MAS-5/32
MAS-5/32
    GREENLEECOMMUNICATIONS(格林利)
    MASONRY BIT 5/32" HEX QUICK 4"
MAS-5/32 数据手册
MASONRY BIT, 5/32", HEX QUICK CHANGE 4" 5/32 MASONRY DRILL BIT (POP) Cat No: MAS-5/32 UPC No: 783310049418 Description • • • • • One piece hardened carbon steel body and hex shank for a stronger, more concentric bit that will not disassemble whendrilling in deep or tough materials Carbide grade tip for faster penetration and longer bit life Hammer drill rated for usein either standard or hammer drills 1/4 IN quick-change hex for fast bit changes. Use in quick-change chucks, conventionaladjustable drill chucks, and hex adapters for more versatility Set includes diameters andlengths most commonly used byelectricians Specifications • • • • • • • • Application : For Use In Either Standard OrHammer Drills Bit Diameter : 5/32 IN Case Dimensions : 1.900 IN X 6.300 IN X 0.160 IN Material : Hardened Carbon Steel With Carbide Tip Overall Length : 4.000 IN Package : 1/Box Shank Type : Hexagonal Weight : 0.100 LB
MAS-5/32 价格&库存
很抱歉,暂时无法提供与“MAS-5/32”相匹配的价格&库存,您可以联系我们找货
