12356
12356
    GREENLEECOMMUNICATIONS(格林利)
12356 数据手册
PUNCH UNT-1/2" (POP) Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 12356 UPC No: 783310123569 Description • • • • • • "The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52"" (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster " Specifications • • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 16 GA (1.500 MM) Includes : Punch, Die And Draw Stud Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers PG : 7 Replacement Part : 12360 UPC 12360 Punch, 12358 UPC 12358 Die And 1675AV UPC 04218 Draw Stud Size : 1/2 IN (12.700 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 0.150 LB (69.000 GM)
12356 价格&库存
很抱歉,暂时无法提供与“12356”相匹配的价格&库存,您可以联系我们找货
