type
50
65
80
100
125
150
175
200
15
30
40
50
65
80
100
125
150
175
200
3
6
8
10
12
15
40
50
65
80
100
140
200
5
7
10
13
15
30
40
50
65
80
100
125
150
175
200
15
30
40
50
65
80
100
125
150
175
200
Catalog
Number
Amps
Catalog Number
Ampere Rating
3K to 200K
BBU-EFID
BBU-EFID
5E to 200E
BBU-EFID
15SE to 200SE
BBU-EFID
3K to 200K
BBU-EFID
BBU17-3K
BBU17-6K
BBU17-8K
BBU17-10K
BBU17-12K
BBU17-15K
BBU17-20K
14
BBU17-25K
BBU17-30K
BBU17-40K
BBU17-50K
BBU17-65K
BBU17-80K
BBU17-100K
BBU17-140K
BBU17-200K
BBU17-5E
BBU17-7E
BBU17-10E
BBU17-13E
BBU17-15E
BBU17-20E
BBU17-25E
BBU17-30E
14
BBU17-40E
BBU17-50E
BBU17-65E
BBU17-80E
BBU17-100E
BBU17-125E
BBU17-150E
BBU17-175E
BBU17-200E
BBU17-15SE
BBU17-20SE
BBU17-25SE
BBU17-30SE
BBU17-40SE
BBU17-50SE
BBU17-65SE
14
BBU17-80SE
BBU17-100SE
BBU17-125SE
BBU17-150SE
BBU17-175SE
BBU17-200SE
BBU27-3K
BBU27-6K
BBU27-8K
BBU27-10K
BBU27-12K
BBU27-15K
BBU27-20K
BBU27-25K
BBU27-30K 12.5
BBU27-40K
BBU27-50K
BBU27-65K
BBU27-80K
BBU27-100K
BBU27-140K
BBU27-200K
BBU27-5E
BBU27-7E
BBU27-10E
BBU27-13E
BBU27-15E
BBU27-20E
BBU27-25E
BBU27-30E
BBU27-40E
Indoor
5E to 200E
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
27
End Fittings
Voltage (kV)
K
K
K
K
K
K
K
K
K
K
K
K
K
K
K
K
E
E
E
E
E
E
E
E
E
E
E
E
E
E
E
E
E
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
SE
K
K
K
K
K
K
K
K
K
K
K
K
K
K
K
K
E
E
E
E
E
E
E
E
E
Max. Int. kA Sym
Fuse Type
3
6
8
10
12
15
30
40
50
65
80
100
140
200
5
7
10
13
15
30
40
50
65
80
100
125
150
175
200
15
30
40
50
65
80
100
125
150
175
200
3
6
8
10
12
15
30
40
50
65
80
100
140
200
5
7
10
13
15
30
40
Catalog
Number
Amps
Indoor
*Note: Muffler can be ordered separately. Order Catalog number
BBU-MFLR.
Form No. BBU
ˆPage 3 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
Time Current Characteristics
5-30-02
SB02199
Form No. BBU
Page 4 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 5 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 6 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 7 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 8 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 9 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 10 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 11 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
5-30-02
SB02199
Form No. BBU
Page 12 of 13
Data Sheet: 1123
Bussmann®
Boric Acid Fuses
BBU
Medium Voltage
BBU Cross Reference Charts
Bussmann®
S&C
Bussmann®
S&C
Bussmann®
S&C
BBU17-3K
BBU17-6K
BBU17-8K
BBU17-10K
BBU17-12K
BBU17-15K
BBU17-20K
BBU17-25K
BBU17-30K
BBU17-40K
BBU17-50K
BBU17-65K
BBU17-80K
BBU17-100K
BBU17-140K
BBU17-200K
BBU17-5E
BBU17-7E
BBU17-10E
BBU17-13E
BBU17-15E
BBU17-20E
BBU17-25E
BBU17-30E
BBU17-40E
BBU17-50E
BBU17-65E
BBU17-80E
BBU17-100E
BBU17-125E
BBU17-150E
BBU17-175E
BBU17-200E
BBU17-15SE
BBU17-20SE
BBU17-25SE
BBU17-30SE
BBU17-40SE
BBU17-50SE
BBU17-65SE
BBU17-80SE
BBU17-100SE
BBU17-125SE
BBU17-150SE
BBU17-175SE
BBU17-200SE
702003
702006
702008
702010
702012
702015
702020
702025
702030
702040
702050
702065
702080
702100
702140
702200
612005
612007
612010t
612013
612015
612020
612025
612030
612040
612050
612065
612080
612100
612125
612150
612175
612200
712015
712020
712025
712030
712040
712050
712065
712080
712100
712125
712150
712175
712200
BBU27-3K
BBU27-6K
BBU27-8K
BBU27-10K
BBU27-12K
BBU27-15K
BBU27-20K
BBU27-25K
BBU27-30K
BBU27-40K
BBU27-50K
BBU27-65K
BBU27-80K
BBU27-100K
BBU27-140K
BBU27-200K
BBU27-5E
BBU27-7E
BBU27-10E
BBU27-13E
BBU27-15E
BBU27-20E
BBU27-25E
BBU27-30E
BBU27-40E
BBU27-50E
BBU27-65E
BBU27-80E
BBU27-100E
BBU27-125E
BBU27-150E
BBU27-175E
BBU27-200E
BBU27-15SE
BBU27-20SE
BBU27-25SE
BBU27-30SE
BBU27-40SE
BBU27-50SE
BBU27-65SE
BBU27-180SE
BBU27-100SE
BBU27-125SE
BBU27-150SE
BBU27-175SE
BBU27-200SE
703003
703006
703008
703010
703012
703015
703020
703025
703030
703040
703050
703065
703080
703100
703140
703200
613005
613007
613010
613013
613015
613020
613025
613030
613040
613050
613065
613080
613100
613125
613150
613175
613200
713015
713020
713025
713030
713040
713050
713065
713080
713100
713125
713150
713175
713200
BBU38-3K
BBU38-6K
BBU38-8K
BBU38-10K
BBU38-12K
BBU38-15K
BBU38-20K
BBU38-25K
BBU38-30K
BBU38-40K
BBU38-50K
BBU38-65K
BBU38-80K
BBU38-100K
BBU38-140K
BBU38-200K
BBU38-5E
BBU38-7E
BBU38-10E
BBU38-13E
BBU38-15E
BBU38-20E
BBU38-25E
BBU38-30E
BBU38-40E
BBU38-50E
BBU38-65E
BBU38-80E
BBU38-100E
BBU38-125E
BBU38-150E
BBU38-175E
BBU38-200E
BBU38-15SE
BBU38-20SE
BBU38-25SE
BBU38-30SE
BBU38-40SE
BBU38-50SE
BBU38-65SE
BBU38-80SE
BBU38-100SE
BBU38-125SE
BBU38-150SE
BBU38-175SE
BBU38-200SE
BBU-EFID
704003
704006
704008
704010
704012
704015
704020
704025
704030
704040
704050
704065
704080
704100
704140
704200
614005
614007
614010
614013
614015
614020
614025
614030
614040
614050
614065
614080
614100
614125
614150
614175
614200
714015
714020
714025
714030
714040
714050
714065
714080
714100
714125
714150
714175
714200
3097
5-30-02
SB02199
Form No. BBU
Page 13 of 13
Data Sheet: 1123
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
FL3T12 BBU-MFLR FL11T20 BBU-EFOD FL11T100 FL3T200 FL11T200 FL11T30 FL11T12 FL11T140
FL11T25 FL11T10 FL3T30 BBU27-140K BBU-EFID FL11T15 FL3T140
很抱歉,暂时无法提供与“BBU-MFLR”相匹配的价格&库存,您可以联系我们找货
