7904ESB
7904ESB
    GREENLEECOMMUNICATIONS(格林利)
    DRIVER-90 HYD W/PG PUNCH SET
7904ESB 数据手册
DRIVER-90 HYD W/PG PUNCH SET Metric Quick Draw 90 Driver, Slug-Buster Pg Punches and Dies 15.2 mm through 30.5 mm, 2 Draw Studs, 1 Adapter, 1 Spacerand Case Cat No: 7904ESB UPC No: 783310356158 Description • • • • • • • Compact, lightweight designfor portability and fast, easy one-person operation Develops 8 tons of hydraulic force for easy punching, even in 10-gauge stainless steel, depending on individual punch capacities Quick Draw is perfect for fast, straight-on front panel punching Quick Draw 90's right angle driver head rotates over 180degrees for maximum flexibility in tight working areas Quick Draw Flex allows unlimited driver orientation to simplify access to work area Can be used with non-roundpunches within the capacity of the tool (adapter may be required) U.S. Patent #6,772,521 Specifications • • • • Includes : 721-1/2 UPC 31756 1/2 IN Conduit Size Slug-Buster Punch, 14722 UPC 14722 1/2 IN Conduit Size Die, 31969 UPC 31969 Slug-Buster Punch, 32002 UPC 32002 Die, 31970 UPC 31970 Slug-Buster Punch, 32003 UPC 32003 Die,31971 UPC 31971 Slug-Buster Punch, 32004 UPC Sub Brand : Quick Draw 90 Type : Hydraulic Weight : 11.000 LB (5.000 KG)
7904ESB 价格&库存
很抱歉,暂时无法提供与“7904ESB”相匹配的价格&库存,您可以联系我们找货
