12357
12357
    GREENLEECOMMUNICATIONS(格林利)
    PUNCH UNT-9/16"
12357 数据手册
PUNCH UNT-9/16" (POP) Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 12357 UPC No: 783310123576 Description • • • • • • "The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52"" (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster " Specifications • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 16 GA (1.500 MM) Includes : Punch, Die And Draw Stud Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers Replacement Part : 12357 UPC 12357 Punch, 12361 UPC 12361 Die And 1675AV UPC 04218 Draw Stud Size : 9/16 IN (14.300 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 0.160 LB (73.500 GM)
12357 价格&库存
很抱歉,暂时无法提供与“12357”相匹配的价格&库存,您可以联系我们找货
