66RT-B-1
66RT-B-1
    GREENLEECOMMUNICATIONS(格林利)
    BIT/PACK 1"NAILEATER RT
66RT-B-1 数据手册
BIT/PACK-1"NAILEATER RT(66RT) "Auger Bit 1"" x 8-5/8 " Cat No: 66RT-B-1 UPC No: 783310001461 Description • • • • • • Patented tip design: pulls through the wood even after several holes, no pushing to finish the hole Quick change cutting edge and feed screw no more resharpening maximum chip removal over center flute Easy pull back ground shaft More durable high quality carbon alloy steel Made stronger, lasts longer, tool steel cutting edge Specifications • • • • • • • • • • • • Bit Diameter : 1.000 IN D Chain : 4 Material : Carbon Alloy Steel, Tool Steel Cutting Edge Material Master Number : 52059676 Overall Length : 18.000 IN Package : 1/Pack Replacement Part : PTR-1 12562 Replacememt Kit 1.000 IN IN Shank Diameter : 7/16 IN Shank Type : Hexagonal Sub Brand : Nail Eater Type : Replaceable Tip Weight : 1.800 LB (817.000 GM)
66RT-B-1 价格&库存
很抱歉,暂时无法提供与“66RT-B-1”相匹配的价格&库存,您可以联系我们找货
