60C-3/4
60C-3/4
    GREENLEECOMMUNICATIONS(格林利)
60C-3/4 数据手册
BIT,COMBINATION,QUICK CHANGE 3/4C (POP) BIT, AUGER, QUICK CHANGE 3/4C(POP) Cat No: 60C-3/4 UPC No: 783310313915 Description • • • • • • All the same great featuresas a traditional flexible drill bit, but with even more flexibility and versatility Simplifies the frustratingand time-consuming process ofinstalling wire or cable inside existing walls For use when drilling between studs and joists Can use with any type of bit with a 1/4 IN quick change hex on it, such as spade bits,auger bits or drill bits for increased application flexibility Replace only the bit as itwears rather than the entire bit and shaft for lower overall cost of ownership Quickly and easily switch from drilling to pulling with the quick change pulling grip,No more fiddling with hookinga pulling grip to the bit Specifications • • • • • • Application : For Use When Drilling BetweenStuds And Joists Bit Diameter : 3/4 IN Dimensions : 1.060 IN X 3.750 IN X 8.250 IN Sub Brand : D'VersiBIT Type : Quick Change, Combination Weight : 0.340 LB (0.150 KG)
60C-3/4 价格&库存
很抱歉,暂时无法提供与“60C-3/4”相匹配的价格&库存,您可以联系我们找货
