LS60LA230
LS60LA230
    GREENLEECOMMUNICATIONS(格林利)
    DRIVER PUNCH 230V AC ADAPTER
LS60LA230 数据手册
DRIVER, PUNCH 230V AC ADAPTER Punch Driver w/230 VAC Adapter Cat No: LS60LA230 UPC No: 783310521624 Description • • • • • • • • • State of the art 18V lithium ion (Li-ion) battery provides 70% more cycles per charge and faster cycle times LED light provides the operator with the battery charge and toolmaintenance status Forward handle position improves tool balance One trigger controls all tool functions Punching cycle stops automatically when hole is completeto prevent damage to punch Overmolded tacky grip areas make gripping the tool easier and more comfortable LED work light illuminatesdark work areas Greenlee battery-powered crimping tools now use bio-degradable oil Smart chargers control thecharging current, charging voltage and battery temperature to maximize battery life10~ Available with 120V, 12V or 230V battery charger or with 120V or 230V corded adapter in place of batteries and charger Specifications • • • • • • • • • • • • Battery : 18 V, 3.0 AMP-HR Lithium-Ion Battery Charge Time : 1 HR Height : 12.500 IN (318.000 MM) Includes : "1614SS UPC 30043 Draw Stud 3/8"" x 2-13/16"", 31872 UPC 31872 Draw Stud 3/4"" x 4-1/8"",1924AA UPC 03248 Spacer-Short, 33967 UPC 33967 Stud Adapter3/8"", 01686 UPC 01686 Metal Case, MKLS60 UPC 05956 Case for LS60 " Maximum Punch Force : 6.7 TON (60 KN) Maximum Ram Travel : 0.870 IN (22.000 MM) Maximum Rectangular Punch Size : 1.378 X 2.559 IN (35.000 X 65.000 MM) Maximum Round Punch Size : 2.420 IN Diameter (61.500 MM) Maximum Square Punch Size : 2-11/16 X 2-11/16 IN (68.000 X 68.000 MM) Overall Length Ram Retracted : 11.500 IN (292.000 MM) Type : Battery Powered, Knockout Punch Weight : 8.800 LB (4.000 KG)
LS60LA230 价格&库存
很抱歉,暂时无法提供与“LS60LA230”相匹配的价格&库存,您可以联系我们找货
