EF32FSA0N-1
EF32FSA0N-1
    REDLIONCONTROLS(美国红狮)
    FRONT NO FANS AC IN
EF32FSA0N-1 数据手册
EK32/EF32 Industrial Ethernet Switch Sixnet Networking Series 32 Port Industrial Ethernet Switch The Sixnet EK32 is an industrial Ethernet switch offering 32 total Ethernet ports including up to 6 super fast Gigabit ports and up to QRLVHLPPXQH¿EHURSWLFSRUWV,WVUXJJHGDQGFRPSDFW8FDVH¿WVLQWRVWDQGDUG(,$:(&2DQG(76,UDFNVIURP´WR´ QRLVHLPPXQH¿EHURSWLFSRUWV,WVUXJJHGDQGFRPSDFW8FDVH¿WVLQWRVWDQGDUG(,$:(&2DQG(76,UDFNVIURP´WR´ QRLVHLPPXQH¿EHURSWLFSRUWV,WVUXJJHGDQGFRPSDFW8FDVH¿WVLQWRVWDQGDUG(,$:(&2DQG(76,UDFNVIURP´WR´ ORDERING GUIDE ORDERIN ORDERING GUIDE PRODUCT HIGHLIGHTS HIGHLIGHTS PRODUCT „ „ „ 32 „total Ethernet ports including  ‡ ‡  Up to Up 6 Gigabit ports  ‡ to 6 Gigabit Designed to meet industrial standards „ REAL-TIME SECURE PERFORMANCE „ „ Real-Time-Ring™ or Rapid Spanning Tree (RSTP) for for „ Real-Time-Ring™ or Rapid Spanning Tree (RSTP) IDVWUHGXQGDQWULQJRUPHVKQHWZRUNV IDVWUHGXQGDQWULQJRUPHVKQHWZRUNV IDVWUHGXQGDQWULQJRUPHVKQHWZRUNV „ „ 6103YDQGYQHWZRUNPDQDJHPHQW „ 6103YDQGYQHWZRUNPDQDJHPHQW 6103YDQGYQHWZRUNPDQDJHPHQW „ „ SNMPv3 authentication & encryption for security „ „ „ 6103QRWL¿FDWLRQV WUDSV IRUUHSRUWRQHYHQW „ 6103QRWL¿FDWLRQV WUDSV IRUUHSRUWRQHYHQW 6103QRWL¿FDWLRQV WUDSV IRUUHSRUWRQHYHQW „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ a = Model Options Ž Ž Ž K = 26 fast Ethernet (FE) and 6 Gigibit (GE) ports Ž Ž Ž F = 32 fast Ethernet (FE) ports (no Gigabit) ‡ ‡ ‡ b = Style Options Ž) IURQWVW\OH(WKHUQHWLQIURQWSRZHU FRQVROHLQEDFN Ž) IURQWVW\OH(WKHUQHWLQIURQWSRZHU FRQVROHLQEDFN Ž) IURQWVW\OH(WKHUQHWLQIURQWSRZHU FRQVROHLQEDFN c = Case / Cooling Options Ž6 VHDOHG,3 QRIDQV  VHHGHUDWLQJ Ž6 VHDOHG,3 QRIDQV  VHHGHUDWLQJ Ž6 VHDOHG,3 QRIDQV  VHHGHUDWLQJ Ž7 IDQFRROHG,3 QRGHUDWLQJ Ž7 IDQFRROHG,3 QRGHUDWLQJ Ž7 IDQFRROHG,3 QRGHUDWLQJ ‡ ‡ ‡ ,*03IRU0XOWLFDVW¿OWHULQJ VQRRSLQJ TXHU\LQJ „ ,*03IRU0XOWLFDVW¿OWHULQJ VQRRSLQJ TXHU\LQJ ,*03IRU0XOWLFDVW¿OWHULQJ VQRRSLQJ TXHU\LQJ ddd = Power Options Ž'1 GXDOLQSXWVIRU9'& Ž'1 GXDOLQSXWVIRU9'& Ž'1 GXDOLQSXWVIRU9'& 9'& 9'& 9'& Ž$1 VLQJOHLQSXWIRU9$&9'& Ž$1 VLQJOHLQSXWIRU9$&9'& Ž$1 VLQJOHLQSXWIRU9$&9'& 9$&RU9'& 9$&RU9'& 9$&RU9'& 9/$1IRUFRQYHQLHQWWUDI¿FVHJUHJDWLRQ „ 9/$1IRUFRQYHQLHQWWUDI¿FVHJUHJDWLRQ 9/$1IRUFRQYHQLHQWWUDI¿FVHJUHJDWLRQ Broadcast & multicast storm protection „ RMON & port mirroring for advanced diagnostics „ Ž$$1 GXDO9$&9'& Ž$$1 GXDO9$&9'&with redundant internal supplies Ž$$1 GXDO9$&9'& „ „ „ „ EK/EF32 PART NUMBER = Ea32bcddd-1 ‡ ‡ ‡ Priority Queuing (QoS/CoS) for real-time operation „ Priority Queuing (QoS/CoS) for real-time operation 6HFXULW\ZLWK+773666/66+6103Y PRUH „ 6HFXULW\ZLWK+773666/66+6103Y PRUH 6HFXULW\ZLWK+773666/66+6103Y PRUH „ (DV\FRQ¿JXUDWLRQYLD:HE7HOQHWRU&/, „ (DV\FRQ¿JXUDWLRQYLD:HE7HOQHWRU&/, „ (DV\FRQ¿JXUDWLRQYLD:HE7HOQHWRU&/, „ )UHH¿HOGLQVWDOODEOH¿UPZDUHXSJUDGHVIRUHYHU „ )UHH¿HOGLQVWDOODEOH¿UPZDUHXSJUDGHVIRUHYHU „ )UHH¿HOGLQVWDOODEOH¿UPZDUHXSJUDGHVIRUHYHU RUGGED & RELIABLE HARDWARE „ ‡ ‡ ‡ including 4 combination ports ports ports including 4 combination  ‡ ‡ 8SWR¿EHURSWLFSRUWVIRUQRLVHLPPXQHOLQNV 8SWR¿EHURSWLFSRUWVIRUQRLVHLPPXQHOLQNV   ‡ 8SWR¿EHURSWLFSRUWVIRUQRLVHLPPXQHOLQNV „ „ „ P PART NUMBER EXAMPLE: 6SDFHHI¿FLHQW8UDFNPRXQWGHVLJQ „ 6SDFHHI¿FLHQW8UDFNPRXQWGHVLJQ 6SDFHHI¿FLHQW8UDFNPRXQWGHVLJQ Redundant AC and DC power options „ Relay „ output contact to signal alarms RS232 and USB ports ports for local „ RS232 and console USB console for management local managementEK Rugged corrosion-resistant aluminum enclosure „ :LGHWHPSHUDWXUHWRƒ&RSHUDWLRQ „ :LGHWHPSHUDWXUHWRƒ&RSHUDWLRQ :LGHWHPSHUDWXUHWRƒ&RSHUDWLRQ 6HDOHG,3RSWLRQSURWHFWVDJDLQVWLQJUHVV „ 6HDOHG,3RSWLRQSURWHFWVDJDLQVWLQJUHVV 6HDOHG,3RSWLRQSURWHFWVDJDLQVWLQJUHVV ZLWKGXDO9'&LQSXWVDQGVHDOHG,3 QRIDQV EK32FSD6N-1 ZLWKGXDO9'&LQSXWVDQGVHDOHG,3 QRIDQV ZLWKGXDO9'&LQSXWVDQGVHDOHG,3 QRIDQV )RUDFFHVVRULHVVHHQH[WSDJH )RUDFFHVVRULHVVHHQH[WSDJH )RUDFFHVVRULHVVHHQH[WSDJH EK32/EF32 Industrial Ethernet Switch Specifications ETHERNET PERFORMANCE „ 32 Ethernet „ ports with up to 6 Gigabit „ Managed, „ store & forward, wire-speed „ All IEEE „ 802.3 Ethernet protocols supported „ RJ45„ port speed auto-negotiation „ RJ45„ MDI/MDIX auto-crossover „ RJ45„TD and RD auto-polarity „ Typical „ latency (varies on load & settings)  ‡@100 ‡ Mbps: 5 us + frame time „ )XOORUKDOIGXSOH[RSHUDWLRQFRQ¿JXUDEOHSHUSRUW „ )XOORUKDOIGXSOH[RSHUDWLRQFRQ¿JXUDEOHSHUSRUW „ MAC„addresses supported 8192 „ Memory „ bandwidth 32 Gbps „ Ethernet „ isolation 1500 VRMS 1 minute „ Console „ ports – USB and RS232 (RJ45) 1 2 3 4 5 POWER INPUTINPUT POWER „ „ Input voltage standard options  ‡  ‡ 18-36 VDC (24 VDC nominal)  ‡  ‡ 36-75 VDC (+/-48 VDC nominal)  ‡  ‡ 90-264 VAC (110/220 VAC nominal)  ‡  ‡ 130-370 VDC (250 VDC nominal) „ „ Power options  ‡  ‡ Dual inputs or redundant supplies „ „ Input power consumption 35 W maximum ENVIRONMENTAL ENVIRON „ „ Operating temperature range: „ „ T option (fan cooled): -40 to +85 °C (no derating) (cold startup at -40 °C) „ 6RSWLRQ VHDOHG,3 WRƒ&ZDOOSRUWVOLQNHGDW „ 6RSWLRQ VHDOHG,3 WRƒ&ZDOOSRUWVOLQNHGDW or derate  ‡ WRƒ&ZLWK*LJDELWOLQNV  ‡ WRƒ&ZLWK*LJDELWOLQNV  ‡ WRƒ&ZLWK*LJDELWOLQNV  ‡ WRƒ&ZLWK*LJDELWOLQNV  ‡ WRƒ&ZLWK*LJDELWOLQNV  ‡ WRƒ&ZLWK*LJDELWOLQNV „ „ Storage temperature range -40 to +85 °C „ „ Humidity (non-condensing) 5 to 95% RH (optional conformal coating is available) ETHERNET PORTS „ Port „ Group 1  ‡16ports ‡ of 10/100 RJ45 STANDARDS STANDARDS CO COMPLIANCE (PENDING) „ Port „ Group 2 „ „ Electrical safety – EN61010-1, CE  ‡2  ‡ 10/100 RJ45 ports bonus „ „ EMC – FCC part 15, ICES-003; EN61000-6-4, -2, CE „ Port „ Group 3 „ „ RoHS and WEEE compliant  ‡(.PRGHOFRPELQDWLRQ*(SRUWVIRUFRSSHURU¿EHUOLQNV  ‡(.PRGHOFRPELQDWLRQ*(SRUWVIRUFRSSHURU¿EHUOLQNV „ „ ,62FHUWL¿HGFRPSDQ\ ,62FHUWL¿HGFRPSDQ\  ‡()PRGHOFRPELQDWLRQ)(SRUWVIRUFRSSHURU¿EHUOLQNV  ‡()PRGHOFRPELQDWLRQ)(SRUWVIRUFRSSHURU¿EHUOLQNV PHYSICAL PHYSICAL „ Port „ Group 4: „ 0RXQWLQJ±´WR´UDFNV(,$:(&2(76,VXSSRUWHG „ 0RXQWLQJ±´WR´UDFNV(,$:(&2(76,VXSSRUWHG  ‡EK  model: ‡ 2 Gigabit 10/100/1000 RJ45 ports „ „ Case – corrosion-resistant heavy-gauge aluminum  ‡EF model: ‡ 2 fast Ethernet 10/100 RJ45 ports „ „ Egress protection IP50 with S option or IP30 with T option „ :HLJKW W\SLFDO OEV NJ ±YDULHVVOLJKWO\E\PRGHO „ :HLJKW W\SLFDO OEV NJ ±YDULHVVOLJKWO\E\PRGHO „ Port „ Group 5 „ „ Dimensions – 1.75 x 17.3 x 12” (44.5 x 439.4 x 305.0 mm)  ‡8 fast  ‡Ethernet 10/100 RJ45 ETHERNET COMPLIANCE A ACCESSORIES „ IEEE „ 802.3z (Gigabit 1000 Mbps Ethernet connections) EK EK1-BRCKT-19 6HW  RI8´EUDFNHWV RQHVHWLQFOXGHG 6HW  RI8´EUDFNHWV RQHVHWLQFOXGHG „ IEEE „ 802.3u IEEE 802.3u (Fast Ethernet 100Mbps for newer devices) (Fast Ethernet 100Mbps for newer devices) EK EK1-BRCKT-23 Set (2) of 1U 23” EIA/WECO „ IEEE „ 802.3 (10Mbps Ethernet supports legacy devices) EK EK1-BRCKT-2324 Set (2) of 1U 23/24” EIA/WECO „ IEEE „ 802.3x (Full-Duplex with Flow Control) EK EK1-BRCKT-ETSI 6HW  RI8PP(76,EUDFNHWV 6HW  RI8PP(76,EUDFNHWV „ IEEE „ 802.1D/w IEEE 802.1D/w (Rapid (Rapid Spanning Spanning Tree forTree redundant for redundant rings rings EK EK1-BRCKT-WALL 6HW  RIZDOOEUDFNHWV 6HW  RIZDOOEUDFNHWV and Spanning Tree for interoperability) R RJ45-PLUG-16 Dust plugs for unused RJ45 port (16 pieces) „ IEEE „ 802.1p (Priority Queuing – QoS, CoS, ToS/DS) EK EK-CCOAT-1 Conformal coating – contact Sixnet for details GMFI GMFIBER-SFP-500 *LJDELW6)3¿EHUWUDQVFHLYHUPPP *LJDELW6)3¿EHUWUDQVFHLYHUPPP „ ,(((4 9/$1IRUWUDI¿FVHJUHJDWLRQ „ ,(((4 9/$1IRUWUDI¿FVHJUHJDWLRQ GMFI GMFIBER-SFP-2K *LJDELW6)3¿EHUWUDQVFHLYHUPPNP *LJDELW6)3¿EHUWUDQVFHLYHUPPNP „ And„more GSFI GSFIBER-SFP-10K *LJDELW6)3¿EHUWUDQVFHLYHUVPNP *LJDELW6)3¿EHUWUDQVFHLYHUVPNP REAL-TIME-RING™ GSFI *LJDELW6)3¿EHUWUDQVFHLYHUVPNP GSFIBER-SFP-30K *LJDELW6)3¿EHUWUDQVFHLYHUVPNP „ /LQNORVVUHFRYHU\P6SOXVP6SHUKRS „ /LQNORVVUHFRYHU\P6SOXVP6SHUKRS GSFI GSFIBER-SFP-50K *LJDELW6)3¿EHUWUDQVFHLYHUVPNP *LJDELW6)3¿EHUWUDQVFHLYHUVPNP „ Switches „ in a ring:
EF32FSA0N-1 价格&库存
很抱歉,暂时无法提供与“EF32FSA0N-1”相匹配的价格&库存,您可以联系我们找货
EF32FSA0N-1
    • 1+23693.968901+3069.19765
