SDS-1/2
SDS-1/2
    GREENLEECOMMUNICATIONS(格林利)
    MASONRYBIT1/2"SDSPLUS6"
SDS-1/2 数据手册
MASONRY BIT, 1/2", SDS PLUS 6" (POP) 1/2 SDS-PLUS MASONRY BIT, 6 (POP) Cat No: SDS-1/2 UPC No: 783310049470 Description • • • • • • Hardened, premium carbide insert tip is strong and stays sharp longer for finer material break up and easier drilling Shaft made from hardened alloy steel for heavy shock resistance and longer bit life Carbide tip sized in inches versus mm for more accurate hole size H-Style flute for faster drilling and material removal SDS Plus drive for more secure hold in rotary hammer drill Kit includes diameters andlengths most commonly used byelectricians Specifications • • • • • • • • Application : For More Secure Hold In Rotary Hammer Drill Bit Diameter : 1/2 IN Case Dimensions : 1.900 IN X 9.300 IN X 0.500 IN Material : Hardened Alloy Steel With Carbide Tip Overall Length : 6.000 IN Package : 1/Box Shank Type : SDS-PLUS Weight : 0.300 LB
SDS-1/2
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款具有较高灵敏度的红外接收头,广泛应用于遥控器、红外通信等场景。
3. 引脚分配:EL817共有3个引脚,分别为VCC、OUT和GND。
4. 参数特性:工作电压范围为3V-6V,工作电流小于10mA,响应波长范围为850-950nm。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号,具有较高的灵敏度和抗干扰能力。
6. 应用信息:主要用于家用电器、汽车电子、安防监控等领域的红外信号接收。
7. 封装信息:EL817采用塑料封装,尺寸为3.51.5mm,具有良好的机械性能和电气性能。
SDS-1/2 价格&库存
很抱歉,暂时无法提供与“SDS-1/2”相匹配的价格&库存,您可以联系我们找货
