BLF6G15LS-40RN,118
BLF6G15LS-40RN,118
    AMPLEON(安谱隆)
    TRANS RF LDMOS 40W SOT1135B
BLF6G15LS-40RN,118 数据手册
BLF6G15L-40RN; BLF6G15LS-40RN Power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 40 W LDMOS power transistor for base station applications at frequencies from 1450 MHz to 1550 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a class-AB production test circuit. Test signal 2-carrier W-CDMA [1] f VDS PL(AV) Gp D ACPR (MHz) (V) (W) (dB) (%) (dBc) 1476 to 1511 28 2.5 22.5 13.5 45[1] Test signal: 3GPP test model 1; 64 DPCH; PAR = 8.4 dB at probability of 0.01 % on CCDF carrier; carrier spacing 5 MHz. 1.2 Features and benefits  Typical 2-carrier W-CDMA performance at frequencies of 1476 MHz and 1511 MHz, a supply voltage of 28 V and an IDq of 375 mA:  Average output power = 2.5 W  Power gain = 22.5 dB  Efficiency = 13.5 %  ACPR = 45 dBc  Easy power control  Integrated ESD protection  Enhanced ruggedness  High efficiency  Excellent thermal stability  Designed for broadband operation (1450 MHz to 1550 MHz)  Internally matched for ease of use  Compliant to Restriction of Hazardous Substances (RoHS) Directive 2002/95/EC. 1.3 Applications  RF power amplifiers for W-CDMA base stations and multi carrier applications in the 1450 MHz to 1550 MHz frequency range BLF6G15L(S)-40RN Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G15L-40RN (SOT1135A) 1 drain 2 gate 3 source 1 1 [1] 2 3 3 sym112 2 BLF6G15LS-40RN (SOT1135B) 1 drain 2 gate 3 source 1 1 [1] 2 3 3 sym112 2 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF6G15L-40RN - flanged ceramic package; 2 mounting holes; 2 leads SOT1135A BLF6G15LS-40RN - earless flanged ceramic package; 2 leads SOT1135B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 65 V VGS gate-source voltage 0.5 +11 V Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. Symbol Thermal characteristics Parameter Conditions Typ Unit Rth(j-case) thermal resistance from junction to case Tcase = 80 C; PL = 2.5 W (CW) BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 1.30 K/W © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 6. Characteristics Table 6. Characteristics Tj = 25 C per section; unless otherwise specified Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage Min Typ Max Unit VGS = 0 V; ID = 0.59 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 59 mA 1.4 1.8 2.4 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 9.4 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA gfs forward transconductance VDS = 10 V; ID = 58.9 mA - 0.5 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 2.06 A - 0.32 -  7. Application information Table 7. 2-carrier W-CDMA RF performance Class-AB production test circuit; PAR 8.4 dB at 0.01 % probability on CCDF; carrier spacing 5 MHz; 3GPP test model 1; 64 DPCH; f1 = 1476 MHz; f2 = 1511 MHz; RF performance at VDS = 28 V; IDq = 375 mA; Tcase = 25 C; unless otherwise specified. Symbol Parameter PL(AV) average output power Conditions Gp power gain RLin input return loss Min Typ Max Unit - 2.5 - W PL(AV) = 2.5 W 19.8 22.5 - dB PL(AV) = 2.5 W - 16 11 dB D drain efficiency PL(AV) = 2.5 W 11.5 13.5 - % ACPR adjacent channel power ratio PL(AV) = 2.5 W - 45 40 dBc 7.1 Ruggedness in Class-AB operations The BLF6G15L-40RN and the BLF6G15LS-40RN are capable of withstanding a load mismatch corresponding to VSWR 10 : 1 through all phases under following conditions: VDS = 28 V; IDq = 375 mA; PL = 40 W; f = 1476 MHz (CW). 8. Test information 8.1 Impedance information Table 8. Typical impedance Measured load-pull data. Typical values per section. IDq = 330 mA; main transistor VDS = 28 V ZS and ZL defined in Figure 1. BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet f ZS ZL (MHz) () () 1450 4.4  j5.9 5.5  j4.6 1480 4.4  j4.1 5.0  j5.0 1510 6.4  j4.7 5.0  j5.0 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 12 BLF6G15L(S)-40RN Power LDMOS transistor drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 8.2 One-tone graphs aaa-003082 30 60 Gp (dB) ηD (%) 25 50 20 40 (2) (1) (3) (5) (4) (6) 15 10 30 20 5 0 10 28 32 36 40 44 PL (dBm) 48 0 VDS = 28 V; IDq = 375 mA. (1) Gp at f = 1475 MHz (2) Gp at f = 1493 MHz (3) Gp at f = 1511 MHz (4) D at f = 1475 MHz (5) D at f = 1493 MHz (6) D at f = 1511 MHz Fig 2. BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet Power gain and drain efficiency as function of load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 8.3 2-Carrier W-CDMA graphs 3GPP, test model 1; 64 DPCH, PAR = 8.4 dB at 0.01 % probability, 5 MHz carrier spacing. aaa-003083 30 60 Gp (dB) ηD (%) 25 50 20 (2) (1) (3) (6) (5) (4) 15 10 5 0 28 30 32 34 36 38 40 42 PL (dBm) 44 aaa-003084 -10 ACPR5M (dBc) -20 (3) (2) (1) (6) (5) (4) 40 -30 30 -40 -40 20 -50 -50 10 -60 -60 0 -70 Tamb = 25 C. 28 30 32 34 36 (1) ACPR5M at f = 1475 MHz (2) Gp at f = 1493 MHz (2) ACPR5M at f = 1493 MHz (3) Gp at f = 1511 MHz (3) ACPR5M at f = 1511 MHz (4) D at f = 1475 MHz (4) ACPR10M at f = 1475 MHz (5) D at f = 1493 MHz (5) ACPR10M at f = 1493 MHz (6) D at f = 1511 MHz (6) ACPR10M at f = 1511 MHz Power gain and drain efficiency as function of load power; typical values BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet -30 38 40 42 PL (dBm) 44 -70 Tamb = 25 C. (1) Gp at f = 1475 MHz Fig 3. -10 ACPR10M (dBc) -20 Fig 4. Adjacent channel power ratio (5 MHz and 10 MHz) as a function of load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 8.4 Test circuit C10 C2 C8 C3 C9 C4 C11 C12 R1 C1 C17 C6 C7 C5 R2 C13 C14 C15 C16 aaa-003059 Striplines are on a double copper-clad Rogers R04350 Printed-Circuit Board (PCB) with r = 3.5, thickness = 0.762 mm and thickness copper plating = 35 m. See Table 9 for list of components. Fig 5. Component layout for test circuit Table 9. List of components For test circuit, see Figure 5. BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet Component Description Value C1, C17 multilayer ceramic chip capacitor 24 pF [1] C3, C6 multilayer ceramic chip capacitor 68 pF [2] C4, C7, C8 multilayer ceramic chip capacitor 150 pF [2] C9, C14 multilayer ceramic chip capacitor 47 pF [2] C13 multilayer ceramic chip capacitor 15 pF [2] C2, C5, C11, C16 multilayer ceramic chip capacitor 10 F [3] C10, C15 multilayer ceramic chip capacitor 0.1 F [3] C12 electrolytic capacitor 2200 F, 50 V R1, R2 chip resistor 15  [1] American technical ceramics type 800B or capacitor of same quality. [2] American technical ceramics type 100B or capacitor of same quality. [3] TDK or capacitor of same quality. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 Remarks © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT1135A D A F D1 U1 B q C c 1 H p U2 E1 w1 3 E B A A 2 b w2 C 0 5 mm 10 mm scale Dimensions Unit(1) Q A max 4.65 nom min 3.76 b 5.26 c D D1 E E1 F 0.18 9.65 9.65 9.65 9.65 1.14 H p Q 19.94 3.30 1.70 q U1 U2 0.10 9.40 9.40 9.40 9.40 0.89 18.92 2.92 w2 20.45 9.91 15.24 5.00 w1 1.45 max 0.183 0.207 0.007 0.38 0.38 0.38 0.38 0.045 0.785 0.130 0.067 inches nom 0.6 min 0.148 0.197 0.004 0.37 0.37 0.37 0.37 0.035 0.745 0.115 0.057 0.25 0.51 20.19 9.65 0.805 0.39 0.01 0.02 0.795 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA Issue date 09-10-12 09-12-14 SOT1135A Fig 6. sot1135a_po European projection Package outline SOT1135A BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 12 BLF6G15L(S)-40RN Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT1135B D A F 3 D1 D U1 c 1 H U2 E1 2 b w2 D 0 Q 5 10 mm scale Dimensions Unit(1) A max 4.65 nom min 3.76 b c D D1 E E1 F H Q U1 U2 5.26 0.18 9.65 9.65 9.65 9.65 1.14 19.94 1.70 9.91 9.91 5.00 0.10 9.40 9.40 9.40 9.40 0.89 18.92 1.45 9.65 9.65 max 0.183 0.207 0.007 0.38 0.38 0.38 0.38 0.045 0.785 0.067 inches nom min 0.148 0.197 0.004 0.37 0.37 0.37 0.37 0.035 0.745 0.057 0.39 0.39 0.38 0.38 mm E w2 0.51 0.02 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA Issue date 09-10-12 09-12-14 SOT1135B Fig 7. sot1135b_po European projection Package outline SOT1135B BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 11. Abbreviations Table 10. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical Channel ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor PAR Peak-to-Average Ratio RF Radio Frequency VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 12. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF6G15L-40RN_6G15LS-40RN#3 20150901 - Modifications: Product data sheet BLF6G15L-40RN_6G15L S-40RN v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6G15L-40RN_6G15LS-40RN v.2 20120514 Product data sheet - BLF6G15L-40RN_6G15L S-40RN v.1 BLF6G15L-40RN_6G15LS-40RN v.1 20111027 Objective data sheet - - BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 12 BLF6G15L(S)-40RN Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14. Contact information For more information, please visit: http://www.ampleon.com BLF6G15L-40RN_6G15LS-40RN#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 12 BLF6G15L(S)-40RN Power LDMOS transistor 15. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 8 8.1 8.2 8.3 8.4 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in Class-AB operations . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 3 One-tone graphs. . . . . . . . . . . . . . . . . . . . . . . . 4 2-Carrier W-CDMA graphs . . . . . . . . . . . . . . . . 5 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6G15L-40RN_6G15LS-40RN#3
BLF6G15LS-40RN,118 价格&库存
很抱歉,暂时无法提供与“BLF6G15LS-40RN,118”相匹配的价格&库存,您可以联系我们找货
