7904-ISO
7904-ISO
    GREENLEECOMMUNICATIONS(格林利)
    DRIVER-90 HYD W/ISO PUNCH SET
7904-ISO 数据手册
DRIVER-90 HYD W/ISO PUNCH SET Metric Quick Draw 90 Driver, Slug-Buster ISO Punches and Dies 16.2 mm through 40.5 mm, 2 Draw Studs, 1 Adapter, 1 Spacer and Case Cat No: 7904-ISO UPC No: 783310356165 Description • • • • • • • Compact, lightweight designfor portability and fast, easy one-person operation Develops 8 tons of hydraulic force for easy punching, even in 10-gauge stainless steel, depending on individual punch capacities Quick Draw is perfect for fast, straight-on front panel punching Quick Draw 90's right angle driver head rotates over 180degrees for maximum flexibility in tight working areas Quick Draw Flex allows unlimited driver orientation to simplify access to work area Can be used with non-roundpunches within the capacity of the tool (adapter may be required) U.S. Patent #6,772,521 Specifications • • • • Includes : 31971 UPC 31971 Slug-Buster Punch, 32004 UPC 32004 Die, 35162 UPC 35162 ISO16 Die, 35164UPC 35164 ISO-25 Die, 35168 UPC 35168 ISO-32 Die, 35159 ISO-40 Die, 33786 UPC 33786 QuickDraw 90 Hydraulic Punch Driver, 1614SS UPC 30043 Draw Stud-3/8 IN x 213/16 Sub Brand : Quick Draw 90 Type : Hydraulic Weight : 12.200 LB (5.500 KG)
7904-ISO 价格&库存
很抱歉,暂时无法提供与“7904-ISO”相匹配的价格&库存,您可以联系我们找货
7904-ISO
    • 1+15915.618341+2058.68576
