353-503
353-503
    GREENLEECOMMUNICATIONS(格林利)
    BLADERECIP
353-503 数据手册
BLADE,RECIP.,6" x 5/8TPI (POP 5 PKG) RECIP BLADE 6 WOOD w/NAILS - 5/8TPI Cat No: 353-503 UPC No: 783310130055 Description • • • • Progressive-pitch reciprocating saw blades cut a wide range of standard construction materials quickly and cleanly - regardless of thickness Bi-metal construction provides maximum flexibility and break resistance - plus lastingsharpness Exclusive plunge tip makesstarting cuts faster and easier Blades color coded by application Specifications • • • • • • • Application : For Wood With Nails Dimensions : 1.900 IN X 6.100 IN X 0.100 IN (4.800 CM X 20.600 CM) Length : 6.000 IN Material : Bi-Metal With Cobalt Teeth Per Inch : 5/8 TPI Type : Reciprocating Weight : 0.190 LB (0.090 KG)
353-503 价格&库存
很抱歉,暂时无法提供与“353-503”相匹配的价格&库存,您可以联系我们找货
