MAS-SET-9
MAS-SET-9
    GREENLEECOMMUNICATIONS(格林利)
    HEXQUICKCHANGEKIT1/4"
MAS-SET-9 数据手册
HEX QUICK CHANGE KIT,1/4"(POP) HEX QUICK CHANGE MASONRY BIT KIT (POP) INCLUDES: (1) 1/2, (2) 1/4, (2) 3/16, (1) 3/8, (1)5/16, (2) 5/32 Cat No: MAS-SET-9 UPC No: 783310021452 Description • • • • • One piece hardened carbon steel body and hex shank for a stronger, more concentric bit that will not disassemble whendrilling in deep or tough materials Carbide grade tip for faster penetration and longer bit life Hammer drill rated for usein either standard or hammer drills 1/4 IN quick-change hex for fast bit changes, Use in quick-change chucks, conventionaladjustable drill chucks, and hex adapters for more versatility Set includes diameters andlengths most commonly used byelectricians Specifications • • • • • • • Case Dimensions : 7.900 IN X 5.400 IN X 1.000 IN Includes : (1) 1/2 IN, (2) 1/4 IN, (2) 3/16 IN, (1) 3/8 IN, (1) 5/16 IN, (2) 5/32 IN Masonry Drill Bits Material : Carbon Steel Body, Carbide Grade Tip Package : 1/Pack Shank Type : Hex Type : Quick Change Weight : 0.800 LB
MAS-SET-9 价格&库存
很抱歉,暂时无法提供与“MAS-SET-9”相匹配的价格&库存,您可以联系我们找货
