SDS-3/8
SDS-3/8
    GREENLEECOMMUNICATIONS(格林利)
    MASONRY BIT 3/8" SDS PLUS 6"
SDS-3/8 数据手册
MASONRY BIT, 3/8", SDS PLUS, 6" (POP) 3/8 SDS-PLUS MASONRY BIT, 6 (POP) Cat No: SDS-3/8 UPC No: 783310049463 Description • • • • • • Hardened, premium carbide insert tip is strong and stays sharp longer for finer material break up and easier drilling Shaft made from hardened alloy steel for heavy shock resistance and longer bit life Carbide tip sized in inches versus mm for more accurate hole size H-Style flute for faster drilling and material removal SDS Plus drive for more secure hold in rotary hammer drill Kit includes diameters andlengths most commonly used byelectricians Specifications • • • • • • • • Application : For More Secure Hold In Rotary Hammer Drill Bit Diameter : 3/8 IN Case Dimensions : 1.900 IN X 9.300 IN X 0.380 IN Material : Hardened Alloy Steel With Carbide Tip Overall Length : 6.000 IN Package : 1/Box Shank Type : SDS-PLUS Weight : 0.300 LB
SDS-3/8 价格&库存
很抱歉,暂时无法提供与“SDS-3/8”相匹配的价格&库存,您可以联系我们找货
