7904-E
7904-E
    GREENLEECOMMUNICATIONS(格林利)
    DRIVER RIGHT ANGLE HYD KO
7904-E 数据手册
DRIVER-RIGHT ANGLE HYD KO (7904E) Metric Quick Draw 90 Driver, 2 Draw Studs, 1 Adapter, 1 Spacer and Case Cat No: 7904-E UPC No: 783310342991 Description • • • • • • • Compact, lightweight designfor portability and fast, easy one-person operation Develops 8 tons of hydraulic force for easy punching, even in 10-gauge stainless steel, depending on individual punch capacities Quick Draw is perfect for fast, straight-on front panel punching Quick Draw 90's right angle driver head rotates over 180degrees for maximum flexibility in tight working areas Quick Draw Flex allows unlimited driver orientation to simplify access to work area Can be used with non-roundpunches within the capacity of the tool (adapter may be required) U.S. Patent #6,772,521 Specifications • • • • Includes : 33786 UPC 33786 Quick Draw Hydraulic Punch Driver, 1614SS UPC 30043 Draw Stud-3/8 IN x 2-13/16 IN, 31872 UPC 31872 DrawStud-3/4 IN x 4-1/8 IN, 1924AA UPC 03248 Spacer-Short, 33967 UPC 33967 Stud Adapter-3/8 IN, 35202 UPC 35202 Plastic Case Sub Brand : Quick Draw 90 Type : Hydraulic, Metric Weight : 11.000 LB (5.000 KG)
7904-E 价格&库存
很抱歉,暂时无法提供与“7904-E”相匹配的价格&库存,您可以联系我们找货
