HOLESAW,VARIABLE PITCH (1 3/16")
Bi-Metal Hole Saws
Cat No:
825-1-3/16
UPC No:
783310191438
Description
Cut through steel, tin, aluminum, fiberglass, wood and plastic
Deep 1-5/8 IN (41.3 mm) cutting depth allows for cuttingthrough 2 IN x 4 IN wood studs
Extra-tough bi-metal blade- we use the highest grade oftool steel to outlast competitor's blades.
That beats premature saw replacement and savesyou money
Steam oxide finish - no paint to gum up and slow cutting. The saw runs cooler for longer life and
better performance
Extra-thick backplate minimizes vibration for smoother, easier, less tiring cutting
Made in USA
Specifications
Cutting Size : 1-5/8 IN
Hole Diameter : 1-3/16 IN
Material : Bi-Metal
Type : Variable Pitch
Use With Quick Change Arbor No. : 2800
Use With Standard Arbor No. : 37157, 37155 Or 38522
很抱歉,暂时无法提供与“825-1-3/16”相匹配的价格&库存,您可以联系我们找货
